EV Mode
Discussion in 'Gen 4 Prius Accessories and Modifications' started by Kimoy, Aug 27, 2020.
  1. Kimoy
    Kimoy Member
    168
    24
    Chicagoland
    Is there a way to disable the limiter on the EV mode. I want to go EV for faster than 25mpg.
    I have a 2020 Prius AWDe
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    What do you mean "faster than 25mpg"??
    EV Mode is totally automatically controlled by the microprocessors for maximum efficiency - but won't make you go any faster.
  3. Salamander_King
    Salamander_King Senior Member
    11,024
    8,976
    New England
    I think the OP means "faster than 25 mph".
    And answer is NO, not on 2020 Prius AWDe. You would have to trade in your AWDe and get Prius Prime to be able to drive EV mode faster than 25 mph.
    #3 Salamander_King, Aug 27, 2020
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    There's a reason for the car not wanting you going fast. The battery doesn't store that much energy. It can shut off the engine under extremely light loads at higher speeds, but you pretty much need to be decelerating for that to happen.
    Basically, EV on the regular Prius is most useful for getting the car out of the garage so you can wash it. If you want to drive it like a Prime, you need to buy a Prime. If you NEED AWD and want EV mode driving, then the RAV4 Prime should be coming to your rescue sometime in the coming year.
    alanclarkeau and krmcg like this.
  5. bisco
    52,658
    there is a way, but it's secret. are you ready to pony up for the premium priuschat membership?
  6. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Consider yourself lucky.
    My C won't stay in "EV" above 5 MPH.
    krmcg likes this.
  7. Tideland Prius
    16,643
    No. But without EV mode, you can still travel up to 62mph with the engine off if you’re careful on the throttle.
    But in terms of normally driving around in EV mode, you’ll need a Prius Prime for that.
  8. alanclarkeau
    7,045
    7,593
    Yes, but only once the ICE has warmed up - otherwise the ICE comes on at 38km/hr.
    Tideland Prius likes this.
  9. Kimoy
    Kimoy Member
    168
    24
    Chicagoland
    So what makes the prime go 80mph on EV mode
  10. CooCooCaChoo
    CooCooCaChoo Senior Member
    962
    544
    Cow-lee-fornia
    2023 Prius
    ^^^ Programming. The Prime is technically the same as all other Priuses with the exception of a larger battery and programming.
    alanclarkeau likes this.
  11. jerrymildred
    11,517
    14,164
    Tampa, FL
    The P610 transaxle for the Prime uses MG2 and MG1 for power in EV mode, which is made possible by a one-way sprague clutch between the engine and the transaxle. The regular Prius doesn't have that sprague clutch so MG1 can't spin that fast to allow that much speed. Go to about the one hour, 43 minute mark in this video to see a partial explanation.
  12. jerrymildred
    11,517
    14,164
    Tampa, FL
    And the sprague clutch.
  13. alanclarkeau
    7,045
    7,593
    Remember it's a HYBRID - not an Electric Vehicle. In other words, it's about as efficient as a Petrol powered car can be (at the moment) - using the small hybrid battery to optimise driving. Don't try to drive it as an EV - it isn't one, and pushing EV Mode doesn't help (unless you're hypermiling).
    Very different concept to PRIME. The PRIME battery is HUGE compared with a PRIUS. I think the PRIUS is about 0.8kWh (? can't see the exact figure), PRIME is 8.8, over 10 times bigger.
    Harters, jerrymildred and krmcg like this.
  14. Tideland Prius
    16,643
    For future reference, the NiMH version is 1.31kWh and the Li-Ion version is 0.745kWh for the Gen 4 Prius.
    #14 Tideland Prius, Aug 29, 2020
  15. jerrymildred
    11,517
    14,164
    Tampa, FL
    I had no idea they were so different!! :eek:
  16. CooCooCaChoo
    962
    544
    Cow-lee-fornia
    2023 Prius
    Yeah, this was done, IIRC, because the Li-ion battery can use a wider ranger of the battery SoC vs the range of the NiMH.
  17. Tideland Prius
    16,643
    It also charges and discharges more easily than the NiMH; a bit disconcerting to seasoned Prius owners used to the operation of the NiMH of the Gen 2 and 3. It definitely allows more EV driving than previous generations and you can more easily recapture the energy back with regenerative braking.
    It saves about 5kg over the NiMH battery (could be 4, could be 6. There’s a typo in the spec sheet so it says 324.5kg lol. We don’t know if they meant to write 32.5 or 34.5kg)
  18. jdenenberg
    jdenenberg EE Professor
    3,960
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    My 2020 Prius AWD-e has the NiMh battery, not the LiOn. The good news is that I already know how to maintain a NiMh traction battery (I had one in my 2004 Prius).
    JeffD
    jerrymildred and Raytheeagle like this.
  19. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,525
    Bay Area, California
    2019 Prius Prime
    What color did you get for your new Gen4?
  20. jdenenberg
    3,960
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    As in my signature red of course.
    JeffD
    Raytheeagle likes this.
