New Injectors
Discussion in 'Gen 2 Prius Main Forum' started by ozarkretiree, Aug 16, 2020.
  1. ozarkretiree
    ozarkretiree Member
    72
    26
    Missouri
    Four Touring
    My 2007 Touring model (240K mi) was running really bad and gave my first ever red triangle. I limped into the local Toyota dealer in Joplin, MO which I dislike but had no choice. Turns out my fuel injectors had failed. They told me 2 were leaking and washing the lubricant barrier off the cylinder walls. The other 2 were partially blocked with carbon. $1400 later my car was running like new but still showing the cat converter code. That's when I went for the new non-OEM unit in Crane and got $200 in the process(I know the math on the rare earth metals). I have almost 1200 miles on the new injectors and have not burned a drop of oil and that includes rapid driving on very hilly Ozark mountain roads. I am very happy and plan to put a new set of Ecopias on next week to, hopefully get another 2-3 years out of the car.
    Aaron Vitolins and bisco like this.
    52,349
    wow, great news. all the best!(y)
  3. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    Glad to hear it’s running good, but my lord! They sure charged you a lot.
    my 2004 was running a little rough, so I decided to change the injectors myself. Got a used, but cleaned set of oem Toyota injectors for $35. Runs great, getting 49 mpg!
    ozarkretiree and Raytheeagle like this.
