  1. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Be careful, in some areas, it is illegal to have blue or red lights on your vehicle if you are not driving a law enforcement or emergency vehicle.
    MagnusAG99, Starbrand and AzusaPrius like this.
  2. AzusaPrius
    AzusaPrius Senior Member
    2,221
    929
    Tapped into the solar panel to charge my 12 volt battery with this charge controller. 20200806_113911.jpeg
  3. JarrettOriginal
    116
    81
    North Hollywood
    This is something that I'm curious about.
    It's basically trickle, right?
    I was thinking of doing something like this, but with an independent battery and run usb ports for charging...
    +5mpg for posting
  4. AzusaPrius
    2,221
    929
    Yes it does like a 4 step charging process and it also has two usb ports.
  5. NorCal Prii
    NorCal Prii Junior Member
    Bay Area
    What the state of charge rate of the solar roof? Pretty cool mod.
    TheeWood likes this.
  6. AzusaPrius
    2,221
    929
    Depends on the sun light and when the fan turns on to cool the inside of the car but it does the job without overcharging.
    #18286 AzusaPrius, Aug 7, 2020
    NorCal Prii likes this.
  7. sadie72
    sadie72 Junior Member
    45
    Chicago
    It looks great, but you need some serious paint correction up front.
  8. ChapmanF
    18,446
    It's one of the weird things about PriusChat, we can never decide whether we're more worried about reanimating years-old threads or about everybody starting new ones so old info gets forgotten.
    This solar-roof-to-aux-battery mod has seven years of PriusChat history now, and a number of people have done it, sometimes with quite detailed write-ups and performance reporting.
  9. AzusaPrius
    2,221
    929
    Thats great right?
    Good to see multiple people doing it and it working, even with different controllers too.
    The way Solarpriusguy did it is the easiest way to do it, so if your gonna do it Ol' Chap then do it and get back to us with your own input.
    icyrius likes this.
  10. ChapmanF
    18,446
    I think I'm gonna do it Michael Cline's way, for reasons already discussed; I'll probably buy correct terminals from Toyota and interpose at the panel noise filter connection; I've just never liked IDC taps.
  11. Xterra72
    Xterra72 Senior Member
    1,436
    1,681
    Finally switched out the original 12 volt battery after 7 years...
    308F14E3-C991-4D4E-BD3E-116FA59DA82C.jpeg AFD7418E-49C8-4B6B-80CF-AE8E44545FC6.jpeg
    Still enjoying the ride ... Hopefully it holds up for another 7 years...
  12. apt5020
    apt5020 Senior Member
    881
    1,294
    Prius City, CA
    Haven't been on here for some time. Be safe out there!
    James Powers, FST4WHT, orenji and 4 others like this.
  13. MPGRaja
    MPGRaja Senior Member
    469
    1,680
    Corona
    Oof it finally happened to dad’s Prius. Better to fix small chips then replacing the entire thing. But of course sometimes like this has to be OEM.
    97A57A1F-94DB-4ADC-9748-EB58A80C0BB0.jpeg 980DCCBC-6ED6-44FE-8B66-64210A2179F1.jpeg 8C5A6F67-3F76-4405-9839-F8FAF3D99256.jpeg
  14. apt5020
    881
    1,294
    Prius City, CA
    Shoot, I thought $600 was expense when I replaced my. But only cost $100 using my insurance
  15. Xterra72
    1,436
    1,681
    sorry to hear. My oem lasted only about a year. I couldn’t justify the oem $$$ so I went with the second best brand in my opinion, Pilkington Solar Windshield. It’s at least 6 years and doing well.
    MPGRaja likes this.
  16. ChapmanF
    18,446
    Camping mod.
  17. apt5020
    881
    1,294
    Prius City, CA
  18. Attila Fekete
    Attila Fekete Member
    164
    59
    Budapest, Hungary
    As Toyota doesn’t produce windshields and most cases it uses Pilkington windows, you have chosen the best - I think.
    Xterra72 likes this.
  19. nepbug
    nepbug Junior Member
    31
    Denver, CO
    20%
    ASRDogman likes this.
  20. nepbug
    31
    Denver, CO
    How does the CT200h seat comapre? Straight bolt-in?
    Inza2 likes this.
