Prius Cabin Airflow Filter Direction
Discussion in 'Gen 4 Prius Main Forum' started by rspiet, Jul 8, 2020.
  1. rspiet
    rspiet Junior Member
    Highland, IN
    Four Touring
    Hello, I bought an after market cabin air filter for my 2016 Toyota Prius 4 from Amazon. There is an arrow on the filter for direction of airflow. Is the airflow up or down?
    Should the arrow be pointing up or pointing down? I no longer have the O.E.M filter, and I don't think it even had an arrow.
    Thanks for you answer.
  2. Striker325
    Striker325 Junior Member
    25
    24
    Los Angeles
    Check your previous cabin filter. The filter that is in your Prius should also have an arrow
    ONEPLUS A5010 ?
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    From page 302 of the 2006 owner's manual, which should be the same as all Gen 2 filters:
    AzusaPrius and krmcg like this.
  4. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    He's talking about a Gen 4 - his profile is wrong (or he's got 2 PRIUS').
    But the Gen 4 in Australia has it in the Owner's Manual - probably in the USA one too:
    jerrymildred likes this.
  5. Georgios
    Georgios Member
    126
    85
    Chicago
    Some filters don't matter which way the the air flows even if they have Arrow. They are just a mesh element. It matters on higher-end filters that have the charcoal position on one side or like the newest generation of antibacterial green filters on some manufacturers
  6. alanclarkeau
    7,045
    7,593
    For GEN 4 - the Owner's Manual specifies that it go in a particular way.
  7. jerrymildred
    11,517
    14,157
    Tampa, FL
    Oops, he did say 2016. I missed that. Good catch. 2016 is almost certainly the same as the Prime and here it is in my manual.
    krmcg and alanclarkeau like this.
  8. rspiet
    Highland, IN
    Four Touring
    Sorry, I do indeed have a 2016 Prius 4 Touring. I am not sure how to update this on this site. I do not have the filter case, the replacement filter did not come with one. I hope I didn't throw out a necessary part. The new filter just has an airflow indicator. That is why I wanted to know the direction of air flow.
  9. Elektroingenieur
    2,515
    3,287
    Three Touring
    The case is needed for proper airflow and should have come with the car. If it’s missing, you can buy one as a service part, 88899-47090 or 88899-0R010; see catalog Figure 87-14, Heating & Air Conditioning - Cooler Unit.
    alanclarkeau likes this.
  10. rspiet
    Highland, IN
    Four Touring
    Thank you. I threw that out thinking I didn't need it. So much for DIY maintenance.
    krmcg and bisco like this.
  11. Mendel Leisk
    41,821
    Assuming it's the same as 3rd gen, I believe air flow direction is downwards.
    Marcilla Smith likes this.
  12. rspiet
    Highland, IN
    Four Touring
    Thank you. That is the answer to my original question. Have a great day.
  13. bisco
    52,274
    11 posts for a simple answer to a simple question (n)
  14. Georgios
    Georgios Member
    126
    85
    Chicago
    Yes, True, BUT if its OEM or good quality one. Some times i have had amazon/ebay non branded filter that clearhy havo no arrow or its on the wrong side of the charcoal. The important thing is to see as jerrymildred said is the tray arrow for airflow direction
  15. ChapmanF
    18,451
    Some filters will have an arrow that says "FLOW", some filters will have an arrow that says "UP".
    In a Prius, that means those filters should have their arrows point opposite ways.
    Unless somebody tells me Gen 4 is different, all Prii have had downward airflow through the filter.
    There's no law that requires it, but it's also kind of unsurprising, since the air comes in at the cowl ahead of the windshield, and from where the heater is, that's, you know, up.
  16. bisco
    52,274
    same with my central vac. the trouble with upward air flow is gravity
  17. Vman455
    Vman455 Senior Member
    539
    556
    The Middle
    According to the textbook in front of me (Frank White, Fluid Mechanics 8th ed.), the effect of gravity on incompressible flow (e.g. airflow below ~Mach 0.3) can be treated as negligible. You can see a real-world example of this on just about every Shopvac ever, where the motor is mounted on top of the basin and pulls air up and out.
    The two air filters in the Prius are, I suspect, positioned as they are to make dealing with debris easier (which is very much affected by gravity). In the cabin, downward airflow will collect debris on top of the filter, where it can be easily disposed of by taking the filter out since the rest of the ducting is inaccessible. In the engine intake, air is pulled up and through the filter; debris will collect at the bottom of the plastic housing which can be taken out and emptied if necessary and won't affect airflow through the filter. My guess, anyway.
  18. Mendel Leisk
    41,821
    Engine air filter flow is upward, the opposite.
    bisco and Pulse07 like this.
  19. Vman455
    539
    556
    The Middle
    "In the engine intake, air is pulled up and through the filter...."
  20. Mendel Leisk
    41,821
    should have read more carefully. :oops:
