How can I get these dents out of my front bumper?
Discussion in 'Gen 2 Prius Technical Discussion' started by Banksy, Apr 9, 2020.
Tags:
  1. Banksy
    Banksy Active Member
    415
    132
    Lancaster Pennsylvania
    I tried using boiling water to push these out however they just kept coming back after cooling down.
    What's the best way I can get these out?
    I plan on using some Bondo made for plastictics for that crack also
  2. MarkySparky
    MarkySparky Junior Member
    30
    Hey, that looks just like the dent in MY front bumper! I need to fix mine too. I saw some youtube videos a while back where someone was doing some pretty major repairs on plastic body parts and they turned out nice. Let us know how you did yours when you get it to work to your satisfaction
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,088
    Columbia, SC
    I've used a hot air gun to do some plastic bumper dent repair. Usually remove the bumper from the car first to allow access to the back. I've never been good enough at it to have a perfect finished product, but they've turned out decent. It's amazing how soft those bumpers can get.
    Raytheeagle likes this.
  4. ChapmanF
    17,766
    I got a big ol' kink in the plastic rocker panel piece once, and I was planning to go out with a heat gun to try to unkink it, but the sun solved the problem before I got around to it.
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,800
    2017 Prius c
    You have a 12 year old car. Some "dings" are expected.
    The only good way to fix that is to replace the bumper cover.
    If it really is that important to you, get an estimate or two from independent body shops.
    Or scout a new part from a salvage yard.
    I think the odds of any "do it yourself" fix turning out good are extremely LOW.
  6. valde3
    valde3 Senior Member
    2,002
    748
    Finland
    Remove the bumper (cover). Plastic welding the crack and heating bending the rest. Then slightly fill it. Then sanding and paint.
