How to make a bluetooth call while driving?
Discussion in 'Gen 2 Prius Audio and Electronics' started by yarzy, Sep 11, 2006.
  1. yarzy
    yarzy New Member
    65
    what about "Dial by name"?
  2. tmgrl3
    tmgrl3 Member
    315
    Anyone else find that Speed Dial is probably the fastest way to make calls???
    terri
  3. Renocat
    Renocat Member
    363
    Rochester, NY
    <div class='quotetop'>QUOTE(yarzy @ Sep 12 2006, 12:07 PM) [snapback]318368[/snapback]</div>
    For me, 2006 package #7 purchased in July of this year, dial by name works when I am driving down the road. It uses the exact steps that are outlined in the owners manual.
    I prefer dial by name, probably because that is what I learned first, I have never used speed dial.
  4. Blue-Adept
    Blue-Adept Active Member
    293
    179
    Grand Rapids, Michigan
    2018 Prius Prime
    OK I found this at Costal Tech - Unlock all bolue tooth options while driving and more.
    Prius - Unlock blue tooth
    <div class='quotetop'>QUOTE(bhaynnes @ Sep 12 2006, 12:02 PM) [snapback]318365[/snapback]</div>
  5. aaf709
    3,862
    2022 Prius Prime
    <div class='quotetop'>QUOTE(Blue-Adept @ Sep 13 2006, 09:44 AM) [snapback]318974[/snapback]</div>
    Unfortunately, according to Coastal's application guide, this won't work on the 2006.
  6. stanleyjohn
    stanleyjohn New Member
    269
    Higganum,Ct
    Just found this thread! I use dial by name and number while car is moving all the time.
  7. Renocat
    Renocat Member
    363
    Rochester, NY
    <div class='quotetop'>QUOTE(stanlwyjohn @ Oct 3 2006, 07:46 PM) [snapback]327595[/snapback]</div>
    Thank you Stan! I was sure I was not the only one that used dial by name while driving. Actually there was another thread going the same time this one was, and I believe Terri did get dial by name working while driving.
  8. PDWadler
    PDWadler Prius (and Cubs) fanatic
    Chicago
    OK, I know this is probably a stupid question, but how do you enter numbers into the Speed Dial buttons? (I have a 2006 #7)
  9. Renocat
    Renocat Member
    363
    Rochester, NY
    <div class='quotetop'>QUOTE(Faygelah @ Oct 5 2006, 06:49 PM) [snapback]328679[/snapback]</div>
    I think if you go to a contact you can assign a speed dial number to the contact...you must be stopped to do this.
  10. Kev1000000
    Kev1000000 New Member
    271
    Livonia, MI
    probably a dumb question, but is the dial by voice option on an 04?
  11. PDWadler
    Chicago
    How do you add the voice tags to the phonebook entries so you can dial by name?
  12. brjacobso
    brjacobso Junior Member
    17
    San Diego
    when you go to an entry and press "edit" keep pressing the down arrow on the scroll bar on the right. I think it's the last option, but it's on the last page of that options screen.
  13. equistroke
    equistroke New Member
    Anyone else having problems with the voice recognition adding additional (as in not spoken) numbers in the dial by number mode? Even when I dictate each # individually and it repeats back to me, when I finally send out the call with all the numbers, Jill adds extra/additional digits I never said.
  14. ramarren
    ramarren New Member
    96
    San Francisco Bay Area, California
    <div class='quotetop'>QUOTE(Taco Mel @ Sep 11 2006, 08:54 PM) [snapback]318133[/snapback]</div>
    911 and the local Police Emergency numbers are the very first things I entered into the Speed Dial catalog.
    I try not to use my phone while driving ... It's a distraction and unsafe on that count. Seventeen speed dial numbers, and voice dial by number, is more than enough for any call I might need to initiate while in motion.
    It's a car, not an entertainment/communications bubble. ;-)
    Godfrey
