GreenBean is offering LIFETIME WARRANTY!?!?!?
Discussion in 'Gen 2 Prius Main Forum' started by ShahGAutos, Aug 14, 2019.
  1. PriusCamper
    PriusCamper Senior Member
    10,917
    4,426
    Pacific Northwest, USA
    I have not ever noticed a difference... But as weird as it sounds, I bought one of these batteries that are most commonly sold as Wheelchair batteries and Computer back up power supply batteries in 2013 and its getting towards the end, yet still hanging in there. I've honestly never had a 12v battery last this long.
  2. fotomoto
    fotomoto Senior Member
    5,597
    3,771
    So. Texas
    No. Constant DC voltage is supplied to the car by the inverter/dc-dc converter (typically in the high 12v to 13.5v range by my observations) The 12v battery is nothing more than bank to store the necessary voltage needed to power up DC components (ECM/ECU's and the HV battery relays being the important ones here) when you push the start button. If the car is in accessory mode (not ready), then all DC power is supplied by the 12v battery but not for very long as the battery is small with little capacity.
    If the 12v is weak and needs a lot or constant charging, the inverter has to supply more electrons to it which drains the HV battery faster which means the ICE needs to run more to recharge it; thus one may notice a slight but noticeable mpg improvement when the 12v is replaced.
    Merkey and Liam howard like this.
  3. PriusCamper
    10,917
    4,426
    And this is also why battery sellers can get away with selling really low quality garbage 12v for Prius and no one is none the wiser. On a traditional car you'd know your battery was trash every time you heard the starter motor trying to turn over, but not on a Prius.
  4. Liam howard
    Liam howard Junior Member
    56
    United States
    Four Touring
    I think it might have something to do with the battery being inside the cab.
  5. PriusCamper
    10,917
    4,426
    Yeah, I don't know Hyundai Hybrids but if that much damage can happen from running over a cute little raccoon, then they didn't design the car very well... Although they do offer lifetime warranty on their battery packs in newer models and nobody else does that.
  6. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,317
    Central Virginia
    In Gen 4 it is now under the hood
  7. Liam howard
    56
    United States
    Four Touring
  8. PriusCamper
    10,917
    4,426
  9. Liam howard
    56
    United States
    Four Touring
    This one was surprisingly only $150. Perfect price point. The dealer wanted close to $300
    PriusCamper likes this.
  10. PriusCamper
    10,917
    4,426
    Nice!!! I tried to enlarge the photo the read the specs but it was too blurry... Do you know how many amp-hours this battery has?
  11. Prodigyplace
    11,696
    11,317
    Central Virginia
    Is that a battery with a vent tube? You do not want charging fumes I’m the passenger cabin.
  12. Liam howard
    56
    United States
    Four Touring
    It says 45 amp hours and has the hole where the vent tube goes. It is the right one
    Prodigyplace likes this.
  13. Liam howard
    56
    United States
    Four Touring
    Yes it has the hole where the vent tube goes. On another note, does anyone know what version of techstream would be most appropriate for my vehicle?
  14. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,782
    2017 Prius c
    THAT is not why the original AGM battery had a vent tube.
    AGMs do NOT release anything in normal operation. They are sealed.
    The vent is there for unusual conditions.......of extreme charging or sudden discharges due to damage.......when unusual pressure builds up inside the case.
    The odds of that happening are remote and other indications should be present making it obvious that you should get OUT of the car.
    Like flames coming out of the engine compartment, for instance. :eek:
    dolj likes this.
  15. dolj
    dolj Senior Member
    7,504
    3,771
    Wellington, New Zealand
    Anything from V8.xx.xxx onwards, will work fine.
  16. Liam howard
    56
    United States
    Four Touring
    Great thank you. Also, will it allow me to change my brake fluid? I read somewhere that that is one of its limitations.
  17. sam spade 2
    7,035
    2,782
    2017 Prius c
    No replies for 7 hours.
    You have me confused......and others too it would seem.
    How would a Techstream not "allow" you to change the brake fluid ??
  18. fotomoto
    5,597
    3,771
    So. Texas
    Yes, you'll need techstream to perform a full bleed as it opens closed valves inside the ABS that the normal foot pedal pressing procedure won't open.
    Liam howard likes this.
  19. 2005Prius01
    2005Prius01 New Member
    Seattle
    i checked local dealers in Seattle, but they are charging more $3000 for new battery. do you know from where can i get in $1600 for new in PMW. Thanks
  20. 2k1Toaster
    6,035
    3,854
    Rocky Mountains
    You can't. The closest to you is in California. The $1650 OE Pack is not a unicorn but it is close.
