Engine doesnt turn off
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Stringer, Sep 23, 2006.
  1. Stringer
    Stringer New Member
    74
    Finland
    Look at this small video clip I tried to take from the problem: clip.
    It goes to that state quite often. Eg. even while it regenerates power or uses electrical motor only, the gas engine doesnt turn off before complete stop. As far as I can tell, the problem occurs only at low speeds like under 50km/h (31mph). It doesnt always happen, but as I said, very often. Since it is still very warm season time, I dont think it has anything to do with outside temperatures. Expecially because it quite often comes in the end of long drive (at the parking zone).
  2. c4
    c4 Active Member
    607
    51
    Whether the engine shuts off at a stop is dependent on a lot of factors.. In most instances, if the cat is at temperature and the engine is hot and you're not asking for engine heat for the heaters or charging of the batteries, the engine should shut off about 10 seconds after you come to a complete stop. In some instances, it seems some other internal criteria is not met and it keeps running, but sometimes you can still force it for example by turning the climate control or A/C on and then off..
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    That is related to the stages of hybrid operation (the article about I can't find and may be lost or needing to be uploaded post site crash).
    In any case, usually it is necessary to get the speed up over 35mph then quickly release the accelerator to enter stealth. most of the time at sub 35mph speeds it will not shut off until your foot is completely off the accelerator for at least 5 seconds.
    Further, with the very low MPG shown it looks like you were still in the initial warm up and it's likely the ICE temp, cats, etcs. were not completely warmed up.
    Finally, make sure you were not in B-mode as that will force the ICE to continue to run.
  4. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    Watching the video, it appeared as though the ICE wasn't running at all... instead, you were first getting regen (either from braking or coasting without feathering the accelerator), then getting power from the motor (maybe you pressed the accelerator ever so slightly?).
    This goes back to the basic operation of the car. At very low speeds (i believe it's 7 and under, someone correct me if i'm wrong), you switch over to using the physical brakes and dont' get any regen. Additionally, there's a "creep" feature in the car, meaning that, if you're stopped and take your foot off the brake, the car will creep forward like a normal car does. In addition to full removal of the brake, only lightly pushing it will allow the creep feature to work too. This happens by running the electric motor, which is what i believe we were seeing in the video.
  5. Stringer
    Stringer New Member
    74
    Finland
    Im sorry, but you all failed to understand the problem. If you watch the video again and pay special attention to the milleage (or litres per kilometer in this case) reading in the bottom of display, you notice it doesnt show zero as it should (in l/km zero means no engine running). That means, ICE is actually running, but the power flows, as you noticed, from everything else than the ICE.
    I know in cold temperatures, or when car is still warming from cold start, the engine might not shut down like it otherwise would. But in this case, outside temperature wasn't cold at all and I had driven long drive already so the engine should have been warm already. Actually Im pretty sure it was warm because at the higher speed it had turned off already. And normally the engine doesn't turn off at low speed if it is not proberly warmed already, but in the video it does do that (watch the number again).
    Also, the video length is well more than 5 seconds.
    <div class='quotetop'>QUOTE(eagle33199 @ Oct 2 2006, 04:23 PM) [snapback]326803[/snapback]</div>
    No, definently did not. I pressed brake slightly all the time.
  6. Stringer
    Stringer New Member
    74
    Finland
    <div class='quotetop'>QUOTE(efusco @ Oct 1 2006, 06:33 AM) [snapback]326332[/snapback]</div>
    D was selected as the video blurry shows.
  7. eagle33199
    5,122
    268
    2015 Prius v wagon
    My guess is you were only in stage 3 operation then. I don't have a link to the stages handy, but essentially in stage 3 the ICE doesn't turn off until after you stop (no mater how long you're cruising at low speed, once it's on it'll stay on). Honestly, it's impossible for any of us to tell you what may or may not be wrong with the car based on a 10 second video clip. If you're concerned about it, take it to the dealer and allow their tech to take it for a test drive. He'll be able to tell if the car is acting appropriately or not.
  8. DanMan32
    DanMan32 Senior Member
    3,799
    27
    Tampa Bay, FL
    Unless the weather outside is 180 degrees, the engine/cat/O2 sensor may not be up to operating temperatures, in which case ICE can remain running to warm things up even when not being used for power. Other posters, such as Evan and C4 did address this.
    However, sometimes the car does seem to have a mind of its own.
