valve stem seal DIY
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Mola, Apr 6, 2018.
  1. T1 Terry
    T1 Terry Active Member
    929
    478
    How do you keep the valve fully seated so the spring will compress enough to reinstall the collets? Even getting them out in the first place would be tricky .... the piston isn't a touch fit to the valve at TDC, they get a bit noisy when that happens :lol:
    T1 Terry
  2. ASRDogman
    ASRDogman Senior Member
    7,542
    3,895
    When you put the new valve guide seal on it will hold the valve in place.
    At least they have on the hundreds I've done.
    On every engine I've done the piston in close to the valves so they don't move
    very much. Sometimes it can be tricky. But I've never had any problems.
    And as needed: results may vary....
  3. T1 Terry
    929
    478
    Thanks for the reply, I've never actually tried to do it without the compressed air so I'll take your word for the effectiveness of this method. Thankfully my mechanicing days are in the past so I don't expect to do many more now I'm in my semi retired yrs, I'll stick to solar and lithium batteries for off grid houses and RV's, a lot easier on the body :)
    T1 Terry
  4. Lemon Drizzle
    Lemon Drizzle Junior Member
    Hall Green, West Midlands
    Who is going to make a step-by-step video for us novices on this procedure?
    Kind regards
    SFO likes this.
  5. Mendel Leisk
    41,327
    @NutzAboutBolts had a video on valve seal replacement. Not linked here, but hopefully will still be on his YouTube channel if you dig.
    telmo744 likes this.
  6. Mendel Leisk
    41,327
    Here's the link:
  7. Lemon Drizzle
    Thank you Mendel. I've just made a new thread for this topic. Maybe that was a mistake.
  8. Lemon Drizzle
    Also can this be done without this tool?
  9. Mendel Leisk
    41,327
    You can report it, request mods delete thread.
  10. Lemon Drizzle
    Also
    Aldo Mendel, that is not a gen 3 prius engine in the video. Does anyone know any videos out there for the 1.8L gen 3 prius engine?
    Thanks
