Aftermarket rear camera aka always on cam Prime
Discussion in 'Prime Accessories and Modifications' started by Sezy, Apr 29, 2020.
  1. Sezy
    Sezy Active Member
    434
    229
    37
    Saint Charles, Missouri
    2020 Prius Prime
    On my 2006 Prius I spliced wires so I can turn on the rear camera at any point while driving or parked, displaying it on the factory 7 in screen. Was great for taking car naps, lunch breaks, double checking before changing lanes. Did not want to attempt this on my 2020 Prime so the search for a similar setup begins. Since it was going to be aftermarket I wanted it to have a DVR feature which limited my options.
    Tried a wifi dash cam that would stream to an old phone but it lagged, needed reconnecting often, and screen was small.
    20200217_114425.jpg 20200217_114430.jpg 20200217_114439.jpg 20200217_114513.jpg
    Next was a motorcycle DVRs. One would not get out of split screen mode, another did not retain camera mirror settings and had a small screen.
    Tried a trucker DVR setup but the camera were way too large.
    A mirror dash cam was not ideal either. I lost my auto dim feature and it covered my homelink garage door buttons a little. Having a front camera on the mirror made it fit awkwardly too. Looked ok setting on the dash but made the front camera useless and you have to scroll up or down to see more of the screen so that did not fit my needs.
    20200318_151648.jpg 20200318_151708.jpg 20200318_151725.jpg 20200318_151935.jpg 20200318_152018.jpg
    Finally came across a trucker DVR system with ok sized cameras, retained settings, 7in screen and was thin. Did several mock ups before taking the trunk apart.
    Now to test where to place the camera so it won't block the OEM reverse or look extra silly. It can be seen a little but blends into license plate on the reverse view.
    20200328_172002.jpg 20200328_172005.jpg 20200328_172021.jpg 20200328_172023.jpg 20200328_172233.jpg 20200328_172402.jpg 20200328_172423.jpg 20200328_172629.jpg
    Took all the trunk plastics out and part of the back seat trim. Ran the camera wire through this spot on the driver side where OEM wires route. Went along the hatch panel. Removed the OEM rear cam, dremeled a notch in it and the trunk for the new camera wire to sneak through. Covered any areas I trimmed with black silicone then zip tied the wires.
    20200403_170102.jpg 20200403_170114.jpg 20200403_170124.jpg 20200403_170130.jpg
    Ran the camera wire along the ceiling trim, down A pillar and out near the driver side access panel. Since I wanted to tidy up my radar and other dash cam hard wiring, you will see lots of extra wires not related to the camera. Ran the power for this kit in with my radar to a fuse tap into the Power Outlet 7.5 fuse. When you do fuse taps on newer Toyotas the fuse cover will not fit back on so keep it in the car. Included is a picture of the interior fuse panel diagram for reference.
    20200428_170640.jpg 20200428_185423.jpg 20200428_190013.jpg 20200428_191527.jpg
    Mounting the screen is done by a bottom and back piece of velcro behind the steering wheel.
    Did not use the provided camera mount and used double sided tape but may change that as headlights are right at it sometimes.
    20200328_195715.jpg 20200330_200931.jpg 20200330_200943.jpg 20200330_200949.jpg 20200330_200953.jpg 20200330_201002.jpg 20200330_201359.jpg
    Plan on adding the front camera to complete the system whenever I feel like going through the firewall or try going under the floorpanel to the front grill.
    Nomina likes this.
  2. Sezy
    Sezy Active Member
    434
    229
    37
    2020 Prius Prime
    Finally got around to running the front camera. Was easier than expected poking through the firewall. Only wanted to do it once so ran extra 12v wires for possible future projects like an led light bar. Helps me know where curbs are or if I can drive straight though in a parking spot on top of being a dash cam. 20200619_170548.jpeg 20200618_214800.jpeg 20200619_164511.jpeg 20200619_184114.jpeg 20200620_152922.jpeg 20200622_110409.jpeg
    Rocketboy235 and Raytheeagle like this.
