O2 sensor faulty
Discussion in 'Gen 2 Prius Main Forum' started by moha777, Jun 1, 2020.
  1. moha777
    moha777 Junior Member
    GB
    Hi everyone,
    In my prius 2008 in 190k I have changed 02 sensor both not genuine and again one genuine but lights keep coming.i am much obliged if any one experience the same can advice me.BELOW IS THE DIAGNOSTIC PICTURES TIA. Screenshot_20200529-175341_Drive.jpeg
  2. moha777
    GB
    Hi thanks for the info.apologies my technical knowledge is low.would u think if air flow sensor need checked and replaced.or fuses need checked and replaced.or 12v battery checked replaced.thanks
  3. SFO
    SFO Senior Member
    5,302
    4,249
    Northern California
    The workups in the factory manual are designed to be followed step by step.
    I would start with step #1 in each workup (p0031 and p0037), and measure the resistance for both aftermarket sensors as that could be the problem. Which brand and part# did you replace them with, most would recommend using Denso or toyota OEM sensors only.
    If the vehicle starts, the 12v battery should be fine for the time being.
