Can I borrow your battery charger/balancer/reconditioner?
Discussion in 'Gen 2 Prius Main Forum' started by JamesG123, Jun 3, 2020.
  1. JamesG123
    JamesG123 Junior Member
    72
    Venice Beach, CA
    Albert, This is amazing!
    1) Why do you even need to add heat sinks to the chargers? Can’t you just keep them separated by a few inches? I assume they were designed for use without a heat sink. Is that correct?
    2) About using the Prius’ fan: why do you need a special wiring harness? Can’t you just tap into the two wires that go to the fan and give it 12 volts? Would there be a problem with the power going upstream of the fan? If so, could you just add a toggle switch to the positive wire upstream of where are you tap in to deactivate it?
    3) Is the input voltage 120VAC? I noticed there’s a big range that can be used for those chargers.
    4) As you monitor your battery bank voltage, at what point do you turn off the chargers?
    GREAT information!! Those chargers are WAY cheaper
    than any option I’ve seen so far! They are the perfect amperage also!
    Thank you so much for all of this great information!
    #121 JamesG123, Jun 17, 2020
  2. JamesG123
    72
    Venice Beach, CA
    $1000 is a great deal!
  3. Albert Barbuto
    106
    98
    Northeast USA
    James, I'm glad all this info was useful to you. :)
    (1) Chargers were designed to operate without heatsinks. Yes, space them apart!
    (2) I've never fiddled with the Prius fan, but you are correct. Give it 12v. A line break switch may or may not be needed.
    (3) 120v is the input voltage.
    (4) The entire pack will slowly climb towards 240v. It will stop rising, then may hold, or even drop a volt or more. Pack is done after this happens. At the gentle 350ma rate, do not rush letting the pack completely fill. Now before using the car, I like to bring the pack back to the original voltage I started with, using light bulbs. 120v bulbs must be in series, to handle the 240v pack. Do not drive the car with a 100% charged pack. The battery computer does not know the pack is fully charged. It will attempt to put more in, which has destroyed packs. Not good....
    alftoy and JamesG123 like this.
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,803
    2017 Prius c
    Ignorance is bliss.
  5. dolj
    dolj Senior Member
    8,450
    4,291
    Wellington, New Zealand
    It truly is.
    srellim234 and Raytheeagle like this.
  6. JamesG123
    72
    Venice Beach, CA
    After a lot of confusion and fact checking I went ahead and ordered those three chargers that you recommended. It seems like a great plan!
    Nice photos of your discharging set up! It’s hard to read the multimeters though. I’m assuming one says 205V and the other says 0.9A? Is that showing how far you discharged your battery bank?
    #126 JamesG123, Jun 19, 2020
  7. Albert Barbuto
    106
    98
    Northeast USA
    smaturin, alftoy and JamesG123 like this.
  8. JamesG123
    72
    Venice Beach, CA
  9. JamesG123
    72
    Venice Beach, CA
    Hi again, i’m at Home Depot right now trying to get lightbulbs, but I don’t know the wattage that I should be looking for. What do you recommend? Thanks
  10. AzusaPrius
    AzusaPrius Senior Member
    2,184
    921
    Not wasting your time making this junior high project.
  11. sam spade 2
    7,035
    2,803
    2017 Prius c
    I second that suggestion.
    For the second time, I think.
    AND......
    It may not be possible to find new conventional 120 V incandescent light bulbs anymore.
  12. JamesG123
    72
    Venice Beach, CA
    I built a battery charger AND discharger similar to Prolong for less than $100 thanks to the information provided by @Albert Barbuto!
    By charging and discharging a few times I was able to increase my gas mileage from 33mpg to 37mpg. The battery bank holds a charge wayyyyy longer and the Doctor Prius app shows an improvement from about 50% life expectancy left to over 100%!
    My fuel mileage is only 37mpg because when my car originally threw codes about the battery bank going bad I replaced one module which through off the balance of the whole bank… If I would have used a charger like this before replacing anything I probably would have fixed it AND improved my gas mileage from about 43mpg to 47mpg.
    At this point it looks like I need to balance each individual module so that they all have the same amp-hours and match them up so they all have the same internal resistances. I calculated my annual driving and I would only save about $150 per year in fuel by fixing it, so I’m going to leave it as is. If I were to fix it it would cost about $200 for an advanced hobby charger that charges and discharges four modules at a time, but I’m not going to bother anymore.
