87 octane only fuel allowed?
Discussion in 'Prime Fuel Economy & EV Range' started by IABoy987, Jun 26, 2020.
  1. IABoy987
    IABoy987 Member
    209
    85
    Iowa
    2018 Prius Prime
    Finally reaching point to add fuel. Manual says 87 octane but doesn't say anything about blended, so assume 87+ethanol is big no-no (ethanol dissolves plastics to clog most likely).
    What about a few squirts of Stabil after refuel or is that also no-no or has no effect?
    As an aside:
    Found there is a release lever for fuel door but with warning to wait a minute before removing fuel cap due to tank pressuring blowing out fuel to user.
    And there is an emergency release if your charger plug won't release (I assume if you use the plug lock option),
    And finally, when I read the specifications, I was shocked :eek: to learn traction battery is 351volts. I knew it would be high but never suspected that high!! Always learning something new.....
  2. Leadfoot J. McCoalroller
    8,112
    7,591
    Pennsylvania
    2018 Prius c
    Read again/more carefully. I think every Toyota made in the last 10 years allows up to 15% ethanol in the fuel supply.
    Trollbait, MTN and jerrymildred like this.
  3. IABoy987
    IABoy987 Member
    209
    85
    Iowa
    2018 Prius Prime
    However this is a Prime plug in so the fuel does not run down every week or so, but Prime fuel could remain up to a year if all Prime is used for around the town of less than 25 miles/day. Our old Prius fillups used 87+ every week with no ill effect that we could tell, and was never in shop except for those !@##$% impossible headlight change outs :mad: , oil changes and recalls.
  4. Leadfoot J. McCoalroller
    8,112
    7,591
    Pennsylvania
    2018 Prius c
    Yep, it's well covered in many other threads. The bottom line is that all the same fuels are fine that version of the car, it has a system to manage fuel aging but it doesn't hurt if you plan 'portions' relative to your actual consumption.
  5. Rob43
    Rob43 Senior Member
    1,373
    1,049
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    I run 92 or 93 E0 gasoline somewhere between 1/4 to 1/2 a tank as a norm for local driving.
    If I go on a long trip I fill up with cheap/costco 87 E10, then I try to come back home with very little E10 fuel.
    Then I repeat this process...
    Rob43
  6. Salamander_King
    Salamander_King Senior Member
    11,019
    8,954
    New England
    There are no 87 E0 gas in my area. Until very recent, there were no E0 gas, but last year a newly opened CitGo gas station within 20 miles started carrying 93 E0 gas at pump. I go there to buy E0 pure gas, not for my PRIME, but for my lawnmower, snowblower, generator, and other small engine yard tools.
    Tips, jerrymildred and benagi like this.
  7. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    Yep, gotta use the "good stuff" in the lawn equipment !
    Rob43
    Salamander_King likes this.
  8. Rmay635703
    Rmay635703 Senior Member
    2,669
    1,690
    Somewhere in Wisconsin
    2013 Chevy Volt
    Never heard a Prime called that
  9. fuzzy1
    10,516
    Look at the gas cap, it should say how much ethanol content is allowed in this car.
    I thought that it was a federal requirement for all normal consumer vehicles made after some long ago date to be able to tolerate E10. After all, many localities were forced to use E10. And E15 is now approved too.
    Trollbait likes this.
  10. davecook89t
    davecook89t Senior Member
    1,090
    826
    Washington State, Florida
    Four Touring
    If it's really in there for a year, I would think you would want to use some kind of fuel stabilizer, especially if you are filling up with something other than E0.
    How Long Does Gasoline Last? Solved! | Bob Vila
    phlack likes this.
  11. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    Yep.
    "Even in proper storage 87 octane gas can start to degrade in 3 months, 93 octane fuel should last closer to 9 months before degradation is noticeable. Keep in mind that 93 octane fuels are still susceptible to octane loss and vapor pressure decreases due to butane evaporation."
    Octane Stability: High Octane vs Low Octane Fuels - Sunoco
    Rob43
  12. jerrymildred
    jerrymildred Senior Member
    11,517
    14,153
    Tampa, FL
    See the manual, or (as @fuzzy1 said) just open the fuel door for ethanol answers.
    My tank depressurizes faster than the message can appear on the dash. Also, fyi, IMG_2119.jpg
    You need to reread that. It's an emergency release for the charging port door. Not for the EVSE cable.
    There's always stuff to learn about this car. This one might be too much at one bite, but check out the Weber Auto videos on YouTube.
  13. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    It is 87 octane MINIMUM. Nothing wrong with higher octane, just not needed.
    IF you are a person who's driving pattern means that you might not put a whole tankful into it in a YEAR,
    I think I would look for E0 gas (regardless of the octane) AND put in some stabilizer too.
    IF you will go through a tank every 3 months or so, I wouldn't worry about it in the least.
    Neither of those things might be strictly necessary but it won't hurt either.
    TGrracie, davecook89t and MTN like this.
  14. benagi
    benagi Active Member
    525
    280
    Utah
    Here in Utah Costco only sells 85 octane and 91 octane, no mid grade. I’ve been running 85 octane in my prime and also my 2012 Prius V. No problems.
    douglasjre likes this.
  15. sam spade 2
    7,035
    2,804
    2017 Prius c
    Are you in a "high elevation" area ?
    It is typical to sell lower octane fuels in the "mountains"......because higher octane is not needed there.
    Mendel Leisk and jerrymildred like this.
  16. jerrymildred
    11,517
    14,153
    Tampa, FL
    I think @sam spade 2 has it. I notice when we're in CO that the octane is lower engines need less anti-knock at higher elevations.
  17. benagi
    525
    280
    Utah
    Yes, we are at 4300 feet. I had already figured that’s why they’re running a lower octane at Costco.
    Curious if anyone is from the Denver area. What octane are they selling there?
    jerrymildred likes this.
  18. fuzzy1
    10,516
    Is the lower octane specific to Costco? I suspect not, but that it is common to the region.
    I've seen the lower octane in Montana and Wyoming, as well as Utah and Colorado. And it is sold in a few other places too. It seems common at 4000+ feet when far enough away (by old era car fuel ranges) from lower elevations. Though I believe I've seen low octane (maybe 85.5 or 86) down at about 3000 feet too.
  19. benagi
    525
    280
    Utah
    The problem with the Costco‘s here in Utah is they only have the 85 and the 91 octane. They do not sell a midgrade. All the other gas stations do sell a midgrade. Usually 87 octane.
  20. fuzzy1
    10,516
    I don't recall Costcos in any state (Western U.S. and Canada only, I haven't been to any elsewhere) as selling a midgrade. Just Regular and Premium, at whatever octanes are customary their the particular area/elevation.
