Getting close to 120k miles for spark plug change, too many choices...
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jeffrimerman, Jul 8, 2020.
  1. Jeffrimerman
    Jeffrimerman Member
    229
    45
    Pasadena
    Hey guys,
    I see the recommended interval is 120k miles and I'm at 115k so probably a few months out since I'm not driving so much these days. Just wanted to see if anyone was able to avoid tearing apart the entire area around the wipers to get at them. Seems like the only issue might be the length of the coil pack tube thing when you pull it out if there isn't enough play then no way around removing all that stuff. Has anyone had success not removing all that stuff?
    Edit: OK nevermind. I did more reading and found a discussion here so it's not possible. Saw a video of a guy doing it but he had an odd model that allowed it but we need to take all the wiper stuff and cowl off. I'll just do my oil change for now and order some plugs.
    #1 Jeffrimerman, Jul 8, 2020
  2. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    On right driver side yes it is possible to change plugs without wipers off. Be sure to buy non-counterfeit plugs. Do a search and you’ll read the nightmare stories on here.
    SFO likes this.
  3. Mendel Leisk
    41,315
    Yeah I tried: disconnected the coil, pulled it off, lifted up and boink. :confused:
    Grit likes this.
  4. Jeffrimerman
    Jeffrimerman Member
    229
    45
    Pasadena
    I"m gonna change the title and see about what plugs. I went to Rockauto.com and there are too many choices =/. What the heck is ruthenium. Is it made out of someone named Ruth? Bosch and Ruth were the most expensive $10 and $8 respectively. I am seeing some cheap deals on ebay so I see why I need to beware of fakes. Is it best to avoid ebay and just go with a big online store if I'm trying to be a cheap skate?
    SKP SP1029 Enhanced Tapered Ground Electrode w/ Platinum Chip
    AUTOLITE XP5683 Iridium-Enhanced Center Electrode; V-Trimmed Platinum Side Wire; 0.6mm Finewire Design
    CHAMPION 9410 {#22401CK81B, REA12WMPB4} Iridium
    NGK 93501 Iridium IX
    NGK 4912 {#ILKAR7B11} Laser Iridium
    BOSCH 96339 OE Fine Wire Double Iridium
    NGK 93220 G-Power
    AUTOLITE APP5683 Double Platinum
    NGK 92274 Ruthenium HX
    #4 Jeffrimerman, Jul 8, 2020
  5. Mendel Leisk
    41,315
    From the Owner's Manual, worth including:
    Denso SC20HR11
    Except, Toyota has revised the above, to a the slightly hotter:
    Denso SC16HR11
    Purchase from local dealership, or reputable local automotive store (likely cheaper), is the safest bet for avoiding counterfeits.
    Attached is some Repair Manual info, stuff that really should be in Owner's Manual. Worth noting: the last page, with torque value (with clean/dry threads), was in another section of the manual; not exactly the best presentation.
    If you do use anti-seize on the threads, I'd be inclined to use it very sparingly. Maybe brush on a thin coat with an old toothbrush, then wipe it clean with a shop towel, presuming a trace will remain. And reduce torque 25%, maybe. Or just stick with clean/dry threads.
    pjksr02 and Jeffrimerman like this.
  6. ttou68
    ttou68 Active Member
    351
    211
    SC16HR11(Toyota part #: 90919-01275) is what dealership now selling instead of SC20HR11(Toyota part #: 90919-01253)..
    I bought my from local dealership online parts store to receive online discount and picked up in a day...
    $9.42 each is what I paid for them...
    #6 ttou68, Jul 8, 2020
  7. StarCaller
    StarCaller Senior Member
    1,277
    729
    Cedar Crest, NM, USA
    "Ruthenium is a chemical element with the symbol Ru and atomic number 44. It is a rare transition metal belonging to the platinum group of the periodic table. Like the other metals of the platinum group, ruthenium is inert to most other chemicals."
    AzusaPrius and Jeffrimerman like this.
  8. SB6
    SB6 Member
    324
    71
    I just got mine from Advance Auto Parts. They have a couple 25% off coupons going right now, and it seemed to be the cheapest option for me right now. You might also be able to find a good price from your dealership, or maybe even online from one of those dealerships that sells parts online and ships.
    I wouldn't specifically say to avoid eBay, but I would make sure the seller is someone reputable -- maybe a dealership or an otherwise known/well-known store/merchant/retailer.
    I did a quick search online before I bought, and the NGK 4912 laser iridium seemed to be very recommended, so that's what I bought. do not know if that helps you.
    #8 SB6, Jul 14, 2020
  9. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    :ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
    SB6 likes this.
  10. SB6
    SB6 Member
    324
    71
    Hey, it's possible :p. Probable? No, but it is possible.
  11. Jeffrimerman
    Jeffrimerman Member
    229
    45
    Pasadena
    I'm tryikng Rockauto.com since I've watched the commercial only 1 million times. Let's see how quick I get the stuff.
