Sway Bar Links?
Discussion in 'Gen 3 Prius Main Forum' started by Luis Egas, Jun 1, 2020.
  1. Luis Egas
    Luis Egas Junior Member
    Ontario, CA
    Hey Guys,
    I'm new on here & this is my first post. Just wondering if anyone has replaced sway bar links, as my passenger side link has a torn boot. I bought this car off an old lady with only 39K miles, so not sure why this is happening! Anyhow, my question is: would it make a difference to install better, aftermarket links?? The car is completely stock but thinking about lowering it though...
  2. Grit
    Grit Senior Member
    6,576
    4,228
    Wilkes Land
    Dam, Granny winning car races with turns!
    mikey_t likes this.
  3. Greenteapri
    Greenteapri Active Member
    330
    387
    Cypress
    I replaced my failed sway bar links with Moogs. Reputable company that sells on Amazon. I believe they cost half of Toyota OEM. They've been working on for several thousand miles with no hassles. I would recommend them.
    How do you know yours are bad?
    mikey_t likes this.
  4. Tiff
    Tiff Junior Member
    86
    Crawley
    Seeing as your in Canada i dont know but i used meyle hd drop links, part number 30-16-060-0053/hd. Ive done close to 80k on them No issues. Would recommend you do sway bar bushes as well easy to do and cheap
  5. Mendel Leisk
    41,861
    He's likely in Ontario, California. Should know better than to enter state address as "CA", lol.
    Montgomery likes this.
  6. Paul E. Highway
    Paul E. Highway Active Member
    209
    129
    Hawaii
    I did the Moog links at 149K while doing brakes. Boots were shot, links are cheap and the Moogs have grease fittings so I can lube when I rotate tires. Rattles when turning or going into a driveway disappeared. Takes maybe 10 mins if you have tire off already.
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    Moog is now and has been absolute Chinese garbage. Bet you bought them at Rock Auto. Half price of oem and you think its better? Its not its not even half as good. Denso is the best. That's why it costs twice as much.
    Buy OEM on line like Olathe Toyota etc.
    Wraiththe likes this.
  8. CharlesPrius
    CharlesPrius Member
    154
    60
    I've thought of getting the Moogs. Do you ever re-grease them? They recommend it every oil change. But I'm wondering whether the non-greasable ones are less hassle.
  9. Paul E. Highway
    209
    129
    Hawaii
    Moogs have been fine. I shoot grease in fitting when I rotate tires at oil change time (5K miles.)
  10. CharlesPrius
    CharlesPrius Member
    154
    60
    Thanks. How much would a shop charge to do this each oil change? And what is the downside of buying links that don’t need to be oiled after install?
