2008 Prius won't start
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by noname87, Jun 13, 2020.
  1. ttou68
    ttou68 Active Member
    351
    211
    You could try an OBDII you now have, if a proper OBDII not available...(I've used a cheapo and it helped with my first Prius repair before I got an Bluetooth OBDII to use with phone apps...
    It may not read everything but you'll probably get codes to give you some idea on what's going on, and nothing is lost if it doesn't read..
    Good luck!
    SFO likes this.
  2. noname87
    noname87 Junior Member
    84
    NC
    That's my gut feeling but it is tempting. 2010 with 75K for 11K, But the battery is 10-11 year old and not a bargain if the oil issue is real. This is for my daughter. I can't see her checking the oil weekly and adding oil.
  3. bisco
    52,286
    that price is high, no?
    my 2012 plug in w/ 70,000 miles is only worth $9,500. on average around here
    #43 bisco, Aug 13, 2020
    SFO likes this.
