Featured Prius 2011 spitting out reservoir coolant
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Aftab Ak, Jul 12, 2020.
  1. Aftab Ak
    Aftab Ak Junior Member
    46
    Pakistan
    Hi everyone,
    My prius 2011 with 115k miles on it. Check engine light is on with warning light. It stops when I drive it with some other lights on the dashboard gets on. I disconnect the 12v battery then i drive for a minute or so and again all the lights comes on and the car stops, it also spitting out engine coolant reservoir,
    It's been two years and I am fed up with the prius issues, I have changed 4 water pumps in this time. It often turns on check engine light.
    Can the engine heats up with a bad hybrid battery???
    what's the main issue any ideas please help
  2. Mendel Leisk
    41,905
    Engine coolant is coming out where? From under the cap of the reservoir?
    With check engine light there will be codes. Get them read and post? Even a basic obd port code reader should get some. Probably not all the info, but at least a start.
  3. Aftab Ak
    46
    Pakistan
    Well I dont have an obd as I have lost it so unable to get codes, will take it to the workshop tomorrow then will read and post all the codes.
    Not from under the cap of the reservoir but when the cap is off, the coolant comes out like boiling water.
  4. Aftab Ak
    46
    Pakistan
    The car it heated I think but dont know why? Can bad hybrid battery cause the engine to heat???
  5. AzusaPrius
    AzusaPrius Senior Member
    2,232
    930
    Dont unplug battery so codes can remain in memory.
    Leave overnight and should be able to drive until next overheat, it is your waterpump.
    When replacing the waterpump if you dont burp the system there will be more failed waterpumps.
    Aftab Ak likes this.
  6. Aftab Ak
    46
    Pakistan
    It sounds good, I didn't get "burp the system" what does it mean? Please give some details as I have replaced 4 water pumps in the last two years. It's now annoying me.
  7. Trollbait
    12,686
    Burping means getting all the air out.
  8. Aftab Ak
    46
    Pakistan
    Okay great, but I dont understand why my water pumps fails so often infact every 4 to 5 months and it's too much costly. I replaced 4 of them the image is attached
  9. AzusaPrius
    2,232
    930
    After a drive or putting the car in maintanence mode and letting it get to normal temp, then shut it off and open the coolant reseviour and you will hear the pressure escape.
    Do that after each drive and eventually you will get all the air out.
    Sorry you have spent so much money on OEM parts, I put in a cheap $125 aftermarket waterpump and all is good.
  10. Trollbait
    12,686
    Air in the lines can lead to the pump overheating and burning out the seals.
  11. bwilson4web
    16,367
    No, the battery is air cooled.
    Can you post a picture of the problem when coolant is spitting out?
  12. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    May be blown head gasket. What does the oil look like does it look contaminated?
    If you have had some previous bad engine over heats does not take much of that to damage the aluminum head. Before putting any more money in the car get a compression test done on the engine.
  13. Aftab Ak
    46
    Pakistan
  14. Aftab Ak
    46
    Pakistan
    Hi guys, this was the problem the connector was bad, I replaced the connector resacanned the prius the code water pump malfunction disappeared and the car ran fine. But now I have the issue with 12v battery, the car isn't starting the current isn't coming to the car, may be I have a bad 12v battery? Dashboard lights gets dim and getting a constant beep from the 12v battery, help please
  15. edthefox5
    10,096
    4,834
    Clearwater, Florida
    What does that connector lead go to? your seeing a symptom there not the fix there’s a reason it’s burned out whatever it’s powering is bad and pulling a lot of power.
    After fixing that it get a IR thermometer and monitor that plug heat and wire heat if you have no idea what it goes to.
  16. ChapmanF
    18,547
    The idea is it's the water pump connector. :)
    Burned contacts in connectors don't always have to be caused by some other part. They can begin with a bit of oxidation of the contact. That increases its resistance, driving the heat up. The heat accelerates the oxidation, and the process runs away.
    I think there's been at least one other thread recently involving that same connector, which might already have the part number for the correct repair terminal. Otherwise, you can locate that connector in the Electrical Wiring Diagram as demonstrated here and expand to get the repair terminal and splice sleeve part numbers as shown here. Being a non-interior repair, it will involve a sealant-infused shrink sleeve over the splice.
  17. AzusaPrius
    2,232
    930
    Great now charge the battery!!
  18. Aftab Ak
    46
    Pakistan
    Thanks buddy, well I installed a new 12v battery and now it's all okay, but as mentioned above it's the second time it has the bad water pump connector, the plug inside the connector heats up and the code water pump malfunction appears, I need a permanent solution for it, why it gets heated, as the temperature here is about 40 degrees. I drove for about 200kms and it was fine today. Need help for its permanent solution. Thanks all of you for your support and help
  19. Aftab Ak
    46
    Pakistan
    One other thing the water pump is fine means the issue was with connector, why it didn't demage the water pump???
  20. AzusaPrius
    2,232
    930
    You will need a donor plug so start looking for a prius in a junkyard or for parts and cut the plug off and put it on your car.
