Air conditioning
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by taxidriver50005, May 26, 2020.
  1. taxidriver50005
    taxidriver50005 Active Member
    204
    170
    GB
    Excel
    Air con not as cool as it should be, it's still working but does anybody know what pressure I should get when checking on gauges before I take to dealers for recharge service.
  2. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    Get a Freon can from Walmart with a built in gauge and see
  3. 2012 Prius v wagon 3
    2012 Prius v wagon 3 Active Member
    281
    277
    Redwood City, California
    From the service manual:
    3. CHECK REFRIGERANT PRESSURE
    (a) Install the manifold gauge set .
    (b) Read the manifold gauge pressure when the following conditions are
    established.
    (1) Prepare the vehicle according to the chart below.
    Item: Condition
    Vehicle Doors: All fully open
    Temperature Setting: MAX COLD
    Blower Speed: HI
    A/C switch: ON
    R/F Switch: RECIRCULATION (30 to 35°C (86 to 95°F))
    Standard Pressure:
    Low pressure side
    0.15 to 0.25 MPa (1.5 to 2.5 kgf/cm2, 21.3 to 35.6 psi)
    High pressure side
    1.37 to 1.57 MPa (14 to 16 kgf/cm2, 199 to 228 psi)
  4. taxidriver50005
    204
    170
    GB
    Excel
    Very helpfully cheers
