What mode to drive in
Discussion in 'Gen 3 Prius Fuel Economy' started by Tamonline, Jul 28, 2020.
  1. Tamonline
    Tamonline New Member
    South Australia
    i-Tech
    Hi guys
    Just bought a 2010 Prius Tourer here in Adelaide south Australia and very eager to drive him.
    I know nothing about these cars except it’s soo smooth and small to drive.
    I ask, what mode is best to drive in and why
    The Toyota dealer just said leave it in ECO mode all day everyday and just use power if you need a boost, quick start off or are going up hill..
    But is there a method that is best to charge the batteries and get good fuel economy
    By the way I have named him “Corvin” after Michael Corvin from Underworld movies as he was also a HYBRID
    Hahah
  2. Ed Beaty
    Ed Beaty Active Member
    334
    311
    Salt Lake City
    THIS may be of use on that question...
    fuzzy1 and Tideland Prius like this.
  3. bisco
    51,623
    congrats and welcome!
    eco for best fuel savings, normal for normal drivers and power for the beast in you.
    but don'tswitch around, it's too much trouble after awhile. pick one and stick with it. ignore the sales weasel.
    all the best! (y)
  4. fuzzy1
    10,344
    Just in case the article linked in Ed Beaty's post (#2) is too long ...
    Nearly all the change is merely user interface touch-and-feel of gas pedal, not real changes to the propulsion system, so the "best mode" varies by driver preference and personality type. Different drivers get their best results in different modes. So just use whatever mode feels best to you.
  5. Threej
    Threej Member
    99
    99
    Portland, OR
    My priority is to optimize MPG. As such, I normally drive in "Normal", and use "Eco" only if I'm heavily using the AC.
    If find "Eco" to be more wasteful than "Normal" on two counts:
    - Its initial slow throttle response means it takes a lot longer to "press" through the battery range and activate the engine. Particularly in stop-and-go traffic, this drains battery life much faster and kills mpg.
    - For the times I really need to press the gas down to get some power, the "ECO" mode is so sensitive that its hard to navigate between "give me some extra gas to get up this hill" and "OMG, IT'S A TERMINATOR GIVE ME EVERYTHING YOU HAVE!", and extra gas gets wasted compared to the finer control of "normal" at high throttles.
    However, Eco does have the added benefit of doing some behind-the-scenes manipulation of the AC to use less energy, so if I'm doing steady highway driving with it on, I'll use eco.
  6. Mendel Leisk
    41,058
    I like "Normal" (neither ECO or PWR pushed): feels natural and linear, what more can you ask.
    ECO, way too much pedal travel required to get a reaction, actually harder to modulate.
    PWR doesn't actually increase power in any way, just makes the pedal a little more touchy.
    4th gen, I understand they've made all the "modes" more aggressive, so might need to be revisited. But for 3rd gen, that's my pref.
  7. bisco
    51,623
    i've been using abnormal mode since the beginning
  8. David9962000
    David9962000 Member
    141
    68
    2020 Prius
  9. RRxing
    RRxing Senior Member
    2,539
    1,814
    NEPA
    I stick with Normal, but it's all a matter of personal preference...
