Megan 26mm rear sway bar on gen 2?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Salstats, May 31, 2020.
  1. Salstats
    Salstats Junior Member
    North Tustin
    Can someone verify if this rear sway bar will work on a gen 2? I recently installed a 2005 Toyota Corolla front sway bar (24mm) on my 2009 Prius but now want to upgrade the rear. I know the TRD and Progress fit but just feel that they are overpriced. I did see a cheap "Focuz Motorsports Development" rear sway bar for like $45 on eBay (seems to good to be true so I'll stay away). Screenshot_20200531-000615_eBay.jpeg
  2. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    744
    Delaware
    sure looks like it'll fit
  3. Strlinmoss
    Strlinmoss Junior Member
    Los Angeles
    I see the tread is old but I just installed this bar on the gen2. The ends are a little taller about .250 has to be milled off to fit. The swap turned out great. The car feel alot more sure footed around corners.
  4. Moses Bruh
    Moses Bruh Member
    97
    29
    there is a thread on here with a trd sway bar from a matric/corrolla that works great.
