Clearance
Discussion in 'Prime Main Forum (2017-2022)' started by tenortodd, Aug 8, 2020.
  1. tenortodd
    tenortodd Junior Member
    Hi all.
    i need some help. We are considering driving a long distance to obtain a crazy deal on a 2020 Prius Prime. As a former 2014 Prius owner, I remember how low to the ground it is. We scraped the bottom multiple times either hitting bumps in the road or going onto an incline.
    Well, our new home has 2 inclines on the driveway: one when you first drive up to it and another after the sidewalk. How in the world would I know of the Prius can clear them? There’s no dealer that would let me test drive the vehicle to my house...nor would they let me try a test that could possibly damage the vehicle.
    Any ideas? My wife thinks we just have to forget this deal.
  2. AzusaPrius
    AzusaPrius Senior Member
    1,673
    772
    Should clear it no problem.
    If there was damage to the driveway and it was not level then you might have a problem.
  3. AzusaPrius
    1,673
    772
    Montgomery and pghyndman like this.
  4. tenortodd
    i tried to show in those pics... it’s not a level driveway. It’s quite an incline.
  5. Trollbait
    11,327
    The current Prius and Corolla have 5.1 inches of ground clearance.
    The Prime's is 4.8", but that is mostly because of the plastic trim.
    I'm guessing that is a Fit in the photo; its ground clearance is 4.4 inches.
  6. Northerner
    Northerner Active Member
    120
    103
    Midwest
    2020 Prius Prime
    I have an inclined driveway that many guests scrape their bumpers on when turning in or leaving the driveway. Our Prime would surely scrape if I didn’t know the technique from lots of practice with previous cars.
    Just make sure to cross that line one tire at a time. It really does make a difference.
    illumiN8i, Tips and Montgomery like this.
  7. ems2158
    ems2158 Active Member
    221
    162
    Bucks County, PA
    The left and right bottom edge on my fenders is really scrapped up from a driveway similar to yours.
    I'm not too concerned about it though. It's plastic and not going to rust and I can't see it unless I lay on the ground.
    jerrymildred likes this.
  8. schja01
    schja01 One of very few in Chicagoland
    1,732
    1,157
    Chicagoland
    2018 Prius
    To be safe I try to attack ramps at an angle whenever possible. Learned that trick during my flying days to avoid “Prop Dings”.
  9. Tideland Prius
    16,072
    No way a Fit without load is 4.4” - maybe you’re quoting a full car with passengers and cargo?
    Honda Canada lists unladen at 5.4” and fully laden at 4.4”
    Their 2014 Prius is listed at 5.5”. The Prime is 4.8” (all unladen).
    The issue is the longer overhang on the Prime compared to the regular Prius. If they’re scraping the bumper with the old Prius, they’ll scrap with the Prime.
    Hell, I’ve scraped the bumper on a standard curb, pulling up curbside (I thought I hit the curb with the wheel but it turns out, it’s the front bumper).
    Montgomery likes this.
  10. PT Guy
    PT Guy Senior Member
    1,085
    709
    Washington, the state
  11. jerrymildred
    jerrymildred Senior Member
    11,491
    14,100
    Tampa, FL
    The Prime is lower, as already stated. And the front overhang is longer.
    But the front overhang is angled up on the bottom. So places that used to scrape the front bottom of my PiP do not scrape the front bottom of the Prime. I don't scrape as often against parking blocks with the Prime either. However, a rock that the PiP would straddle might be too tall for a Prime.
    On steep driveway transitions, I do like @schja01 and take it diagonally. It works most of the time. And, again, it's plastic. Won't rust. Not visible except to oil change personnel and to any slow pedestrians who don't get our of your way. :whistle:
    Tideland Prius and schja01 like this.
  12. jerrymildred
    11,491
    14,100
    Tampa, FL
    I measured mine this morning. Front center had 7-1/2" clearance. Toward the sides it was more like 7-1/4". That's quite a bit more than my PiP had even though the Prime extends farther forward from the front axles. Oh! And I didn't notice any scrape marks on the bottom. The car has about 45,150 miles on it.
    Tideland Prius likes this.
  13. Tips
    Tips Member
    128
    64
    Grand Forks, B.C. Canada
    2020 Prius Prime
    Maybe try backing in. Lots do! Im thinking of purchasing a back-up camera and mounting it on the frount.
  14. 1x1
    1x1 Member
    147
    45
    My Gen 2 would always scrape the curb backing up from the garage to the street. The Prime does not do this. YMMV, but in my experience it is better/improved. Can also try doing it at an angle as that can help.
    Tips likes this.
