Rim sizes
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Airbalancer, Oct 8, 2010.
  1. Airbalancer
    Airbalancer Active Member
    892
    73
    Cobourg, On, Canada
    I hope the mods can make a sticky with different rims sizes, since winter is coming
    Can 15" 5X114.3 steel rims fit a Prius
  2. HAWAIIANBUILT
    HAWAIIANBUILT Senior Member
    824
    791
    69
    SO CAL
    HI AIRBALANCER !!!
    The Standard Lug Pattern for the Prius is 5x100.
    You can run the 5x114.3 if you utilize a wheel adapter.
    Hope this helps !!!
    Rodney
  3. Sac916Prius
    Sac916Prius New Member
    Sacramento
    what is your rims size on your prius...
