Left our '02 parked in Drive. Now it won't start.
Discussion in 'Generation 1 Prius Discussion' started by Tryyn, Aug 13, 2020.
  1. Tryyn
    Tryyn Junior Member
    Madison, WI
    2002 Prius
    My grandfather and I bought a 2002 a couple months ago. It has been well maintained (was an electrical company car) and is still on its original traction pack. The pack tests out well (Dr. Prius). My grandpa's been driving it regularly. He plans to give it to me when I get my license, and I'm something of a tech historian myself, so that's why I wanted a gen 1.
    A week ago, he parked it and didn't realize he left it in Drive. Today he tried to start it, and it wouldn't boot. No beeps. No lights. No multi-display. I suppose the 12V is dead? Is that the case or did we do anything else to it?
    Thanks!
    - Tryyn
  2. vaughnstark777
    190
    33
    Roy, WA
    2001 Prius
    I
    I would try to jump the 12v first. Then go from there.
    WHCSC and Tryyn like this.
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,158
    Tampa, FL
    A week in drive? It may have run out of gas and then drained both batteries. :eek: Try jump starting it to see if it will start. Just make dead sure you have the polarity right before you connect the jumper cables.
    WHCSC likes this.
  4. Tryyn
    Tryyn Junior Member
    Madison, WI
    2002 Prius
    A week, key OFF, in Drive. Hybrid system was off.
  5. Trombone
    Trombone Active Member
    349
    122
    Allentown, Pennsylvania
    2002 Prius
    I'm puzzled. You can't take the key out of the ignition when the car is in D (Drive); it only comes out when it's in P (Park). So the car was sitting with key left in, in D gear. Was it left in "Ready" mode? In any case, you've surely fried the 12V battery, which is now dead, so you won't get any action at all. If car was left in "Ready," you may have depleted the hybrid battery as well. Charge the 12V battery and hope for the best.
  6. Tryyn
    Tryyn Junior Member
    Madison, WI
    2002 Prius
    The vehicle was off. The key was taken out. For some reason that interlock isn't working. Is something wrong with the ignition switch itself?
  7. jerrymildred
    11,517
    14,158
    Tampa, FL
    I admit that I'm not a Gen1 expert, but it sure sounds like something's wrong with the ignition switch. Since he's nearby, maybe @ericbecky can advise.
  8. ChapmanF
    18,560
    If it was OFF with the key out for the week, it should still really have been OFF though, and not drained the battery.
    If there's a problem with the shift interlock circuits (as it already sounds like there is), maybe that's also the explanation for not starting? It has to think it's in Park. (Not just look like it's in Park; the ECU has to be seeing the interlock signal saying it's in Park.)
    But if it's really dead, no lights anywhere, I guess that's not it.
  9. Tryyn
    Tryyn Junior Member
    Madison, WI
    2002 Prius
    UPDATE: put the 12V on a charger and now it runs fine. Now we need to get that interlock checked out...
  10. Larry Hill
    Larry Hill Junior Member
    West Virginia
    2002 Prius
    This is a bit off topic, but last year I got out of my 2003 Prius and had accidentally left it in Drive and Ready mode. It had kicked off and was therefore silent. I did NOT get any warning tone when leaving the car. An hour later I found that it had started up to charge the battery and had enough at idle to roll over the hill into the woods and was totaled hitting a tree - still in Ready mode and engine running when I found it. I had recently put a reconditioned battery in it and pushed the insurance co to give me a good settlement which I put into a 2002 Prius. Bought the carcass back from insurance co and had loads of spare parts, including a good battery pack.
