P0300 0301 0303 misfire and engine knock problem
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by noctiluca, Apr 10, 2020.
  1. noctiluca
    noctiluca Junior Member
    40
    Vancouver, BC
    2014 Prius v wagon
    running like a dream since i replaced the two bad coils. lets hope it sticks!
  2. noctiluca
    40
    Vancouver, BC
    2014 Prius v wagon
    did not fix :( after everything ive done, she ran perfectly for a few days and then the problems started again, which points to maybe some kind of buildup. now all four cylinders have error codes and i'm losing coolant, super gasoline-y smell when misfiring...maybe i cracked part of the EGR system when doing the cleaning? tried to do a leakdown test but the tester i bought leaked so still trying to do that. otherwise not sure where to look next.
  3. ChapmanF
    15,101
    Leaky leakdown tester. What is the world coming to?
  4. pjksr02
    pjksr02 Active Member
    532
    225
    Connecticut
    Sounds like it's the head gasket, unfortunately.
    If you had damaged the EGR system, you would likely see where coolant was leaking, or could hear where exhaust gas was leaking. Or are you thinking it's possible that coolant is going into the EGR gasses via a cracked EGR cooler--maybe check the egr pipe to see if it's wet. You'd probably see lots of white smoke in this case.
    What codes are you getting? Misfiring on all 4 cylinders?
    Raytheeagle likes this.
  5. feivel
    feivel Junior Member
    43
    I'm dealing with the exact same issue. No remedy yet. Thanks for sharing your efforts!
    Engine rattle at low RPMs with some load, even on startup now. Once the engine speeds up a bit, the issue is gone and there's no detectable loss of power/torque until it's slow again, then I get it again intermittently. Feels like the engine is trying to shake itself off the frame!
    I replaced the spark plugs / coils. Opened up the EGR valve and it moves super smoothly. Removed the the pipe in front of it and it wasn't clogged (had maybe 1mm of carbon buildup). I blew compressed air in while pushing the EGR valve, and it sounds like air moves smoothly, and changes resonant note when I push the EGR valve, so it's not clogged.
    What next?
    My non-Prius car guy is convinced it's the transmission slipping/chattering. But he also thinks that'll be a repair that costs more than the value of the vehicle. I've seen no indication here that it's the transmission and he can't prove it.
    The Toyota dealership wants $400+ just to start to diagnose it.
  6. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    I’d say it’s either a clogged EGR cooler, or the head gasket.
    it’s definitely not the transmission. The Prius uses a very simple but elegant planetary gear set utilizing two electric motors. Basically the only way for them to fail is an electrical short which is very rare.
    pjksr02 and Mendel Leisk like this.
  7. Mendel Leisk
    38,247
    Check/clean the intake manifold too, in particular the EGR passages: large EGR intake passage feeds into four capillaries, one per port.
    Aaron Vitolins and pjksr02 like this.
  8. pjksr02
    532
    225
    Connecticut
    ...and while you have the intake manifold off, put in a new PCV valve.
    How many miles are on the car?
  9. feivel
    43
    @pjksr02 There are 168,000 miles on the car
    Thanks so much for the advice! That's super valuable to hear. I'm so glad it's not the transmission.
    How can I know if it's the head gasket or not? The coolant level was mid-way - haven't been driving it a ton so I don't know if it's eating coolant.
    So my half-way EGR check that showed the valve and front tube just wasn't enough? It sure looked like air could flow.
    Both issues seem like pretty substantial projects. I would love to figure out which problem is causing the issue before I go fixing the one that isn't.
    Aaron Vitolins likes this.
  10. Mendel Leisk
    38,247
    EGR and intake manifold cleaning are not that hard. Head gasket is tough. Independent shops would charge around $2500?
    Leak down test is good to diagnose if head gasket is failing.
    pjksr02 likes this.
  11. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    With the miles it’s a good chance It’s the head gasket. A proper test would be the leak down test, as stated above.
    you might try loosing the cap on the coolant fill reservoir to depressurize the coolant system. Drive around for a bit with the reservoir cap loose end and see if the shaking stops. If it stops that’s a good indication that your head gasket is leaking.
