Replacing Timing Chain
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by kkmestrada, May 28, 2020.
  1. kkmestrada
    kkmestrada Junior Member
    Need help stop rattling engine noise at startup. I replaced the Timing Chain Tensioner but still makes the noise sometimes. I'm looking for a "How to" change the timing chain. Please direct me to the right path. thanks
  2. StarCaller
    StarCaller Senior Member
    1,240
    692
    Cedar Crest, NM, USA
    very likely NOT the timing chain....
  3. SFO
    SFO Senior Member
    5,286
    4,226
    Northern California
    Welcome to PriusChat!!
    How many miles on her?
  4. T1 Terry
    T1 Terry Active Member
    585
    297
    Have you tried accelerating hard to see if the noise is there then as well? If it is, the problem is a blocked catalytic converter, not a timing chain rattle. I replaced the full timing chain, guides, tensioner and water pump (because it had to come out anyway) in my 2008 Gen 2 Prius only to still have the rattle. Turned out to be exhaust pressure build up forcing the engine pipe away from the manifold (held in place with springs compressed as the bolts are tightened) the rapid pressure release causing the springs to slam the pipe back against the manifold, then the pressure build up and the whole pattern repeats. I am a mechanic by trade and it sure sounded like timing chain rattle to me, it is not an easy job to replace the chain and my ex taxi Prius had 720.000km on the clock so it was possible with that sort of mileage on the clock. Once I got it all apart I could see the tensioner hadn't quite reached its full travel and there were no signs of chewed out guides that would have created the metal on metal sound.
    If you really want to replace the timing chain, look for a You Tube video for the same engine code to get the idea of what needs to come out, in my case the engine mount was the most trouble, the rest was just a battle to get in between the inner guard/strut tower and the timing cover to get to the hidden bolts. I bought the whole kit on Evil Bay, cheap enough and you can figure out where the bolts are by looking at the replacement gaskets.
    T1 Terry
    T1 Terry
  5. b100
    b100 Member
    139
    72
    Netherlands
    I likely not your chain. Prius gen3 will rattle with clogged egr system.
    tankyuong likes this.
  6. kkmestrada
    Thanks T1 Terry.
    I have 320k on my gen3 mostly long distance driving. I recently cleaned the EGR intercooler all the way to the intake manifold and replaced gasket. I also replaced the timing chain tensioner and still made the rattling noise and engine shake. But once the engine runs for about 30 seconds it is fine and smooth and have no issues the whole day. I haven’t tried at high rpm because I can’t get it passed 2500rpm (by feel) but when driving uphill and engine revs up I still don’t hear rattling sounds. But smooth high revving engine. So I’m inclined to go your Catalitic converter route instead of replacing timing chain. Next question ...where do I start? I only watch YouTube video doing all these. Thanks in advance for guiding me in this process. I cannot afford a mechanic right now.
  7. T1 Terry
    585
    297
    If the engine revs freely on a hill climb, it isn't likely to be the catalytic converter, if it was partially blocked the engine would struggle getting the exhaust gas out and the rattle would be serious.
    A dribbling injector could cause a rough run start up and knocking with a slight hydraulic lock or compression that high the fuel in the cyl starts to self ignite. A ruptured fuel pressure regulator diaphragm will do a similar thing but usually doesn't settle down after the motor has run for a few minutes.
    A slight head gasket leak allowing water into a cylinder will do a similar thing, is it using water at all or do you see fine bubbles in the radiator?
    T1 Terry
    2012 Prius v wagon 3 likes this.
  8. Dxta
    Dxta Senior Member
    1,932
    766
    Lagos
    You may have to take a look at the intake(VVTi) camshaft gear
  9. Mendel Leisk
    38,259
    So everything's cleaned on the EGR, all the way back to the Exhaust Manifold connection?
    Have you cleaned the intake manifold too? Everything, but in particular the small passageways (about 1/4" diameter at most) at each port. They are the last leg of the EGR circuit.