    At least now I have my charger which I can use a couple times per year to extend the life of my battery bank.
    Here’s what you need:
    - BE CAREFUL! Even after you take that orange clip out of the battery bank you need to take a multimeter to the battery output terminals that you will tap into to make sure that they are actually dead. Sometimes they are still live!
    -Three of these little chargers wired in SERIES to have a 300V output at a constant 0.350Amps. The inputs should be wired in parallel because they need 120VAC.
    -A flat board to mount these little chargers onto. Space them out so they can cool, but it’s really not like they get that hot.
    -Some lightbulb outlets for mounting on the board which will be your discharger setup. You really only need two wired in series so that your battery bank doesn’t blow the lightbulbs, but I mounted 4 and wired them up different ways, but it didn’t improve anything. Leviton Plastic Keyless Lamp Holder-R50-08829-CW4 - The Home Depot
    - INCANDESCENT bulbs. Two 200W bulbs, two 75W bulbs and two 25W bulbs. Here in California I couldn’t find 75W lightbulbs so I used 40W bulbs instead. You should get one or two extra 200W bulbs because they like to blow since you’ll be using them when your battery bank is fully charged at about 240V.
    -A 25ft roll of 14gage wire that’s rated for 600V from Home Depot. It only needs to have two wires running through it. No need to have that center bare grounding wire like I had. If that’s all you can find and go ahead and buy it. Southwire 25 ft. 14/2 Gray Solid CU UF-B W/G Wire-13054221 - The Home Depot
    - Three pronged plug for 120VAC outlet which feeds your chargers. Two prongs is probably fine also since you won’t be using the grounding wire. Leviton 15 Amp 125-Volt 3-Wire Plug, Orange-R51-515PV-0OR - The Home Depot
    - A bag of wire connectors so you can quickly connect and disconnect wires. From Home Depot. Ideal PowerPlug Orange Ballast Disconnect Discs (5-Pack)-30-1302S - The Home Depot
    - 3 amp fuses and in-line fuse holders rated for 600V. This goes between the battery bank and charge wire you install. This is important because the charge wire that you install will permanently be in your car and if it shorts it could electrocute you or catch something on fire.
    - Wire connector kit that includes butt connectors and ring terminals. Gardner Bender 100-Piece Terminal Kit-TK-806 - The Home Depot
    Wire crimping tool/stripping tool
    - electrical tape
    - Multimeter to monitor charge and discharge voltages.
    To install and operate your charger and discharger follow the instructions here: Our Product Guides | Hybrid Automotive
    To keep your battery bank cool while charging all you need to do is find the two wires that run to your cooling fan which is attached to the duct work on the passenger side and cut those wires, splice into them with a few feet of wire so you can extend it for easy access once your car is put back together (mine can now be accessed from where the 12V battery is located) and use those orange wire connectors to connect and disconnect to the fan. When you are charging all need to do is connect the fan directly to a 12V battery, but not your Prius battery because it will probably die. Ideally you find a 12V power supply, but I don’t know how to guide you on that. Whichever 12V battery you use will need to stay charged for about 24-36 hrs because that’s how long it takes to fully charge your battery and give it extra time to hopefully balance. After doing this, I personally don’t think that it’s possible to balance your battery bank with this kind of charger, but it will definitely add life to it in the form of increased amp hours. To balance modules I think you need to charge them individually and then you are able to collect data and ensure that each module has the same specs before putting them back in the bank.
    Discharging is very tricky with the lightbulb discharger. You cannot actually calculate when you will reach the termination voltage because it does not discharge linearly, so don’t even try it. You’ll have to keep checking on a regular basis. It discharges fairly linearly for the majority of the time and then all of a sudden the voltage will drop off DRAMATICALLY, so you really need to check it often. You don’t want the voltage to get too low because you can risk damaging individual cells within a module because the current can flow backwards. That happened to me once, but seems to be OK. Also, probably no need to charge/discharge more than three times. More than about three times is not recommended because it’s a little hard on your batteries. Most likely you’ll be good to go after about one or two times.
    Try to preserve your connections by not connecting/disconnecting anything under load whether it’s the charger or discharger. Basically you want to avoid sparking so that your nice connections don’t get damaged over time. If any sparking occurs it should be as you screw in your remaining light bulb when activating your discharger.