    As far as the EGR cooler I can promise you it has a good bit of carbon buildup at your mileage, so just keep that in mind, not saying it is for sure the cooler but there’s a good possibility
    jzchen likes this.
  12. HaYon Prius driver
    HaYon Prius driver New Member
    Tracy, Ca
    Buy a cheap little borescope and remove the spark plugs and see if there is liquid running down the cylinder wall. Make sure you do this after driving for a while to pressurize the coolant system. I had a similar issue and did all the same steps. I actually missed it the first time because i scoped it when the car was cool. I had a small drip forming on cylinder #2. I could watch it form a drip and then run down the cylinder.
    Aaron Vitolins and Raytheeagle like this.
  13. feivel
    43
    Thank you all sooo much for the advice. I tried opening the coolant tank cap as @Aaron Vitolins suggested, and it worked! After an initial vibration, I was able to drive without more vibrations. Which, while pleasant, is probably a bad sign. Yes? Also, noticed the engine coolant level in the reservoir has gotten low.
    Does that mean it's the head gasket? I have a fellow I typically take the cars to, but he doesn't know the Prius' idiosyncrasies. He doesn't do a leak down test, but he does a pressure test on the coolant system. I left it with him for that, but apparently his equipment won't fit the cap without some magic adapter he doesn't have yet.
    Is it worth buying a leak down tester and figuring out how to test it myself? Is it most-likely the head gasket?
    What do you recommend at this point? The car has a list of other things it needs (brakes, tires) and I'm debating if it's time to sell it vs fix it. The laundry list seemed reasonable, but probably not on top of a multi-thousand-dollar engine repair. How do I know when it's time to cut bait?
    I'll still be driving another Prius, even if this one finds a new home.
    #33 feivel, Jun 24, 2020
  14. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    I would definitely say that’s your head gasket, especially since it’s so common. Not worth spending the money for the official test. With the cap loose, it will stop the leak for now, but the coolant level will keep going down, due to it not being a pressurized system now. So I’d top it off maybe once a week depending on how much you drive.
    it might be time to sell this Prius, depending how much you like this Prius. Or maybe buy a new one, I’m sure you could get a pretty good deal.
  15. jzchen
    jzchen Newbie!
    3,296
    1,006
    Arcadia, CA
    K-Seal?
    moto g(7) power ?
  16. noctiluca
    40
    Vancouver, BC
    2014 Prius v wagon
    i think feival's situation is a bit different to mine. i had zero coolant leaks until i did the egr/intake system clean, now i have an enormous coolant leak. timing is a little too coincidental.
    my cylinder codes switch around but are mostly 1, 3 and multi.
    another fun symptom: misfire goes away completely for a few cycles after disconnecting the battery, so there must be at least some electrical/computer aspect to this.
    still diagnosing :(
  17. noctiluca
    40
    Vancouver, BC
    2014 Prius v wagon
    yup, this is what i was thinking. definitely lots of white smoke. havent had time to get back into it yet but when i do ill look at the pipe for signs.
  18. Tim Jones
    Tim Jones Senior Member
    1,687
    547
    SE Texas
    2011 Nissan LEAF
    And people give me a hard time when I say don't purchase a used Gen 3.......
  19. noctiluca
    40
    Vancouver, BC
    2014 Prius v wagon
    confirmed head gasket via hydrocarbon leak test (why dont more of you recommend this? easiest way to diagnose considering the location of plugs!) and it blew completely while warming it up to do a confirmation test. engine is toast. f my life and this car.
  20. noctiluca
    40
    Vancouver, BC
    2014 Prius v wagon
    DONT BUY THIS CAR!!!!!! i tried to do due diligence on reported issues and this was supposed to be the golden model year, but didnt check the forums here. couldve saved myself a lot of money and heartache. and of course a new motor for the V is 2k instead of $500 like a regular prius. kdjhskdjhkjshehkjhwekjhe :( :( :( :(
