Emergency brake, ABS, and (!) lights on
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by slickvik, Jun 4, 2020.
  1. slickvik
    slickvik Junior Member
    40
    Three lights just turned on in my 2007 prius:
    Emergency brake
    ABS
    (!) brake system warning light
    I only had a mile to drive when the lights turned on, and the brakes still worked. When I restarted the car the next time they did not show up. Is this a one time issue or possibly the speed sensor?
    I just changed my actuator 6 months ago so it can't be that.
    #1 slickvik, Jun 4, 2020
  2. SFO
    SFO Senior Member
    5,302
    4,248
    Northern California
    Happen to have any OBD2 codes (DTCs) that you can share with us?
  3. slickvik
    40
    No, the local hybrid shop is charging $125 to read techstream codes. So I'm thinking of buying a mini VCI to get an idea at least. I'm driving another car in the meantime.
  4. SFO
    SFO Senior Member
    5,302
    4,248
    Northern California
  5. slickvik
    40
  6. SFO
    SFO Senior Member
    5,302
    4,248
    Northern California
    Not sure which device you're using, but after reading that webpage it appears that the carista product accommodates both platforms.
  7. slickvik
    40
    I'm leaning towards VXDIAG VCX Nano as it seems that Tactrix 2.0 Openport isn't perfect with Generation 2 prius.
  8. dolj
    dolj Senior Member
    8,428
    4,285
    Wellington, New Zealand
    Out of interest, What makes you think that?
  9. ChapmanF
    18,076
    I think I said so somewhere. I have an Openport, and I bought it because the Mini VCI that I already had tended to flake out on my Gen 3. Then one day, I was trying to work on somebody's Gen 2, and whatever I was trying to do (forgotten now) didn't work, and I dug out the Mini VCI and it worked.
    There are no more details in my sieve at the moment.
    SFO likes this.
  10. slickvik
    40
    Code is C1249. Forgot to mention in first post that VSC light was on also. Strangely enough, these lights never came on again.
  11. dolj
    dolj Senior Member
    8,428
    4,285
    What do you mean by this?
    DTC C1249 (Blink code 49) | Open in Stop Light Switch Circuit
    DESCRIPTION
    The skid control ECU inputs the stop light switch signal and detects the braking condition.
    The skid control ECU has a circuit for open detection inside. The skid control ECU outputs the DTC if it detects an open in the stop light signal input line when the stop light switch is off, or an open in the stop light circuit (GND side).
    DTC No. Blink Code INF Code DTC Detection Condition Trouble Area
    1 C1249 49 520 The stop light switch circuit is open for at least 10 sec. when IG1 terminal voltage is between 9.5 V and 17.02 V
    • Stop light switch
    • Stop light switch circuit
    • Stop light bulb
    See DTC C1249 Inspection Procedure for the complete inspection procedure.
    Let us know how you get on.
  12. slickvik
    40
    To your initial comment, what I mean is these 4 lights came on once when I started the Prius a few weeks ago, but never since then.
  13. dolj
    dolj Senior Member
    8,428
    4,285
    And they are still off now? If so, you do not have any faults to investigate currently.
  14. AzusaPrius
    AzusaPrius Senior Member
    2,172
    915
    Change out the rear wheel hub assembly. This is a speed sensor issue and takes a while until the speed sensor error shows up. In the meantime your hybrid battery is taking a hit.
    CPate2020 likes this.
  15. dolj
    dolj Senior Member
    8,428
    4,285
    How do you know this? Are there any codes at present? The OP has indicated all the idiot lights are off (not lit), so this would indicate there is no fault at present.
  16. Gino Veltri
    Gino Veltri Member
    413
    40
    Can you please explain this? why does the hybrid battery take the hit from a speed sensor issue? Thanks in advance!
  17. mr_guy_mann
    mr_guy_mann Senior Member
    4,036
    1,965
    NJ-USA
    If there is a fault with the braking system, then the hybrid control will usually disable regenerative braking. AFAIK the car will still charge the HV battery from ICE operation, but no regen, so there's a hit to mpg.
