2012 Pip five codes that won’t reset p0a94,p1a64,p1a67,p1a61 and p31ab
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by JAYSON Zimmerman, Jun 1, 2020.
  1. JAYSON Zimmerman
    JAYSON Zimmerman New Member
    Shohola pa
    I was driving the other day and I blew the 150 amp high-voltage fuse.This was the same fuse that was in the recall. So I had the vehicle towed to my local dealership. They told me that they replaced the fuse and now are still unable to clear the codes even with the low voltage prevention override. Please help My car is 304,000 miles on it.
    51,739
    welcome!
    what type of help are you looking for?
  3. JAYSON Zimmerman
    Shohola pa
    Well maybe .what components Is faulty. DC to DC converter or inverter. Any help Towards the solution would be helpful
    Thank you.
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,147
    Tampa, FL
    That a bunch of miles!! I'm impressed.
    I would ask the dealer WHY they can't clear the codes. Generally, you have to fix what triggers the codes. I would expect the dealer, if I'm giving them money, to give me at least an explanation so I can decide if I want to have them fix it. Just saying, "We can't clear the codes," is not in their job description.
    willyag likes this.
  5. bisco
    51,739
    if you had the recall done, i would ask the dealer if it is under extended warranty. if not, call toyota corporate and ask for goodwill assistance
  6. JAYSON Zimmerman
    Shohola pa
  7. JAYSON Zimmerman
    Shohola pa
    They told me they would look into it but it would take quite a of man hours to diagnose which would most likely be over the value of the vehicle
  8. jerrymildred
    11,517
    14,147
    Tampa, FL
    That's a bummer!
  9. Yea Right
    Yea Right Active Member
    232
    115
    Seattle
    2014 Prius Plug-in
    Have you or they tried a reset, by disconnecting the battery completely
  10. JAYSON Zimmerman
    Shohola pa
    Yes still won’t reset
  11. bisco
    51,739
    i think you're gonna have to rent the service manual and use the code troubleshooting