    All supplies that you use should be rated for at least 300VDC. The closest thing you’ll find in the stores are things that are rated at 600V, so don’t let that throw you off. Just make sure everything is rated for 600V as you make your purchases.
    That’s about it! Like I said, building this charger is definitely worth it if you want to add more amp-hours and probably overall lifespan to your battery bank, but if you need to balance your batteries then I highly recommend going the hobby charger route, collecting data on each module, matching them up a.k.a. balance them and put them back in your pack. There are other posts on that. This charger however is very convenient for being able to quickly connect it without having to take your car apart in the future so that you can continue to extend the life of your battery bank in the years to come.
    Sorry for the crappy photos! I should have taken them when I had everything hooked up.
    #132 JamesG123, Jul 28, 2020
  13. bisco
    52,012
    well done!(y)
  14. dolj
    dolj Senior Member
    8,450
    4,291
    Just one comment on your post, but otherwise a lot of good and useful information there. I too say, "well done, sir."
    Possibly, especially if the module you put in had better capacity than the other existing ones. Equally, possibly not, if the old module had a dead cell, i. e. had a voltage reading 1.2 V (or lower) than the other modules.
    Just to save you chasing ghosts, this line of thought says to me you do not understand what balancing is. If I am understanding you correctly you are confusing capacity with balance.
    CAPACITY
    To do a rudimentary capacity test whereby you can compare all the modules with each other, you just need to do a relative load test. A basic load test is here: HA Battery Module Load Tester User Guide. Note the end voltage must be read before taking the load off. Use a camera to snap the voltmeter at the 120-sec mark, if need be, then record the end voltage in your records from the photo.
    To get the best bang for your reconditioning buck it is imperative that you match capacity as tightly as possible. Your modules need to coexist and play well together. Each of the modules charging and discharging as closely as possible to all the others in the pack.
    BALANCING
    Top balancing is the process of raising each cell in a module to full capacity. Due to the design of the Prius prismatic module, it is not possible to charge each cell individually. Instead, each 6-cell (in series) module or 168-cell (in series) battery is overcharged at a very low Amp rate This is done by over-charging the fuller cells so the emptier cells can "catch up" using a low current (0.05C or 325 -350 mA for a Prius module/battery) over a long time. The over-charge is maintained until the voltage rise is no longer observed over a period of 4 - 6 hours. Using the low current ensures the heat generated by the over-charging cells does not cause heat damage to them, but it is important (imperative, even) to use external cooling to dissipate whatever heat there is. Also, balancing should not be done when the ambient temperature is above 38ºC (100ºF), but as close to 20ºC (68ºF) the better.
    When the top balance is complete, perform a bottom balance. To bottom balance, the module or battery is discharged (ideally 3 times, each time to a lower voltage, but twice or even once will still be beneficial). The first discharge target is 0.8 V per cell (4.8 V/module; 134 V/battery); the second target is 0.6 V per cell (3.6 V/module; 101 V/battery); the third target is 0.5 V per cell (3 V/module; 84 V/battery). After each discharge perform another top balance.
    To finish the balancing process, perform a final top balance.
    Understanding this process, it should become obvious that it does not matter whether you charge a module or a battery of modules. However, there are pros and cons of each method, so what outcomes are desired can influence which method is chosen.
    I hope that clarifies things for you.
    #134 dolj, Jul 29, 2020
    tungm, a.mcintosh, SFO and 1 other person like this.
  15. JamesG123
    72
    Venice Beach, CA
    Thanks! I think we are actually saying the same thing, but I’m simply outlining a process and providing links to those details on the prolong website.
    As you said there are pros and cons to balancing your batteries with one style of charger over the other because when you use the style of charger that I built/prolong then you have less control over the final outcome of your battery bank. If you use the hobby chargers then you can work on each module individually, collect more data and ensure that the entire bank is perfectly balanced.
    To those of you who are having problems with your hybrid battery and trying to decide how to go about fixing it in the most efficient way possible then you should consider:
    Scenario 1- In this scenario you build or acquire a charger like the one I built/Prolong. This requires you to build/acquire the charger, take apart the interior of your car including the drivers side metal cover of your battery bank so you can install your charger wire which will stay permanently installed, and splice into the fan wiring on the passenger side. You should choose this scenario if:
    A. Your car has not thrown codes, but your are starting to notice your battery charge level fluctuate more widely than usual, engine is starting up more often to keep them charged, can’t drive for very long on battery.
