Tire Suggestions
Discussion in 'Gen 3 Prius Main Forum' started by 12PriusTN, Jul 3, 2020.
  1. 12PriusTN
    12PriusTN New Member
    Nashville, TN
    Hello Prius Chat
    It is getting close to time to purchase new tires for my 2012 Prius Five
    I am a sales Rep that covers TN/KY/MS/AL so needless to say I drive a LOT
    I purchased my current tires at Discount tire in October of 2018 with 44k on the car and now i'm almost at 89k - I am not extremely happy with this performance considering how much the tires were
    The current tires are the Michelin Primacy mxm4's
    My models size is 215/45-R17 17 wheels
    Please let me know your suggestions
    thanks!
    #1 12PriusTN, Jul 3, 2020
  2. Tideland Prius
    16,017
    What are you looking for in a tire? I assume long wear since you cover several states but anything else?
  3. lrisius
    lrisius Member
    120
    56
    Illinois
    2015 Prius v wagon
    Take a look at the General Altimax RT 43's. They're about $96 on Tirerack.com. Rate highly for grip in wet and snow and are warrantied for 65k miles. I've had a set for a couple of years that now have about 40k on them and they look like they will be good for at least 60k, maybe more.
    Here's an old thread about them:
    General Altimax RT43 -- review | PriusChat
  4. 12PriusTN
    Nashville, TN
    Tire life is the most important thing. With all of the driving I do I would like to minimize how often I buy tires. I treat my tires well with rotation and balancing them when they need it. If it helps with gas mileage that’s a plus but it’s not as important to me as how long they last.
  5. Tim Jones
    Tim Jones Senior Member
    1,669
    546
    SE Texas
    2011 Nissan LEAF
    I have M Defenders from DT with almost 40,000 and they look Great... lot's of tread... but I do rotate my tires at least four times a year.
    SCdave likes this.
  6. KennyGS
    KennyGS Senior Member
    1,243
    1,044
    Keystone State
    From the Tirerack
  7. Montgomery
    Montgomery Senior Member
    2,254
    2,233
    Orange County, CA
    I just purchased the Bridgestone Turanza QuietTrack for my Prius. Stock size, on sale at Firestone for $104 each. For the record, they are much quieter than the Goodyear tires that came with the car.
  8. tvpierce
    tvpierce Senior Member
    949
    878
    Maine
    2013 Prius v wagon
    FYI: Those are the wrong size tire for your car. They should be 215/50-17.
  9. Mendel Leisk
    38,106
    I think you've got a regular Prius (level 5 with 17" rims and various other options), not the larger Prius v, that was introduced in 2012?
    With 45k miles on the Primacies you're not happy with them, their performance?Can you give more detail? What's their tread depth currently? Wear is even, what's their condition? How about mpg?
    I switched to the same tires, spring before last, from OEM Michelin Pilot hx MXM4. Found the Primacies quieter (which is fairly typical, for any new tire), the ride a bit cushier. They feel fine, steering feels good, cornering uneventful.
    One negative: mpg initially took a big dip, and still is off a bit.
    #9 Mendel Leisk, Jul 5, 2020
    Bay Stater and tvpierce like this.
  10. tvpierce
    949
    878
    Maine
    2013 Prius v wagon
    In which case, my post above about incorrect tire size is, well, incorrect. The size I mentioned is for the 17" wheels on the V wagon.
  11. SCdave
    SCdave Junior Member
    LA/OC
    I'm on my 2nd set of 15" Michelin Defender T+H on my 2015 Prius.
    First set of Defenders lasted 67K miles and had 5/32nds left on them. Was on track for hitting the 80K warranty rating. Unfortunately picked up a large screw in sidewall of one so replaced all 4.
    I only drive dry/wet in California with occasional light snow in mountain passes. Defenders have lowered my Mpgs a bit but they handle great....for a Prius. Could get a bit better handling with a Summer Tire in California but Defenders have been a nice compromise between Mileage Rating of 80K and handling for an All Season tire.
    I also rotate/balance about 3-4 times a year and keep pressure at 38 psi on all four.
    Waited for Costco to put on Sale and price matched over at America's Tire.
    Montgomery likes this.
  12. Tim Jones
    1,669
    546
    SE Texas
    2011 Nissan LEAF
    I have them on my Previa, Camry and Prius v.
  13. Mendel Leisk
    38,106
    Sadly Defenders don't come in 217/45R17. :(
  14. 12PriusTN
    Nashville, TN
    My door panel says P215/45R17
    My from tires are currently at 5/32 and back are 4/32
    I was looking at the Yokohama Avid Ascend LX but am really open to suggestions. Given the time and milage on my current tires I am not extremely satisfied with the life of the current model im using
  15. David9962000
    David9962000 Member
    139
    65
    2020 Prius
    Maybe downsize to 15", they would last longer and more comfortable. Just get a LRR tire. Used 15' are a good deal.
  16. Superleaf444
    Superleaf444 Junior Member
    25
    Car stuff is one of the only reasons I have a Consumer Report membership. This is what they suggest fwiw.
    15''
    17''
    #16 Superleaf444, Aug 7, 2020
    2012 Prius v wagon 3 likes this.
  17. Grit
    Grit Senior Member
    6,103
    4,032
    Wilkes Land
    Superleaf444 likes this.
  18. Superleaf444
    25
    Ha, fixed. I didn't have enough coffee today.
  19. Mendel Leisk
    38,106
    Deleted. Thought this was brand-new thread, started repeating myself lol.
    Raytheeagle likes this.
  20. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,474
    Bay Area, California
    2019 Prius Prime
    At least you recognized it;).
    But who reads several posts back:whistle:.
    Keep it fresh(y).
