new guy, need help,
Discussion in 'Gen 2 Prius Technical Discussion' started by robert e cook, Jul 8, 2020.
  1. robert e cook
    robert e cook New Member
    mexico mo
    I put a used hybrid battery in and now have no triangle of death but have these lights on the dash and no ready light comes on. What am I doing wrong, I did replace a battery about 5 years ago and but have forgotten what I needed to to to get the car running agian.
    Yes the battery is good and the 12 volt appears to be good, I have double checked all the wiring and made sure I plugged in the disconnect and pushed down.
    Thank in advance.
  2. robert e cook
    mexico mo
    its a 2007 and yes I searched but did not come up with anything.
  3. strawbrad
    strawbrad http://minnesotahybridbatteries.com
    953
    996
    For the first start after disconnecting the 12 volt battery you have to push the start button twice with your foot on the brake.
    AzusaPrius, Raytheeagle and TMR-JWAP like this.
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,097
    5,810
    Columbia, SC
    I think you nailed it..
  5. robert e cook
    mexico mo
    That did not make any difference.
  6. AzusaPrius
    AzusaPrius Senior Member
    1,673
    772
    Try holding your foot on the break for 10 seconds then double press the start button.
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,795
    Clearwater, Florida
    Do you see the icon of a car in the upper left corner of the mfd?
  8. ttou68
    ttou68 Active Member
    340
    198
    You may want to double check that orange plug, I have a feeling it may not have been pushed in and locked down..
  9. TMR-JWAP
    6,097
    5,810
    Columbia, SC
    May I ask how that was determined? I do recognize that you do not have the RTOD, just curious how you know it's a good battery.
    I have an HV battery on my bench right now that, in all appearances, is a good battery. Doesn't even have any electrolyte leaks....but....prior to disassembly, it measures 23+ volts from the (+) main lug to the case and the individual bad module is showing 6.7 volts when measuring to the case. I'm guessing a hidden crack in plastic module case body allowing electrolyte to touch the metal thread insert on the bottom and grounding out. Was bad enough it wouldn't even let the main relays close.
    #9 TMR-JWAP, Jul 9, 2020
  10. SFO
    SFO Senior Member
    5,286
    4,226
    Northern California
    Welcome to PriusChat!!
    Do you have any OBD2 codes (DTCs) that you can share with us here?
