Prius runs again!!!!!
Discussion in 'Generation 1 Prius Discussion' started by Gen1Prius, Jul 30, 2020.
  1. Gen1Prius
    Gen1Prius Junior Member
    37
    Michigan
    2002 Prius
    Thanks to all those that sent me valuable information and I just wanted to update everybody to let you know that the hybrid battery was changed and it has a unlimited mileage lifetime warranty on it from Green Bean battery Company and after cleaning the throttlebody out and shooting a little starting fluid in it and disconnecting the 12 V battery we finally were able to get it started and my brake lines are rusted out now so I had it towed up to the repair facility that I deal with and am getting a lot of preventive maintenance done on her. Yes, it was a very expensive lesson to learn. The gentleman that changed the hybrid battery (with assistance from his young daughter I might add) had his own scan tool and at first we weren’t sure if it was going to start. After clearing one of the codes, the car just wouldn’t start even though it was gone. He said he could only try it one more time and then it will deplete the charge on the HV battery. Our last hope was to clean the throttlebody and we shot a little bit of starting fluid down and it finally fired right up! When I first called the company and I talk to the person there, he was telling me that with this COVID-19 pandemic, it has caused a lot of problems for a Prius owners because they aren’t driving their vehicles and they’re letting them sit and then when they do come out to drive it, the HV battery is toast because they don’t like to sit. So, a word of wisdom, drive your vehicle and I was surprised because I had to fight and try to get a jack underneath that car with both right side tire is flat and it’s sitting uneven. The left side of the vehicle was on the driveway and the right side was on the gravel and I even went out and bought a trolley Jack and even it wouldn’t go up underneath there. I actually had to take my floor jack and I know it’s not safe to do this, but I jacked up by the shipping hook on the right rear high enough to where I can get the trolley Jack on the side of the vehicle. To my surprise, the rims one bent and here I thought To my surprise, the rims one vent and here I thought I bend them when I hit that pot hole. The tires them selves or dry rotted. According to the tire manufacturer’s or whoever it is, they state that tire life is only six years regardless of mileage because of the breakdown and they use the illustration of what happens to a rubber band over time and it eventually basically dry rots so that it just breaks. Hope that helps anyone else.
    bisco and AzusaPrius like this.
  2. Gen1Prius
    37
    Michigan
    2002 Prius
    I just received a phone call from the repair facility that I deal with and they said this is more complicated than what they can handle and they can’t get parts for it. The last thing that I want to do is take this to the dealer because they’re going to charge me up the wahzoo! Anybody know a technician around the Lapeer, Michigan area that I could get to repair it?
  3. Jim DS
    Jim DS New Member
    Holland
    2002 Prius
    I
    Great to hear you got it running. A lifetime warranty on battery. How is that?
  4. bisco
    52,855
    tl;dr, but congrats on getting her up and running!(y)
  5. Gen1Prius
    37
    Michigan
    2002 Prius
    Thats what they advertise. Check it out at http://www.greenbeanbattery.com. I was surprised myself plus they come to you.
    AzusaPrius likes this.
  6. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    It is because they only change out the individual cells that have failed......in the beginning AND if it fails again under warranty.
    Which it certainly will because most of the cells are still OLD.
    Pretty sure I remember that even their replacement cells are used too.
    If it sounds too good to be true............:(
  7. Isaac Zachary
    Isaac Zachary Senior Member
    2,779
    1,501
    Of course a lot of us are finally starting to have battery problems past 200,000 miles. Maybe Green Bean has placed their bets on these cars not lasting much longer anyway. Even if they get a 1/4 more life out of them, that's 250,000 miles on the rest of the vehicle too.
  8. dolj
    dolj Senior Member
    8,646
    4,396
    Wellington, New Zealand
    Great news, keep us updated on how the GBB works out for you. So often we don't get follow-ups so have no idea whether to recommend them or not. The reports we do get are not always favorable, sad to say.
    As far as your brake lines are concerned, you can always buy the parts you need from a Toyota dealer's online shop (out of state to save on tax, if applicable) and give them to your trusted technician to install.
    Toyota Parts Center Online is a good place to find a dealer site.
    #8 dolj, Jul 31, 2020
  9. AzusaPrius
    AzusaPrius Senior Member
    2,257
    942
    This is wrong, if you buy a pack from them and it later goes bad, they replace the whole pack again not just replace a cell.
    We dont know how they build their packs but Im sure they have things in place that are far better than any DIYer will have.
    Please keep all the nay sayers up to date with your purchase!!!
    Congrats on a smarter purchase.
    WHCSC likes this.
  10. sam spade 2
    7,035
    2,804
    2017 Prius c
    That first statement is a distinction without a real difference.
    You STILL end up with a battery pack composed 100% of OLD cells.
    It makes absolutely NO difference if they aged in your car or somebody else's.
    And that second statement just proves that you REALLY know nothing about the company or how they do business.
    But yet you keep acting like you DO.
    It is not a very good act.
  11. Gen1Prius
    37
    Michigan
    2002 Prius
    Apparently the brake lines are okay, but there is a problem with the hydraulic system so I found a Hybrid repair facility to get that addressed as well as the HVAC System. They changed the system but there is I believe a fault code for it as well as the hydraulic braking system. The technician actually drove the car home for me and after I took him back and came back home, I took the car out for a drive around the block and around the block here is like 5 miles because I live in a rural area. The brake pedal goes all the way to the floor but it will eventually stop the vehicle. So, until I’m able to take it in I will just be driving it around the block just to keep the hybrid battery charged.