    I've had a situation where I drive the car for 40 minutes to a co-worker's development to pick him up. When I reach his development, I have about 500-1000 feet I drive at 15 MPH. Many times the ICE would not shut off until I stopped to let him in. What I started doing when that happened was activate EV.
  9. c4
    c4 Active Member
    607
    51
    The video just gave me a headache- it was bouncing around all over the place and didn't stay focused on one spot long enough to tell what the heck was going on..
    In any case:
    1) The graphic display is idealized and does not reflect the exact behaviour of the vehicle systems at all times; in fact, if you had a CANview or similar device that could monitor the raw data signals, you'd see that quite often, the graphical display is in fact *wrong* (or perhaps just time delayed or oversimplified)..
    2) The car does not necessarily turn the engine off at all opportunities, again, there are a complicated set of criteria that is used to determine when to shut the engine off. The car is very sensitive to temperature, so even if you think it's still warm, just a degree or two drop may cause the car to want to run the engine more.. This happens with my Prius in the fall as well: one day, I'll notice that the engine just doesn't shut down as easily as it did in the heat of summer, and that's my cue to start adding in the engine compartment insulation: the hood-liner first, which resolves the problem for a few weeks, then the first half of the first stage radiator blocker, then the second half, and finally the full front blocker when winter really sets in.. However, even in hotter weather, sometimes the engine still doesn't want to shut off for whatever reason, and you can generally try the trick of playing with the A/C or environmental controls, or if you're still moving, and you don't have EV, sometimes giving it a brief pulse of the accelerator pedal and releasing will also trigger the engine stop.. In the video, although the engine may still be running at the early stages, it is definitely off by the time you come to a complete stop, so as far as I can tell, the car is operating completely normally..
  10. Stringer
    Stringer New Member
    74
    Finland
    <div class='quotetop'>QUOTE(DanMan32 @ Oct 5 2006, 04:58 PM) [snapback]328401[/snapback]</div>
    That sounds like the situation I'm complaining too. However, you dont tell how your enegy flow acted in your situation. If it showed it was actually driving with the ICE, eg. the energy did flow from engine to tires, then it was just fine because that happens from time to time in slow speeds. But if it did show regeneration and/or only power flow from electric motor to tires while ICE was still on, then to me it doesnt sound like what it should have been doing.
    I would accept the cat/O2 sensors as a reason to act like that, but only if someone proves that those temperatuers can cool down in matter of 1-2 minutes after driving at faster speeds AND can explain why those temperatures don't matter anymore when the car speed goes to zero.
  11. Stringer
    Stringer New Member
    74
    Finland
    <div class='quotetop'>QUOTE(c4 @ Oct 5 2006, 05:34 PM) [snapback]328422[/snapback]</div>
    Sorry about that. I wanted to include the speed reading to demonstrate the fact that it happens only at slower speeds. Unfortuanlly I dont have two cameras, so I had to move the only one between the two views. Also, keeping the camera longer at one view was a risk because the event was quite short.
    I know, even the manual explains that. Unfortunally I dont have any extra equipment or skill to install the CANviewer even if I did order it. However, I can definently tell if the ICE is ON or OFF in the speeds we are talking about, because when it is ON I can feel some shaking compared to the OFF state.
    A/C doesnt affect, I have tried with and without. EV is a standard at Finland and it sure does turn off the engine.
  12. DanMan32
    3,799
    27
    Tampa Bay, FL
    By then, I am sure ICE was providing power. However, at 15 MPH with nominal SOC, using ICE is very inefficicient and should have been shut down. Even while stopping to pick up my passenger, ICE was still running about 10-20 seconds before it shut down, sometimes with a slight shudder. As I approached my passenger, I was braking, so I was in regen, which also was the case at various points of my travel through the development. They have speedbumps there, so my speed varied from 10-18 MPH. During acceleration, I could see ICE might be used, but I also slowed down at points, long enough that ICE should have shut down but didn't. There is a traffic light about 1/2 mile before entering the development where things might have cooled down some, but then I accelerate to 45 MPH for the 1/2 mile before turning into the development, so all systems should be sufficiently warm.
