Left Hi beam headlight not working
Discussion in 'Prius v Technical Discussion' started by Tophawk, Aug 10, 2020.
  1. Tophawk
    Tophawk New Member
    Bogata, Texas
    2015 Prius v wagon
    Ok I am stumped. My Left hi beam headlight wont come on. I replaced the bulb, swapped the fuse under hood...even swapped bulb to right side to verify it was good. I have halogen headlights so please no HID lamp answers necessary.
  2. Tim Jones
    Tim Jones Senior Member
    1,685
    547
    SE Texas
    2011 Nissan LEAF
    Did you put a volt meter in there? Probe back from the plug...
    One of my volt meters has very sharp probe ends that can easily penetrate the wires to see if you have voltage just before the plug.
    #2 Tim Jones, Aug 11, 2020
  3. Air_Boss
    Air_Boss Senior Member
    3,912
    1,068
    New Yawk
    Corrosion or heat damage to the base/connector?
    Georgina Rudkus likes this.
  4. Tim Jones
    1,685
    547
    SE Texas
    2011 Nissan LEAF
    Have you worked on this?
  5. Tim Jones
    1,685
    547
    SE Texas
    2011 Nissan LEAF
    Another person on here that doesn't respond to people trying to help..... I don't get it......
