how to check plug-in battery health (state of health)?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by fish lab, Jul 4, 2020.
  1. fish lab
    fish lab Junior Member
    17
    Georgia, Tbilisi
    2013 Prius Plug-in
    hello, first sorry if there was thread like this. i search but did not find info about this. is there any software to check how much health left to my li-ion battery? nissan leaf using software LeafSpy can detect state of health, is there any soft like this to check out battery healt?
    my plug-in first showed 14.6ml range, not it shows about 13.1-13.7. i know this is dependes how and where i drive my car, also wheather and temperature matters. my friend hase same plug-in and his range is amazing between 20.5-21.2ml. he has same 1 gen prius plug-in 2014 year model.
    thanks and soffry for my bad english IMG_20200621_213720.jpg IMG_20200621_213743.jpg
    52,286
    no, you would have to get toyota tech stream.
    what are you driving?
    20 is impossible, unless he is going downhill.
    mine started around 16 and is down to 14 on back roads at 30mph with few stops.
  3. fish lab
    17
    Georgia, Tbilisi
    2013 Prius Plug-in
    yes he lives place, when he start drive negins downhill few miles, but when he returns home he muay go same uphill.
    this is his cars screen.
    as he told he drives agresive and has very low MPG. most ofnhe uses HV mode then EV mode.
  4. hieronymous
    hieronymous Member
    154
    92
    Auckland, New Zealand
    2013 Prius Plug-in
    You know that the EV range you get depends on speed, roads, weather etc. You might get as much as the number on the dash, you often will not get as much.
    Your friend's car shows a big number because he drives downhill to start his trip in EV mode, but he will not be driving uphill in EV mode. If he drives on a flat road with a full battery he will not get any more EV miles than you do.
    The number on the dash is a prediction, not a guarantee. Your friend is getting a big prediction from only using EV mode downhill.
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    Well, he might have selected EV mode, but that doesn't mean the ICE won't run. If he drives aggressively in EV, he's turning on the ICE very frequently.
  6. hieronymous
    hieronymous Member
    154
    92
    2013 Prius Plug-in
    Not while he’s running downhill, if his very high EV miles is any indication...
  7. QuantumFireball
    QuantumFireball Active Member
    420
    269
    Ireland
    Just turning on the aircon will reduce the predicted range by about 10% or so. It varies a lot based on previous journeys.
  8. Iain Millar
    Iain Millar New Member
    UK
    Just bumping this thread up, as I still don't get how to check the battery health? Is techstream capable of looking at the individual modules in the PiP Li-Ion battery? Does it even have modules?
    Thanks!
  9. jerrymildred
    11,517
    14,157
    Tampa, FL
    Yes, Techstream will give info on each block. The Dr. Prius app automates things quite a bit for testing your battery and lots of our member use that product. Hybrid battery diagnostic and repair tool for Toyota and Lexus
  10. bisco
    52,286
    yes and yes. it won't give you a health check though, just the actual voltages under load. you will have to interpret the results.
    i have read the u/k dealers do a health check on regular prius?
  11. Mendel Leisk
    41,826
    Some info, and I don’t think it’s unique to Brit’s, it’s built into Techstream:
    Toyota Hybrid Health Check - Toyota UK Magazine
    Ask local dealership if they know about it?
    I’d second @jerrymildred ’s Dr Prius recommendation too. I’ve only done the static test but gives some insight.
    jerrymildred likes this.
