Spare Tire VS Traction Control
Discussion in 'Gen 2 Prius Technical Discussion' started by bad monkey, Oct 10, 2006.
  1. bad monkey
    bad monkey New Member
    So I get a nail in my tire and drive to work after filling it up and watching the tire pressure sensor instead of the road. The tire shop can't fix it, so they order me a new tire. For tomorrow. I drive home and back to work today on the doughnut spare. Anytime I turned a corner or drove over 50mph, the traction would flash. If it flashed for speed I would fight it for control and to maintain my speed, as it was trying to slow me down from my "uncontrollable wheel." I drained the battery fighting it for control on the freeway. I guess I was fighting the brakes with the motor because it's the only time I got 99.9mpg uphill at 65 mph.
    I know that the diameter of the spare versus the full size or different, and therefor a different revolutions per mile, but there must be a way to tell it that this is a special condition and don't help.
    Yes I have non-stock tires. The Sumitomo HTR-200 P195's.
  2. vkykam
    vkykam New Member
    27
    You know, for your own safety, you shouldn't really drive over 50mph on the donut anyways. AFAIK, just about all spare tires' maximum speed is 50mph, and I doubt the Prius would be an exception.
    Think about the narrow tread you're driving on and what would happen at 65mph in an emergency...
    <div class='quotetop'>QUOTE(bad monkey @ Oct 10 2006, 05:54 PM) [snapback]330853[/snapback]</div>
  3. Tempus
    Tempus Senior Member
    1,690
    Washington DC
    Did you have the donut on the front?
    If you blow a front tire, I would strongly recommend putting a good tire from the back on the front and only running the donut in the rear.
  4. bad monkey
    I don't mean to sound condecending. Thank you for the spare tire tips.
    My issue is that I can not get from home to work without going 20 miles and an hour out of my way without using the freeway. There is a six mile section of freeway that is free of slow traffic and I have to traverse it both ways. I can be the guy at 50mph while everyone else is at 85 to 90, but that is more dangerous than trying to get to 65 on a tire rated for 55. That is not my biggest complaint. I know I am doing something that is outside specs. Fine. But when I TURN A CORNER at 15mph, I expect that to not necessitate the traction control slowing me down to a crawl.
    When it's raining the 10 days a year here, I love the VSC. When I accelerate from a stop and my tires go over leaves and the car slows down to compensate, I hate it. I just wish there were a button to shut it off when it wouldn't help the driver. Maybe then I could do some burn-outs with the high torque motor, or even drive properly with a spare tire.
  5. ceric
    ceric New Member
    1,114
    Fremont, CA
    <div class='quotetop'>QUOTE(bad monkey @ Oct 11 2006, 11:45 AM) [snapback]331192[/snapback]</div>
    I believe there may be a way (a sequence of actions you must perform per start-up) to shut off Toyota/Lexus VSC. The sequence I read was for Lexus GS. I believe it may also work for Prius.
    Just Google...
    Lexus VSC "turn off"
    Since there is no editing post allowed, I am posting the sequence here.
    The sequence was for Lexus GS 300/430. I personal did not try it. (source atumobilemag.com)
    1. Make sure the car is in Park and the parking brake is disengaged before you start the car.
    2. Start the engine.
    3. Engage the parking brake.
    4. Fully depress the brake pedal and then release.
    5. Fully depress the brake pedal and then release.
    6. Disengage the parking brake.
    7. Fully depress and hold down the brake pedal.
    8. Engage the parking brake, then disengage it (while holding down the brake pedal).
    9. Engage the parking brake, then disengage it (while holding down the brake pedal).
    10. Release the brake pedal.
    11. Engage the parking brake.
    12. Fully depress the brake pedal and then release.
    13. Fully depress the brake pedal and then release.
  6. Beryl Octet
    Beryl Octet New Member
    1,293
    Abingdon VA
    <div class='quotetop'>QUOTE(Tempus @ Oct 11 2006, 11:24 AM) [snapback]331147[/snapback]</div>
    It's gonna suck no matter where you put it, if it's on the back, then there is a tendency for the back to swing out when cornering etc.
  7. hyo silver
    hyo silver Awaaaaay
    15,268
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    You might want to check the air pressure on the spare. They're typically over-inflated, and have about as much traction as a wooden wheel. There may be mould-release compound still on it, too, which is also very slippery.
  8. Sufferin' Prius Envy
    3,998
    The traction control is not there just to prevent us from spinning our wheels . . .
    “in the Prius the reason for the interrupt in power when the wheels spin on wet surfaces is to protect MG1 from an over speed condition as the psd tries to correct the MG2 speed and it's all controlled by the abs computer input to the ICE control computer. It sees wheel speed for all 4 wheels and say's nope your not going to over speed MG1 when you regain traction and the psd want's to correct the speed imbalance between the 2 of them.â€
    Frank Hudon
    http://priuschat.com/index.php?s=&show...ost&p=44223
    rogerdpack likes this.
