My White 08 Prius With 50K Miles
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by LeoThePriusGuy, May 28, 2020.
  1. LeoThePriusGuy
    LeoThePriusGuy New Member
    McHenry Maryland
    My Prius 08 50K Miles Has The Vsc Light Red Triangle Tire Pressure Light AirBag Light And The Check Engine Light On Went To The Toyota Dealership And They Gave Me Codes. I Bought The Car I’m 2010. New I Replaced The 12V In 2014. Oil Was Changed 1/03/20. The Tires Were Changed In 2014. I Need Some Options. Here Are The Codes.
    C1415 - Rear Speed Sensor Right Output Malfunction
    C1259 - HV System Regenerative Malfunction
    C1201 - Engine Control System Malfunction
    C2318 - Low Voltage Error Power Supply Malfunction
    C1310 - Malfunction In HV System
    C1242- IG2 Power Source Circuit
    P0A7F - Hybrid Battery Pack Deterioration
    P0A80 - Replace Hybrid Battery Pack
    P3013 - Battery Block 3 Becomes Weak
    P3014 - Battery Block 4 Becomes Weak
    P3000 - Battery Control System Malfunction
    P0AC2 - Hybrid Battery Pack Current Sensor 'A' Circuit High
    P0AFA - Hybrid Battery System Voltage Low
    P0516 - Battery Temperature Sensor Circuit Low
    P0119 - Engine Coolant Temperature Circuit Intermittent
    B1424 - Solar Sensor Circuit Driver Side
    B1473 - A/C Inverter Start-Up Signal System Malfunction
    B1635 - Front Passenger Side Rear Airbag Sensor Circuit Malfunction
    B2799 - Engine Immobilizer Malfunction
    U0293 - Lost Communication With Hybrid Vehicle ECU
    #1 LeoThePriusGuy, May 28, 2020
  2. LeoThePriusGuy
    McHenry Maryland
    Also the 12v battery light is on the screen where you check your hybrid battery. It’s keeps draining to fast the hv battery and goes up to fast to fully green and back to purple one bar.
  3. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    Welcome to PriusChat!!
    Options are going to be expensive unless you have a DIY mindset.
    You have quite the collection of OBD2 codes (DTCs), did those just appear suddenly out of nowhere?
    Did the dealership quote you a price to fix the above issues?
    How is the body and does/will it pass inspections?
  4. bisco
    49,479
    start with a new 12v. reread the codes with tech stream. depending on what codes come back, replace the hybrid battery if necessary. at 50k, the rest of the car has many, many years of happy motoring ahead.
