Gen 4 PVC Valve
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Sheeks, Aug 10, 2020.
  1. Sheeks
    Sheeks Junior Member
    Mississippi
    New here. 140k on my Gen 4 (2016). Looking to clean my throttle body, clean the EGR tube, replace plugs and pvc valve in the next couple weeks, but I can not find any information on the location of the PVC Valve. Any ideas on location and/or best access ? My mpg has decreased from 55+ and now stays between 48-50. Any information will be helpful. Thanks.
    Raytheeagle likes this.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,476
    Bay Area, California
    2019 Prius Prime
    Welcome to Prius chat(y).
    The PCV valve is buried behind the intake manifold:cool::
    And the egr cooler will be a bear to remove, requiring the inverter to be moved:(:
    69512831-CB06-4DB0-B0C7-E6A3EB9BE3AA.jpeg 02AFB6A0-0EE6-4288-AA05-AD5EA88C24B6.jpeg
    I put an oil catch can on too, similar to what the Gen3 folks do:):
    I had to add my own bolt in the top as it didn't come with that:whistle:.
    The throttle body and intake looked good at 21k miles on our Prime;):
    4FCD7024-FEE7-47F1-8940-151CB53AD546.jpeg 67D53BE3-236C-43C6-8160-108D8E9FB1AA.jpeg 99AC464A-CDD2-40B2-8D51-98E68164B750.jpeg 5C11973A-FC0C-4086-9AAA-E951855ADE73.jpeg FD82E3BD-37E4-4448-90F0-7CEBD6E3E8FE.jpeg 2B565D34-011B-46EB-9430-A5EFA93B665D.jpeg 5FB6BDD3-0F0D-4085-84F6-1406A8C5B461.jpeg
    Hope that helps(y).
    Mendel Leisk, ETC(SS), amos and 3 others like this.
  3. amos
    amos Active Member
    341
    281
    los angeles
    @Raytheeagle , your car is brand new, why did you think it needs that? was the egr cooler dirty?
  4. Raytheeagle
    11,251
    15,476
    2019 Prius Prime
    Is it ever too early to hedge :whistle:.
    As an aside, guess what the oil catch can is already catching:cool:.
    So I'll say it isn't too early as the spooge is already there;).
    And the cooler will be its own effort as the inverter will have to move(y).
    amos likes this.
  5. amos
    amos Active Member
    341
    281
    los angeles
    is your invite still valid? mine is already 140k, i got so much time now to drive up north. what were the findings over there at the OCC
  6. Raytheeagle
    11,251
    15,476
    2019 Prius Prime
    Once we get out of pandemic land, absolutely:).
    I found a teaspoon amount after 4K miles on the odometer, which is really about 1.5k miles of engine use :cool:.
    So since there was a pool in the intake manifold, I think it's prudent ;).
    Hope that helps (y).
    amos likes this.
  7. amos
    amos Active Member
    341
    281
    los angeles
    yes helps, i think i am going to do something about it, i will order an egr cooler from ebay, seems like i cant ignore that issue, wonder if other already did the OCC and cleaned all that egr path
  8. Travis Decker
    Travis Decker Active Member
    139
    115
    Portland OR
    On the Gen 4 if the EGR gas comes from behind the cat it's supposed to solve these problems and you aren't supposed to have to do any of this stuff....
    amos likes this.
  9. Raytheeagle
    11,251
    15,476
    2019 Prius Prime
    That Potentially solves the egr cooler Clogging but not the PCV valve blow by ;).
    The oil catch can cured that to a certain degree(y).
  10. amos
    amos Active Member
    341
    281
    los angeles
    so how can i get an access to the pcv without disassembling half the car?
  11. Raytheeagle
    11,251
    15,476
    2019 Prius Prime
    Just the pressure washer is needed;).
    Save your $$$ for the cooler for something else:).
    But the oil catch can is a good idea(y).
  12. ChapmanF
    15,056
    If you're quite convinced it needs replacement, here's a thread where if you follow down the page you'll get a good sense of pros and cons of different ways you might try. (It's a Gen 3 thread, but the engine at least is largely the same.)
    Every Prius ever made makes a small pool of gloop in the intake manifold though. If you remove that, it will only feel intensely self-conscious in the company of other Prii.
    amos, Raytheeagle and krmcg like this.
  13. Mendel Leisk
    38,198
    Gen 3 PCV valve can be reached from below, if you're not needing to remove intake manifold. 4th Gen is essentially the same engine, though the periferals are different, so may still be doable thus.
    @NutzAboutBolts has a (3rd Gen) video showing access from below.
    That said, removal and cleaning the intake manifold may be warranted anyway.
    NutzAboutBolts likes this.
  14. amos
    amos Active Member
    341
    281
    los angeles
