Boot flap has broken - what should I do?
Discussion in 'Gen 2 Prius Technical Discussion' started by enginestarter, Jun 2, 2020.
  1. enginestarter
    enginestarter Junior Member
    66
    UK
    Active
    The boot flap has broken.
    See below an image of the part.
    (Not sure why, but the image isn't showing. This is the URL for the image:
    Upload and share screenshots and images - print screen online | Snipboard.io )
    I looked around, but couldn't find a name for it.
    I'd be happy to hold in place with a nut and bolt instead of buying the part.
    I thought I would ask here for advice first.
    Thanks.
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,225
    5,910
    Columbia, SC
    "Garnish" I believe is the word...just do a google search for Prius Garnish
    SFO likes this.
  3. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    Try using copy (control - C) and then paste (control - V) the image directly into the posting.
  4. dolj
    dolj Senior Member
    7,651
    3,860
    Wellington, New Zealand
    Or use the Upload a File button at the bottom right of every post edit window.
  5. Mendel Leisk
    38,715
