Want to buy a spare - but where?
Discussion in 'Prime Main Forum (2017-2022)' started by DBLXX, Aug 5, 2020.
  1. DBLXX
    DBLXX Member
    118
    76
    NY NY
    Three Touring
    Is there an easy place to buy a spare tire and steel wheel for tue tire?
    Tire Rack?
    What would I search for? I have the tire info but not for the steel tue tire mounts to.
    Looking for a one stop shop. Iā€™m going to buy a cover and just leave it in the trunk.
    thanks
  2. Salamander_King
    Salamander_King Senior Member
    10,963
    8,839
    New England
    Are you looking for a compact spare? If so, then eBay or any local junkyard is the best bet. Any mounted compact spare tire from Gen3 or Gen4 Prius will fit. There may be other cars that work as well such as some Corolla spare. You can also order new from a dealer, but it will cost you a lot. Instead, I just ordered a generic seel wheel from Walmart and had them put one of newish OEM tire on it when I had to replace a pair of OEM tires (one tire could not be repaired and they did not have the same OEM tire, so I had to put two new identical aftermarket tires. I keep mine in the footwell of the rear seat behind the driver-side.
  3. schja01
    schja01 One of very few in Chicagoland
    1,732
    1,156
    Chicagoland
    2018 Prius
    I bought one from the dealer. Compact spare and wheel mounted $200ish. Beats rummaging or eBay crapshoot. Keep it covered in trunk except when I need trunk space then I put it in front of a rear seat.
  4. DBLXX
    DBLXX Member
    118
    76
    NY NY
    Three Touring
    Is this the right size? Thought I needed a 15ā€?
  5. Salamander_King
    10,963
    8,839
    New England
    Yap, that should work. 16" wheel for a temporally donuts tire 135/70/16.
  6. DBLXX
    DBLXX Member
    118
    76
    NY NY
    Three Touring
    Thank you...gonna buy it. Appreciate it.
  7. Salamander_King
    10,963
    8,839
    New England
    Although it should fit on PRIME, it maybe bit smaller than ideal size. If you can find 135/80-16 tire size with 5x100 bolt pattern, then the overall diameter of the tire will be closer to the full size 195/65-15 tires.
    Looking up 135/70-16 tire has diameter of 23.44" whereas 135/80-16 is 24.5". The OEM full size tire 195/65-15 is 24.98". Some Prius may have been fitted with a smaller temp tire to fit in the spare tire well, but for PRIME that is a moot point since you have no spare tire well available anyway.
    Here is one with 135/80-16 tire.
    2016 2017 2018 2019 2020 TOYOTA PRIUS SPARE TIRE WHEEL DONUT 16" 5X100 135-80-16 | eBay
  8. Salamander_King
    10,963
    8,839
    New England
    Here is another with 135/80-16 tire. But, if you are going to buy a used temp tire from eBay, check what year model it came off. Even if it looks new, a tire older than 6 years are risky to use. If it is going to sit in your car for next few years unused, the temp tire may be too old to be safe when you really need it.
    2010-2015 Toyota Prius Emergency Spare Tire Donut Wheel T135/80d16 | eBay
  9. PT Guy
    PT Guy Senior Member
    1,080
    708
    Washington, the state
    You strap that spare tire down, right? If someone hits you, you do not want that spare tire becoming an unguided missile launched inside your car.
    Mark57 likes this.
  10. Mendel Leisk
    38,202
    You can search on Tire Rack (great resource), then shop local (with info from Tire Rack). Temp spares I would think tend to be a seldom-sold item, but they can order anything I'm sure.
  11. schja01
    1,732
    1,156
    Chicagoland
    2018 Prius
    I called Tire Rack and they were unable to give me much help when I was looking.
  12. Mendel Leisk
    38,202
    Just search for the temp spare size listed in the Owner's Manual. Either 3rd/4th gen. My 2 cents: 3rd gen spare size is better, closer to OEM tire OD.
