Complete List of Cars with Rims and Wheels that Fit on Gen2 Priuses
Discussion in 'Gen 2 Prius Accessories & Modifications' started by alfa164b, Jul 6, 2020.
  1. alfa164b
    alfa164b Junior Member
    Sonoma County California
    Hi there--
    Looking to compile a list of cars with rims that fit on a gen2 prius without much modification-- or if modification is needed like spacers then we list those out as well.
    Obviously the most common is FRS wheels. But I am not a pro at that and not sure what spacers are needed.
    How about we start a list that can list out what to look for on craigslist to make these Priuses look nicer.
  2. Trukinbear
    Trukinbear Junior Member
    24
    Klamath, CA
    6Jx15ET45 or 6J16ET45 ... 6 inches wide, 'J' type mounting flange, positive offset 45mm - PCD 5x100
  3. Trukinbear
    24
    Klamath, CA
    Looks like all the midsize GM cars from the 90's on, VW, Subaru, all the Toyotas based on the Corolla etc... a ton of wheels in the junkyard, most of them probably deathly ugly, but still. A very common wheel size.
  4. wufibugs
    wufibugs New Member
    San Diego
    What is the tallest/widest tires that will fit front of the 04
    What is the tallest/widest tires that will fit rear of the 04
    DinoBravo likes this.
  5. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    a lot of discussion here about what fits; i have 215/55R16 and they do rub in the front every so often. a little deeper offset you could go a little bigger maybe without modifying.
  6. Priusjames
    Priusjames Member
    91
    68
    Irvine, CA
    I’m about to add the 1.5” Priusoffroad lift kit to my Gen 2, specifically came here to ask what size wheels/tires people are running afterward.
    Also - is there room to increase wheel size from 15”?
    Im looking for ground clearance and “plus 1 performance.”
  7. 69shovlhed
    2,170
    752
    Delaware
    people been putting 17 and 18" wheels on, but with low profile tires. if you want to run a big knobby tire, you need to keep the wheel smaller. but if you want to run 30 series street tires for that conestoga wagon ride quality, you might could even get a 19" wheel to fit with the lift kit.
    Priusjames likes this.
  8. James Analytic
    336
    52
    Michigan
    I made a video and FB post to store the info I found researching, as I do not prefer to use the gen 2 rims typically unless they are from an indoor kept or southern car. https://www.youtube.com/shorts/6tl5jXYA6Lo
