2010 Prius Battery Replacement?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by messyj232, Jun 6, 2020.
  1. messyj232
    messyj232 Junior Member
    Hey Everyone!
    My 2010 Prius has about 150,000 miles and the battery charge levels are not quite what they used to be.
    Should I replace the battery?
    Should I keep driving it until the battery no longer charges AND THEN replace the battery?
    Should I give up and get an F-450?
    Thanks so much! Hope all are being safe and healthy (and sane)!
  2. ttou68
    ttou68 Active Member
    351
    211
    I'm assuming you are speaking of the traction battery, not 12V battery..
    Before you decide to replace the battery, I would get an OBDII scanner (Bluetooth or WiFi) and download apps like Dr.Prius on your phone to diagnose your current battery condition...
    If batteries are out of balance, and require maintenance then get battery charger/maintenaner could help you get your battery packs back in shape..
    Here's a link to one highly recommend charger..
    Prolong Battery Systems | Hybrid Automotive California, USA
    There are multiple options in battery replacement, if you do indeed need to replace your battery.. battery from Toyota dealer are now more affordable than ever, and aftermarket replacement batteries are available if you can DIY it yourself..
  3. bisco
    51,792
    welcome!
    not sure what 'battery charge levels are not what they used to be' means
    if you don't have any trouble lights, the battery is still working within acceptable parameters, although a charger as mentioned above could help with longevity.
    read through the egr circuit/head gasket threads. those may make the f-450 decision easier
