08 Issues
Discussion in 'Gen 2 Prius Main Forum' started by LisaAndAl08, Aug 8, 2020.
  1. LisaAndAl08
    LisaAndAl08 New Member
    Hughesville MD
    Three Touring
    Al Here My Wife’s Car Lisa 2008 White Prius With 234,234 Miles In Hughesville MD We Have These Codes From The Toyota Dealership In Waldorf MD And We Need Some Options Here We Have No Plans To Sell Our Gen 2 Model Prius Since Lisa My Wife Really Loves This Car. I Did Notice B1421 Most Prius Has If You’re In A Dark Zone. The Car Is Very Clean. Plz Any Options Would Be Nice. 425BCB85-05A7-44F1-8682-FC658A0765BB.jpeg 96703752-9CCD-4B4F-89B3-7B1AEC1406FE.png
    C1202/68/511 BRAKE FLUID LEVEL LOW
    C1241/41/81 LOW BATTERY POSITIVE VOLTAGE OR ABNORMALLY HIGH BATTERY POSITIVE VOLTAGE
    C1259/58/150 HV SYSTEM REGENERATIVE MALFUNCTION
    C1300 ABS ECU MALFUNCTION
    C1310/51 MALFUNCTION IN HV SYSTEM
    C2318 LOW VOLTAGE ERROR (POWER SUPPLY MALFUNCTION)
    P0A7F/123 HYBRID BATTERY PACK DETERIORATION
    P0A80/123 REPLACE HYBRID BATTERY PACK
    P3000/123 BATTERY CONTROL SYSTEM
    P3011/123 BATTERY BLOCK 1 BECOMES WEAK
    P3030/123 DISCONNECTION BETWEEN BATTERY AND ECU
    P0AC1/123 HYBRID BATTERY PACK CURRENT SENSOR LOW
    B1271 COMBINATION METER ECU COMMUNICATION STOP
    B1421/21 SOLAR SENSOR CIRCUIT (PASSENGER SIDE)
    B2795/99 UNMATCHED KEY CODE
  2. PriusCamper
    PriusCamper Senior Member
    13,467
    5,434
    Pacific Northwest, USA
    Yikes, that's a lot of codes... This website can help you work on all of them if you or a friend or family member enjoys working on and learning about cars. We can walk you thru all the details. But basically, if this were my project, I'd make sure the 12v battery is healthy, then pull the hybrid pack for a thorough cleaning, replace any corroded damage that can't be cleaned, then inspection and reconditioning, then start a spread sheet on the pack's modules and replace bad ones as needed. Then once that's completed and warning codes for all those problems are gone, I'd service/replace major parts in the brake system... Cost would be about $1000 total and I'm sure the Toyota Stealership told you it would be something stupid like $6K total and then tried to sell you a finance package for a new Prius. Alternatively, if you went to a local mechanic who works on hybrid cars who's cool with replacing the expensive parts with used parts, you'll be up in the $2-$3K range.
  3. LisaAndAl08
    Hughesville MD
    Three Touring
    I would need a new 12v Hybrid Battery abs ecu combination meter and possibly Regenerative breaking and brake fluid do you now any one in southern Maryland that works on hybrids
  4. bisco
    52,862
    welcome
    it's not likely that all that failed at the same time.
    agree with prius camper, start with the 12v. do options include diy?
  5. LisaAndAl08
    Hughesville MD
    Three Touring
    I don’t think so diy but I replaced the 12v last night got rid of c1241 c2318 most likely all other codes remain I think I would need Dynastic again old 12v was off 9.6V 9.1V on new 12v at 12.59V on and when off 14.58V
    Combination meter is still out and fan is super loud in back now there is no arrows charging my Hybrid battery battery is stuck at one purple bar
    #5 LisaAndAl08, Aug 9, 2020
  6. LisaAndAl08
    Hughesville MD
    Three Touring
    Update I found someone in Annapolis who works on hybrid vehicles Prius hybrid repair they charge 800 for combination meter and 795 for battery and 200 for Regenerative breaking there only 59 minutes from me. 25$ monthly for battery and inverter pump and inverter. They have 19 cars at the shop currently. Are they any good or is there a cheaper option. Sorry I meant off 12.59V and on 14.58V for 12V
    #6 LisaAndAl08, Aug 9, 2020
  7. bisco
    52,862
    12v sounds good. hybrid battery my be going, but replacing with rebuilt is iffy at best. if she really likes the car, get a new battery, or at least 'newpriusbatteries.com
    is there movement in the inverter fluid reservoir when the car is on?
  8. ColoradoCrow
    ColoradoCrow Senior Member
    1,108
    464
    Leawood, KS
    I
    Texas hybrid batteries can get you a new combo meter. I replaced both my 08 and my wife’s 08 with new ones. Best thing ever. Solid ever since. Taking the dashboard out is an easy DIY IMHO.
