87 octane only fuel allowed?
Discussion in 'Prime Fuel Economy & EV Range' started by IABoy987, Jun 26, 2020.
  1. benagi
    benagi Active Member
    525
    280
    Utah
    So it is not just Utah. It is probably all the Costco‘s across the US that’s sale only Regular and premium?
  2. fuzzy1
    10,039
    Yes, as far as I have seen. Which isn't the whole country.
    The same is true at the unattended agricultural fuel station where I fill up dad's farm-ranch vehicles, as well as our non-farm vehicles when the Bank of Dad is paying. (Farm and non-farm vehicles are tracked and reported separately for business fuel tax reasons, with license plate codes entered to unlock the pump.)
    #22 fuzzy1, Jul 2, 2020
    Rmay635703 likes this.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,782
    2017 Prius c
    That really is NOT a "problem".
    Mid-grade is pretty much a joke.
  4. Rmay635703
    Rmay635703 Senior Member
    2,577
    1,601
    Somewhere in Wisconsin
    2013 Chevy Volt
    Our “Mid-grade” is 88e15 and 5-30 cents a gallon cheaper than 87e10, no joking needed.
  5. sam spade 2
    7,035
    2,782
    2017 Prius c
    That's because it has 5% more ethanol.
    And the resulting one point jump in octane really isn't significant.
    I would be willing to venture a guess that it isn't like that at ALL stations in your area........because if "blender" pumps are in use, that wouldn't work at all.
  6. DavidA
    2,325
    1,811
    Chicago western burbs
    Gas cap. Gas cap. I should go find my Prime manual to look that up. Hmmmm. Gas cap. I must have one of those, right?
    jerrymildred, benagi and fuzzy1 like this.
  7. fuzzy1
    10,039
    Check the other side. And you might need to dig through the Owner's Manual to find the hidden release lever.
    Do you remember how and where you plugged in to recharge your first Prius? I know that was along time ago, but if you can dredge up old memories, it should be about the same on this car. ;)
    benagi likes this.
  8. DavidA
    2,325
    1,811
    Still confused. I'll keep looking.
  9. Tideland Prius
    16,065
    :LOL::LOL::LOL:
    Raytheeagle likes this.
  10. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,476
    Bay Area, California
    2019 Prius Prime
    jerrymildred likes this.
  11. Trollbait
    11,314
    Car gas tanks are far better sealed than the plastic cans for lawn mowers. Evaporation and oxidation are what causes gas to go bad. Those aren't going to be happening in a tank sealed tight enough to pressurize. If you aren't using gas fast enough in a PHEV for the computer's liking, you should get a warning to had fresh gas, and if that isn't enough, the car will start burning it to get rid of it.
    So Stabil isn't required.
    That link is talking about gas stored in plastic cans for power equipment. Those cans can be leaky to the atmosphere, specially as they age, allowing a regular change over of air. Which means anything evaporated from the fuel into the headspace of the can can get out, and fresh oxygen can get in to degrade the gas.
    From the link in your link;), "Perfectly stored, most race fuels will last more than a year. If you are not sure you can use the fuel up within 2 years, add a quality fuel stabilizer to the fuel as soon as you purchase it." Accounting for the lower quality of pump gas, you could probably store gas for up to a year without needing a stabilizer, if properly stored; a modern car gas tank counts as proper storage.
    Gas being stale doesn't mean it can't be used. By design, cars can safely run fuel of octane lower than their requirement. Efficiency will be lower, and the engine will run rougher. Adding fresh gas will improve those.
    Costco probably decided to save money by not installing blender pumps or a third storage tank. Or they wanted to force turbo cars there into buying premium.
    If you ever need midgrade, and can't get it, it is 2 parts premium to 10 parts regular. mixing it yourself will likely be cheaper than buying from a pump.
    Wish we had that while I had my turbo Sonic.:(
  12. Rmay635703
    2,577
    1,601
    2013 Chevy Volt
    no not every station but the ones with favorable pricing all have e15 in place of the mid grade
    All that is needed to support every fuel octane/ethanol content is a simple 3 tank stack As follows
    (most stations these days have 4 tanks)
    85e0
    91e0
    E85
    Blending between these Three different fuels can provide
    87e10
    89e10
    93e10
    88e15
    90e15
    E85
    87e0
    91e0
    It’s unfortunate that few stations carry all the grades anymore
    Most are carrying the following
    87e10
    88e15
    91e0
    E85
  13. sam spade 2
    7,035
    2,782
    2017 Prius c
    Not entirely.
    Some of the deterioration is due to impurities and additives breaking down just due to age......and heat.
    Gas stored in a perfect vacuum will still go bad eventually.
  14. IABoy987
    IABoy987 Member
    180
    76
    Iowa
    2018 Prius Prime
    Took a road trip that got the fuel meter to about quarter full. Since we use Prime for around town and recharge nightly, we refilled with 3 gallons of 87 fuel to bring up to about half full tank.
  15. eatriceyo
    eatriceyo Member
    45
    32
    Honolulu
    I mainly pump 87 at Costco and have no problems ever.
  16. m8547
    m8547 Senior Member
    927
    615
    Colorado
    2018 Prius Prime
    Regular is 85 at all gas stations in Denver and everywhere to the west of that in Colorado. Not sure about the eastern plains ("west Kansas"). I use nothing but 85 in all my vehicles, and I've never had a problem at 4,000 feet or higher. There's about 15% less oxygen at 5,000 feet, so a NA engine will make about 15% less peak power. Worst case is on top of 14'ers, there's about 42% less oxygen. I often see manufacturers doing high altitude testing in Summit County and on Pikes Peak.
    If I had a turbocharged or supercharged car I wouldn't run less than the recommended octane at any altitude.
    benagi likes this.
  17. David9962000
    David9962000 Member
    139
    66
    2020 Prius
    Intersting info
  18. m8547
    m8547 Senior Member
    927
    615
    Colorado
    2018 Prius Prime
    He seems to be basing the video on one or two fairly old studies about octane requirement vs altitude. I wonder if manufacturers have newer (proprietary) data? It seems like the results would be specific to each engine design.
  19. sam spade 2
    7,035
    2,782
    2017 Prius c
    Ford cautions you to not use 85 in their trucks. Makes sense since trucks work harder.
    Even Ford might not have a similar recommendation for the engines used in other types of vehicles.
    Wild assumption made by a "self appointed expert".
  20. m8547
    m8547 Senior Member
    927
    615
    Colorado
    2018 Prius Prime
    Some F150s have turbo engines, so using 87 minimum is definitely a good idea. If they don't make a separate manual for each engine, then it is easiest to put the same warning in every manual.
    Most other cars recommend 87 octane in the owners manual, because that's what they test with and that's what's available in 80% of the US. But that doesn't necessarily mean using 85 at high altitude will cause any problems. Manufacturers do high altitude testing, but specifically testing for minimum octane vs altitude might not be worth it. It would be interesting to know if they ever use 85 octane during their high altitude testing.
    So using 85 is at your own risk. But I've never seen or heard of a problem with it in a naturally aspirated car above around 4,500 feet.
    If anyone has data on modern cars that shows otherwise, I will gladly change my mind. For example dyno runs with 85 vs 87 at 5000 feet showing improved performance on 87, would be the easiest way for the average person to test this.