  12. Peter123
    Peter123 Active Member
    131
    128
    I bought NGK 4912 from Rockauto after a bad set of alleged Denso plugs bought locally.
  13. 2012 Prius v wagon 3
    2012 Prius v wagon 3 Active Member
    281
    278
    Redwood City, California
    Seems weird, but I also would trust RockAuto.com more than a local store for real vs. fake spark plugs. And Real vs. Fake is the thing I'd be most concerned with. I'd get the currently spec'ed (by Toyota) Denso plugs from RockAuto.com and worry about other stuff.
    RockAuto probably has the knowledge and ability to detect fakes, as well as the power to destroy bad suppliers. Amazon does too, but it's just not their style to care that much. The local stores less so, and the local stores are also susceptible to people returning fake plugs to them (e.g., person buys fake plugs on eBay, realizes it, buys real ones at PepBoys, then decides to return the eBay ones to PepBoys, and then the next unsuspecting guy buys them).
    On the Ruthenium, here's something I wrote on a different forum on this topic back in Feb (so prices may have changed):
    "I first noticed the Ruthenium a year or so ago. As far as I can tell it is just another precious metal with very similar physical properties to Platinum and Iridium.
    Biggest difference though is ... PRICE
    Current prices in US dollars per ounce:
    Platinum: $969
    Iridium: $1495
    Ruthenium: $255
    So I can see why NGK, etc. would rather use the Ruthenium if it is just as good, and maybe better."
    And it's definitely something NEW, and we all know how some spark plug shoppers like new stuff vs. the boring old manufacturer recommended plug.
    I think that it may actually be possible to get the actual plug in and out with the cowl in place, but the ignition coils are the impossible part, so the cowl has to be removed for our cars.
    One thing you may want to work on is getting the right spark plug socket figured out. These have a 14mm hex, which is smaller than most (16mm or 5/8" is the much more common standard). You will also probably really be happy to have a magnetic one, or at least one with a rubber insert to grab onto the plug. And the socket you use cannot be too thick otherwise it would not fit within the spark plug tube (I measured that to be 22.05 mm ID). When I had my cowl off recently to do the EGR cleaning, I took out one of the plugs to get this all figured out just so I'm ready when replacement day comes. 9/16" will work just as well as the 14mm for this application.
    I found that I already have the general purpose tools to do this perfectly: a Craftsman USA deep well 14mm 3/8" drive hex socket, and a Husky 6" magnetic tipped 3/8" drive extension. Turns out the insertion of that magnetic tip (seen in the photo) fits just perfectly, reaching the tip of the spark plug and holding it securely. Special purpose magnetic spark plug sockets typically will instead have a ring that sits down near the bottom of the hex.
    #13 2012 Prius v wagon 3, Jul 16, 2020
    SFO, Mendel Leisk and Jeffrimerman like this.
  14. Jeffrimerman
    Jeffrimerman Member
    229
    45
    Pasadena
    That makes sense. I bet the price of iridium was cheaper before it because high use for spark plugs. Ruthenium will probably go up in price as it becomes a good alternative for similar uses.
  15. Mendel Leisk
    41,315
    When using a rubber lined socket, especially a new and extra grippy one, it's a good idea to tape the joint between the socket and extension: they're prone to separate, especially after you've just installed a plug.
    Jeffrimerman likes this.
  16. Jeffrimerman
    Jeffrimerman Member
    229
    45
    Pasadena
    I found out sometime in the past to remove plugs with a nice grippy one but when installing maybe it's not good but I try to gently lower the plug into the area and then use my spark plug socket with out the rubber to tighten it in. Maybe not good to drop it hard and mess up the gap. Or I cold just barely grip the plug to the rubber then turn a couple times and then swap to the socket with no rubber then never a problem. I know what you mean. If they are weak connections it can be irritating trying to get that socket out. If I rotate the end of the extension that helps also.
  17. ttou68
    351
    211
    Here's something to try, it's been working for me... I found the end of coil pack will hold the weight of spark plug, and enable you to pickup and lower down spark plug freely..
    14mm regular deep wall socket to loosen the spark plug and then use coil pack to pick it up and lowering the new spark plug.. Spin it down and then using 14mm deep wall socket to tighten and torque to spec...
    Jeffrimerman and Mendel Leisk like this.
  18. Mendel Leisk
    41,315
    Tape is cheap insurance! ;)
  19. Kasra
    Kasra Member
    48
    27
    Irvine, CA
    Using NGK ILKAR7B11, so far it's been great and better welding quality than Denso if you compare side by side. The fake ones are ILKAR7B-11 but if it doesn't have the dash, it's legit.
    Fostel likes this.
  20. elementnomore
    elementnomore Member
    136
    44
    Los Angeles
    THIS make the job a whole lot faster. Good luck!
