Weird window issue!
Discussion in 'Prime Main Forum (2017-2022)' started by OpusFuller, Aug 14, 2020.
  1. OpusFuller
    OpusFuller Member
    31
    47
    PA
    2018 Prius Prime
    I noticed a weird window issue. There doesn't seem to be any issue on the inside or outside of the window it seems like it's on a layer in between the glass if that makes sense. I don't know if this would be covered under the warranty or not but it doesn't seem like it's something from wear and tear from the customer. Has anyone else experienced this or had this happen to their window. It's a 2018 previous prime mid trim level.
    I also have the rest issue on the rear hatch handle but from reading some comments on this thread it seems like the people that got this fixed had it happen again so I don't know if there's anything that I could do with that.
    Also have the weird issue with my steering Wheel there is a parts on the top of my steering wheel that is getting wrinkled. Also reading some posts here it seems like some people have luck getting it fixed under warranty and some were denied not sure what I should do. Thoughts?
  2. OpusFuller
    OpusFuller Member
    31
    47
    PA
    2018 Prius Prime
    Pictures.
  3. schja01
    schja01 Senior Member
    1,834
    1,221
    Chicagoland
    2024 Prius
    Limited AWD-e
    Not normal IMO I would think it would be covered by warranty. Unless you took a hair blower to it thawing it out in winter?
  4. OpusFuller
    OpusFuller Member
    31
    47
    PA
    2018 Prius Prime
    Lol, I didnt. Just started happening from what I noticed. But what on earth is it? Like a bubble in between the glass? I thought the window was one solid piece?
  5. bisco
    51,937
    laminated
  6. jerrymildred
    jerrymildred Senior Member
    11,517
    14,152
    Tampa, FL
    The does look like it's delaminating but side windows are usually tempered rather than laminated. I'd absolutely ask the dealer about that.
  7. Flaming
    Flaming Active Member
    138
    123
    QC , Canada
    Technology
    Prius Prime has acoustic front windows. I mean they are special laminated glass. Looks like they delaminate....yes go see your dealership. Not normal.
  8. Salamander_King
    Salamander_King Senior Member
    11,019
    8,954
    New England
    Wow, first time seeing and reading this glass problem. Chips and cracks, yes... but not this. As for the problem with rust on hatch handle backing plate and wrinkled steering wheel SofTec covering, those are known issues. You have to ask press hard to get any warranty repair, but it's been done, although the fix seem to be variable.
  9. OpusFuller
    OpusFuller Member
    31
    47
    PA
    2018 Prius Prime
    Thanks for the replies. I actually work at a Toyota dealership. I sell them. We don't get Primes here in this region aka Pittsburgh, Pa. I just wanted to k on what to talk to service about tomorrow when I go in.
    Its funny, I've been selling Toyota for 4 years and this is the only vehicle I've seen or heard about the steering wheel issue. Same with lift gate and definitely this is the first time I've seen the windshield issue. Quality control is always pretty good. Weird.
    Again, thanks for the info everyone.
    Salamander_King likes this.
  10. mistermojorizin
    mistermojorizin Active Member
    310
    137
    usa
    2019 Prius Prime
    What is the lift gate issue?
  11. jerrymildred
    11,517
    14,152
    Tampa, FL
  12. Trollbait
    12,539
    As mentioned, it is laminated like the windshield. In addition to sound reduction, some consider it a safety feature, as it keeps those not wearing seat belts from ejecting out the side window when it breaks during a crash.:rolleyes: Of course, it makes it harder to break for escape and extraction during emergencies.
    Rust on the piece supporting the handle.
    Japan doesn't salt roads in winter. So their car designers had no idea what it can do to cars. That's why the first Tacoma/Hilux Toyota imported to the US had the bed rust out. I guess each generation of engineers needs to relearn the lesson.
  13. Tips
    Tips Member
    128
    66
    Grand Forks, B.C. Canada
    2020 Prius Prime
    Make sure the drains in the underside of the doors are clean. Use a wire too clear the drains.
  14. Prim.e.xample
    Prim.e.xample Active Member
    164
    107
    Indiana
    2020 Prius Prime
    That is super weird! The only glass issue I've had is the back passenger window squeaks the I put it up.