    But remember, it all has to do with emissions, and we can't always tell when conditions are not sufficient for proper emissions control
  13. Stringer
    Stringer New Member
    74
    Finland
    <div class='quotetop'>QUOTE(eagle33199 @ Oct 5 2006, 04:05 PM) [snapback]328379[/snapback]</div>
    Im affraid it is also impossible for everyone else except the actual designers of this car. The car was at the dealer today. Primaly it was there because they had to change one leaking shock damper, a malfunctioning side mirror heater and a bad windshield washer, but I also complained about this engine problem and naturally they said they weren't able to even reproduce the whole situation.
  14. Stringer
    Stringer New Member
    74
    Finland
    <div class='quotetop'>QUOTE(DanMan32 @ Oct 5 2006, 06:50 PM) [snapback]328458[/snapback]</div>
    To me it doesnt sound very emission frienldy to keep the engine ON without doing anything with it. Afterall, it is the component that produces those emissions. Sure I can understand it stays on if something has to be heated, but then it shouldn't turn off virtually instantly (and every time) after the speed goes to zero. My logic says that there is small possibility that the car is trying to predict what I might do next and keeps the engine running for that reason, but I think it shouldnt keep doing that incorrect and expensive guessing more than 10 seconds at max.
  15. prev93
    prev93 Member
    63
    Califon, NJ
    <div class='quotetop'>QUOTE(DanMan32 @ Oct 5 2006, 09:58 AM) [snapback]328401[/snapback]</div>
    Gee, you must be having a worse problem with global warming where you live. 180 degrees is pretty warm!
  16. Tideland Prius
    16,597
    Stringer, try this next time.
    When you're cruising at a slow speed (such as that 16km/h shown in your video), give the accelerator a jolt, jab it and let the engine rev up. After that, see if the engine shuts off.
    Why? Because on my route home, there's a 1-2 km stretch of very slight downhill where I can glide and boost my mpg like there's no tomorrow. However, on occasions, if it's cooler (esp. since my commute to school is only 14km one way), the engine doesn't have much time to warm up (except on a 4km stretch of 80km/h highway). In this case, the engine will still run during that particular stretch of road (but because I'm doing 40-50km/h, it'll ready 1.5L/100km or 2.x rather than the 5.3 shown on yours). In that case, sometimes I'd jab the accelerator, let the engine rev up (and gain a bit of speed) then feather it again. That usually coaxes the engine to shut off without resorting to the EV button.
  17. Proco
    Proco Senior Member
    2,570
    172
    28
    The Beautiful NJ Shore
    <div class='quotetop'>QUOTE(efusco @ Sep 30 2006, 11:33 PM) [snapback]326332[/snapback]</div>
    Question about this specific to my situation. When I'm driving local roads to get to the highway before/after work, I've been able to deadband (complete with impg of 99.9). But when I get to a stop light, the engine shuts off.
    So, is the engine running, but no gas being used? I'm confused. http://www.thehealthymom.com/wp-content/plugins/more-smilies/maidacollection/do not know.gif
  18. Stringer
    Stringer New Member
    74
    Finland
    <div class='quotetop'>QUOTE(Tideland Prius @ Oct 5 2006, 11:05 PM) [snapback]328604[/snapback]</div>
    Heh, do that on the parking zone and you find yourself soon paying someone's crashed car :) While Prius might not have fastest acceleration when measured from 0 to 60mph, I think it is quite fast at the slower speeds due the good torgue value coming from the electrical motor. On the otherhand, the acceleration is very smooth and can be easily controlled. However, here is a clip that shows how the problem shortly occurs, then it actually uses the ICE due a hill it has to climb and then falls again to "the ICE running without a reason"-state.
    I try to remember your hint when the state comes next time and there is some room to actually do it.
  19. eagle33199
    5,122
    268
    2015 Prius v wagon
    Finally found a place to link to... check out the 5 stages of prius hybrid operation:
    http://priuschat.com/lofiversion/index.php/t13519.html
    It's clear that you're in Stage 3:
  20. Stringer
    Stringer New Member
    74
    Finland
    <div class='quotetop'>QUOTE(eagle33199 @ Oct 6 2006, 12:13 AM) [snapback]328644[/snapback]</div>
    Yea, the situation sounds like it. But im not convinced yet about my case that it really should be in stage 3. It says the car goes to stage 4 in full stop, but it doesnt say when it falls back to stage 3. On my route, there was a traffic lights when my car stopped, so according to the document it should have been in stage 4 right? Well in either case, I think I start investigating possibility to measure the temperature that affects to the stages. Does anyone perhaps know, where the temperature should be measured under the hood to get a value that correlates with the spesification somehow?
