charging block: stay or go
Discussion in 'Prime Plug-in Charging' started by CINQUIRY, Jun 16, 2020.
  1. CINQUIRY
    CINQUIRY Junior Member
    24
    Little Rhody
    2025 Prius Plug-in
    SE
    On 2020 prime: is it recommended to keep block plugged into 110 wall socket. Is there any harm in keeping it the wall. Or should it be removed after each charging session.
  2. CINQUIRY
    24
    Little Rhody
    2025 Prius Plug-in
    SE
  3. schja01
    schja01 Senior Member
    1,841
    1,226
    Chicagoland
    2024 Prius
    Limited AWD-e
    I keep mine plugged in as do most. Short of a lightning hit you should be ok. That said I do have a whole house surge suppressor. Can’t be too careful.
  4. Salamander_King
    Salamander_King Senior Member
    11,023
    8,962
    New England
    No need to unplug. I have mine plugged to Kill-o-watt meter which is plugged to the wall 24/7/365 for 3+ years now. One thing is that having EVSE (the fancier name for the charging cable) plugged to a wall outlet consumes about 0.01kWh/day of electricity.
  5. bisco
    52,284
    none at all. plugging and unplugging wears out the socket and plug
    Raytheeagle likes this.
  6. Salamander_King
    11,023
    8,962
    New England
  7. Rob43
    Rob43 Senior Member
    1,373
    1,049
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    My Toyota 120 volt EVSE unit has been plugged into my 240 volt outlet for Over 11,000 hours.... Works Perfectly.
    Rob43
  8. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,520
    Bay Area, California
    2019 Prius Prime
    Not to be specific:p.
    Anything special about March 16, 2019:whistle:?
    Or just like 458 days as a round number (y).
  9. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    I can't remember if I plugged into 240v at the end of Feb. or the beginning of March 2019. :coffee:
    So "roughly" 11,000 plus hours on the Toyota 120v EVSE.
    Rob43
  10. PiPLosAngeles
    PiPLosAngeles Senior Member
    1,551
    724
    Just to add to the chorus, the charger that came with my 2012 PiP has been plugged in continuously (other than occasionally moving it or such) since November of 2012. I use it to charge both the 2012 PiP and the 2018 Prime. No issues yet.
  11. CINQUIRY
    24
    Little Rhody
    2025 Prius Plug-in
    SE
    Thanks everyone- put a surge protected Leviton dual wall switch ~ 20 bucks.
  12. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    A dissenting voice here. In lightning central where I live, I always unplug when not charging. Also, I've noticed on my meter that the EVSE consumes a surprisingly large amount of power when plugged in and not charging. About like a night light. It'll add up. But mostly I unplug in case of lightning.
  13. Salamander_King
    11,023
    8,962
    New England
    My kill-a-watt meter connected to the EVSE tells me that OEM EVSE consumes 0.01kWh/day. Even at a very high electricity rate at my house, it is 0.21 cents a day, or 77 cents a year. At your rate, it's less than half of that. I would not sweat on that.;)
    schja01 and Rob43 like this.
  14. Hicksite
    Hicksite Member
    176
    2020 Prius Prime
    Ditto.
  15. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    Ditto on the fact that the OEM EVSE consumes 0.01kWh/day to operate (which is literally nothing), or that you unplug it for lightning ?
    Rob43
    #15 Rob43, Jun 17, 2020
  16. jerrymildred
    11,517
    14,157
    Tampa, FL
    My L2 charger pulls about 4 watts IIRC, which comes to about 35 kWh per year. Rounding it to 10 cents/kWh, is about $3.50 per year. Not much at all. Till lightning takes it out ... or worse yet, gets through it to the car it it's charging in a storm. I'm not saying anyone has to unplug it. I'm saying I unplug it.
    Salamander_King likes this.
  17. Salamander_King
    11,023
    8,962
    New England
    I guess, I should unplug ALL electric appliances from the outlet during a lightning storm, but I don't. In case of a direct hit, wouldn't the main service plate get fried first? Does the whole house surge protection device really work on such direct hit?
    jerrymildred likes this.
  18. jerrymildred
    11,517
    14,157
    Tampa, FL
    Hard to say. Lightning is pretty unpredictable. One time I got hit and it took out the garage door opener and the answering machine. (Obviously a long time ago. LOL!) Another time was down in Honduras at the radio station. It hit so close that my wife said she saw "fire" come out of an outlet in the kitchen and we both heard the next door neighbor scream. But no damage at the house. However, it took out the transceiver for our studio-transmitter link (STL) about 150 yards away and took us off the air.
    My TV and other entertainment stuff is on a 1,000 kVa UPS that has surge protection. Computer is on another 800 kVa UPS with surge protection. So far, so good. But I figure that if either gets blasted I have a good excuse to get an upgrade. :D
    Andyprius1 and Salamander_King like this.
  19. Salamander_King
    11,023
    8,962
    New England
    I no longer have desktop computers, except for a very old all-in-one machine. All the others are laptops and tablets, a total of over 10 devices, that are not connected to the wall all the time. TV and other pieces of audio/video equipments are connected to a surge-protection strip but I am not sure how protective those strips are against lightning. Probably the most expensive electrical appliance we have connected to the wall 24/7 is not the PRIME's charge cord, but any one of the kitchen appliances, range, refrigerator, dishwasher, cloth washer, and dryer. There is also an electrically controlled boiler which would cost over $10K to replace, but with the lightning surge, I would think only electrical parts are prone to damage which would be much cheaper to replace.
  20. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    I don't mean this as a cavalier statement.....but it anything in my home gets hit by a lightening strike (I've never experienced one) I will just upgrade the items that gets hit.
    Rob43
