Check Gen 3 trans fluid level before drain
Discussion in 'Gen 3 Prius Technical Discussion' started by cobradb, Jan 17, 2012.
  1. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Before you take any plugs out spray the plug area off with carb cleaner so no dirt in the area can get in.
    When i go through the trouble of lifting my G2 up that high to get to the trans I make good use of that time and service the ac ecoil under the dash.
    I use Kool It from Amazon it comes with the hose kit it's a spray can of microbial cleaner for you ac system that you inject back up the ac drip hose it fills the ecoil with soapy foam and comes back out as liquid. Cleans the evaporator box under the dash.
    Makes the car smell real nice and keeps the drip hose clear. First time use 2 cans. Last time I asked dealer charges $125.
    It is a maintenance item that you didn't know about till your drip hose gets clogged..
    Drip Hose is hard to find its very short and stubby comes out under the glove box area..
    I also lube the shite out of the chassis but that's another discussuin
  2. Mendel Leisk
    40,985
    Nobody's dealing you cards, plenty of ways to get it level. Simplest with the front on ramps would be to jack up the rear a bit.
    If it was sloping down front-to-rear your level's probably a bit low, but still within spec.
  3. Soulbarer
    Soulbarer Junior Member
    Joplin, MO
    2013 Prius v wagon
    What do you all recommend for tranny fluid? I'd like to skip dealer and go to O'Reilly's, where I was able to get my Asian car coolant from as well.
  4. ASRDogman
    ASRDogman Senior Member
    7,440
    3,870
    Toyota WS Fluid. Nothing else is correct.
    The cost is only a few dollars more for the fluid designed for the transmission.
    Or transmission designed for that fluid. How ever you want to put it.
    Foxglove likes this.
  5. Michael Wood
    Michael Wood Active Member
    181
    118
    Boston, MA
    2020 Prius Prime
    If your car is still under warranty I would stick with Toyota WS fluid. If not, I'm using Valvoline Maxlife Full Synthetic. Sometimes you can get it under $5 a quart at Walmart.
  6. Mendel Leisk
    40,985
    Toyota only gets completely sticky with one fluid: Toyota ATF WS, for the transaxle. They caution in owners manual that anything else may damage it.
    there’s a link in my signature on transaxle fluid change.
    Doug McC and Foxglove like this.
  7. Bill Norton
    Bill Norton Senior Member
    2,136
    730
    MONW, Ks.
    Any quality synthetic ATF will be fine.
    It's a very simple transaxle. It's just gears and bearings. There is no shifting or clutching.
    Toyota has only one ATF for their entire fleet. Of course they recommend that.....:rolleyes:
    I've used Mobil 1 ATF and Redline D6.
    No one can tell the difference of what brand you use.
    I have an old thread on the subject with many oil analyses of what came out of the transaxles.
  8. ChapmanF
    17,765
    and copper wires carrying 650 volts, protected by a coating of insulating varnish that it would be best not to chemically degrade.
