2017 Prius (7450 mi) required all brake pads to be replaced
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Pappapete, Aug 13, 2020.
  1. Pappapete
    Pappapete New Member
    Ontario
    Hi Everyone,
    Looking for anyone who's had experience in this area. My parent's 2017 Prius, with only 7,450 miles had to have all of its brake pads replaced. They've barely driven it because of the pandemic. The dealer said that moisture built up due to inactivity and rusted the brake pads out.
    They're retirees and paid out hundreds of dollars on this already.
    Please let me know if you've experienced this, or believe this is possible, or could be downright fraud.
    Thank you,
    amos likes this.
  2. krmcg
    2,592
    2,392
    Whittier, CA
    no problems with the rotors?
  3. Pappapete
    Ontario
    I believe the front and rear rotors were replaced also. Am confirming. Sound legit to you?
  4. mjoo
    mjoo Senior Member
    1,154
    1,326
    Michigan
    I'm calling BS on this one - either surface rust or flood damage.
  5. Pappapete
    Ontario
    Thanks mjoo, if it's surface rust it likely will just wear off after a couple of miles of driving right?
    kenoarto, Tande, krmcg and 1 other person like this.
  6. Prodigyplace
    12,521
    11,741
    Central Virginia
    Or a dealer who needed to buy a new boat.
    bikeprof, amos, kc5dlo and 2 others like this.
  7. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,592
    near Brisbane, Australia
    Contact TOYOTA Customer Service and complain bitterly. They should last 200,000kms.
  8. dig4dirt
    dig4dirt MoonGlow
    1,151
    741
    Lancaster Co PA
    2014 Prius c
    smh
    You need to find a new dealer or garage to have them take their car to.
    check their reviews on google. ask around.
    kenoarto, krmcg and Prodigyplace like this.
  9. Pappapete
    Ontario
    Thank you Alan.
    Yes thank you MoonGlow I believe we may have to do that.
    #9 Pappapete, Aug 14, 2020
  10. mjoo
    mjoo Senior Member
    1,154
    1,326
    Michigan
    Yes
    kenoarto, Raytheeagle and krmcg like this.
  11. krmcg
    2,592
    2,392
    Whittier, CA
    not at all.
    Prodigyplace likes this.
  12. Salamander_King
    Salamander_King Senior Member
    11,015
    8,943
    New England
    I have read other threads with a similar issue on fairly new Gen4 Prius or Prius PRIME having to do brake/rotor replacement. Since you live in the rust belt, it is possible the car may need a brake service. The best way to be sure is to bring the car to the different shop(s) to get second or third opinions.
  13. Pappapete
    Ontario
    ok thank you for your input Salamander_king. Sadly, my parents went ahead with the replacement before getting a second opinion. I think this is a lesson learned.
    Salamander_King likes this.
  14. bisco
    51,810
    'my parents had to have all of its brake pads replaced'
    had, as in already done? or recommended, but doing due diligence?
    davecook89t likes this.
  15. Pappapete
    Ontario
    Already done. They trusted the dealer and simply paid for the service. Had I been there I would have questioned it and gotten a second opinion.
    kenoarto and bisco like this.
  16. davecook89t
    davecook89t Senior Member
    1,088
    821
    Washington State, Florida
    Four Touring
    Have you described the problem correctly? We have seen reports of rusting rotors on this forum, but I don't believe I've seen any about rusting brake pads. In fact, I wonder if that is even possible. There is a metallic component in some brake pads (not sure about the Gen 4 Prius), but since it is combined with other materials and little of the metal is exposed on the surface, I don't think it could rust. If that is what the service writer said, it really does sound like BS.
    Also, if the work has not been done yet (it sounds like it has), could you post pictures of before and after?
    Prodigyplace and krmcg like this.
  17. Pappapete
    Ontario
    Hi Dave, thanks for being precise - yes, I did not describe it correctly. The rotors were rusted. The brake pads were simply replaced along with the rotors. I'm trying to get my hands on the inspection report to see why. Front pads were down to 6mm and rear, 8mm.
    No photos available sadly.
  18. Prodigyplace
    12,521
    11,741
    Central Virginia
    Are you in California or Canada? You profile is not clear.
  19. RRxing
    RRxing Senior Member
    2,542
    1,817
    NEPA
    Was this based on actual measurements or were they just "eyeballed" by the "technician"?
    kenoarto likes this.
  20. ChapmanF
    18,018
    A caution though: that's true for light surface rust that has only formed in the last few days, when the car is driven often enough to keep it scrubbed off.
    If the car is driven less often and is not scrubbing all of the rust off while it is light, it (the rust) becomes more established, rougher, and harder. At that point, it is not something the pads will scrub off. It becomes a pad grinder.
    Happened to my Gen 1 back when I was mostly bicycle commuting.
