Charging 2 Plugins at home?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by pokenoprius, May 29, 2020.
  1. pokenoprius
    pokenoprius Member
    51
    27
    New Zealand
    2018 Nissan LEAF
    Hi Everyone.
    Our family have 2x 2013 plugins. We have one 240v dedicated weather safe outdoor power socket ( NZ style ) with a dedicated circiut breaker in the fusebox inside. All good there. Is it safe to plug in our second car at the same time to charge both , as long as it is not on the same circuit as the outdoor charger?
    Power cost is not a worry, as we have a free hour of power to use every day, so would be great to take advantage of that. The house is 3 years old, so house wiring quality and age are not a worry.
    I will need to find a suitable extension cord that can handle the load for the second car( wont use a standard department store cord )
    Thanks for any advice.
  2. hieronymous
    hieronymous Member
    154
    92
    Auckland, New Zealand
    2013 Prius Plug-in
    PiPs draw 10A - think 2.4 kWh heater, no difference. Your power circuits are almost certainly 15A. All trip ratings are for continuous load, peak load assume 30% higher I.e. your 15A circuit won't fall over with 17A.
    Extension cords are a bad idea period, and a no-no outside.
    Work out which of your 15A circuits has the lightest load, then plug your 2nd PiP into that. Get your sparkie to replace that circuit breaker with a combined trip/rcd module for the safest outcome..
    QuantumFireball likes this.
  3. pokenoprius
    pokenoprius Member
    51
    27
    New Zealand
    2018 Nissan LEAF
    Thanks hieronymous, good advice
  4. kenmce
    kenmce High Voltage Member
    1,549
    522
    NY
    Should be fine. Just find a circuit that can handle a 13 Amp load.
    A 2013 PIP should pull 13 Amps, so a 12 gauge cord would work well. (Wonders if Kiwis have electrical gauges or use something metric...)