    B. Your car recently threw codes about your battery bank and you have not changed any modules yet.
    Scenario 2- You’re probably better off using the hobby chargers (great thread: Gen II Prius Individual Battery Module Replacement | PriusChat), which requires you to take apart the interior of your car, take your battery bank out, disassemble your battery bank, work on the modules individually and generally spend more time if:
    A. You only want to work on your battery bank once and guarantee that you’ll fix it the first time.
    B. If you tried the other charger and your car is still not fixed.
    B. If you replaced one or more modules, drove it around and it’s still not fixed.
    C. If you replaced one or more modules, tried the other charger and it’s still not fixed.
    D. If you are considering cleaning/replacing all the copper plates. (That’s probably not going to fix it and it’s a pain in the butt if doing it while in your car, so you might as well take the battery bank out and completely rehab it.)
    This is the thought process I would follow if I were to do it all over again. These are by no means ironclad rules, but from my perspective they are the most efficient way to go about fixing a hybrid battery problem. Good luck!
    #135 JamesG123, Jul 29, 2020
    Isaac Zachary likes this.
  16. dolj
    dolj Senior Member
    8,450
    4,291
    I don't think we are.
    You need to properly diagnose why it is still not fixed.
    Scenario 3
    Using the right tools like Torque Pro, Dr. Prius, or Techstream, you can pretty much identify if you have modules that need changing.
    You then need to source replacement modules that match the capacity of your existing remaining modules. (This is the hard part!)
    You reassemble the battery with the replacement modules installed.
    You reinstall the battery and use the grid charger and discharger to balance it. Job done.
    #136 dolj, Jul 30, 2020
    SFO and Raytheeagle like this.
  17. JamesG123
    72
    Venice Beach, CA
    I don’t think what you are recommending is a good idea because how can you be sure that the replacement modules that you buy closely match your existing modules? If people go the route you are suggesting it’s more of a gamble because you are suggesting that the style of charger that charges the whole battery bank (the one that I built) will balance the battery pack with the new modules that you just replaced. I would not rely on this style of charger to balance the modules. It did not work for me.
    If any modules are to be replaced I think it’s best to use the advanced hobby chargers, collect data on each module and do everything listed in my Scenario 2. Both of these scenarios were laid out so that people can minimize gambling.
    If someone is OK with gambling they should follow your Scenario 3, because they could save a lot of time, but I personally think that it’s best to minimize the gambling. In fact, everything you are suggesting is exactly what I just finished doing and that’s what led me to give the advice that I just gave with Scenario 1 and Scenario 2. Another advantage to following my two scenarios is that you don’t even need to use the apps because you already know you have a hybrid battery problem and you either solve it or don’t solve it with Scenario 1 and if the problem is more severe then you follow the instructions in Scenario 2 which means collecting lots of data with the hobby chargers which is more accurate than using the apps. There’s nothing wrong with using the apps, but they are not necessary unless following Scenario 3, but I personally don’t recommend that because I just took that gamble and it didn’t work out.
    I won’t be responding on this form for a while. I have a lot of stuff I need to be working on right now. Thanks for the interesting conversation and thanks to everyone who has helped with this project! Good luck to those of you working on your hybrid battery problems!
  18. dolj
    dolj Senior Member
    8,450
    4,291
    At the time of purchase, you can't, and that was my point. BUT ... you can load test them after charging to evaluate whether they are suitable.
    If you evaluate the module(s) there is no gamble.
    Fine, if you want to take the time to do that.
    As above, there is no need for it to be a gamble as long as prudent steps are taken to ensure the replacement module(s) are a good fit with the existing ones.
  19. alftoy
    alftoy Senior Member
    1,132
    517
    Saskatchewan, Canada
    Thank you Albert
    #139 alftoy, Jan 21, 2021
  20. alftoy
    1,132
    517
    Kinda humorous, junior high? Oops!
    Looks to do the same job as the Prolong charging wise for under $100. This video uses 2 for the Honda, will need 3 for the Prius.
    https://www.mouser.com/ProductDetail/MEAN-WELL/APC-35-350/?qs=%2Fha2pyFadujitiXKI3Am59jVMxwoQShdVJfANkhx6fEbVL20LNBrEw%3D%3D
