Accidentally added trans fluid to inverter coolant reservoir
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by hihosilver, Sep 2, 2020.
  1. hihosilver
    hihosilver Junior Member
    Irvine, California
    Yes I did this - and did not realize I did so until eight months later.
    So last October I had my auto transmission fluid drained & filled. Then I looked under the hood in December & noticed a reservoir (by the brake fluid reservoir) filled with pink fluid that was low - I had transmission fluid on the brain so I topped it off from low to full.
    Eight months later - now - I realized what I did as I prepare to drain & fill the inverter coolant. Oops.
    So should I be concerned? Have no idea what a few ounces of auto trans fluid would do to a inverter cooling system.
    Car is still running, guess that's a good sign :)
    Any thoughts/suggestions would be appreciated.
    Majafamily likes this.
  2. Kenny94945
    Kenny94945 Active Member
    855
    431
    Sausalito
    2016 Prius v wagon
    8 months ago?
    No drivability issues?
    Wow....dodged a bullet.. my guess would have been drivability issues.
    What I would do is drain and refill the invertor coolant two times in an effort to clean the system.
    The oil may have floated on top of the coolant, so turkey baster the coolant reserve first before doing a drain.
    Good luck.
    jerrymildred, RRxing, ETC(SS) and 2 others like this.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    That's one way to keep the pump lubricated......
    jerrymildred likes this.
  4. Grit
    Grit Senior Member
    6,573
    4,228
    Wilkes Land
    “If it ain’t broke, don’t fix it” a quote I see here at times.
  5. ETC(SS)
    7,282
    +1 for both not worrying about it and changing the inverter coolant x2.
    Since it's only two months until Thanksgiving, you may want to splurge on a new Turkey baster.
    Besides.....Thanksgiving might be a little rough this year.
  6. PA Prius
    PA Prius Active Member
    762
    251
    SE Pennsylvania
    Reminds me of the first time I changed the oil in my 914. Realized I poured the oil in a hole that went to the clutch....
  7. hihosilver
    Irvine, California
    Thanks everyone for your suggestions and laughs - appreciate the laugh-with-me response to my bone head move.
    With the car sitting still overnight, I inspected the reservoir & noticed a pink coloration for the top two inches that was different than below the top - I thought perhaps the trans oil was floating on the top.
    So I started drawing (via tube sucking) the top fluid & unfortunately I was drawing a mix of trans oil & coolant (mostly coolant), it looked like lightly tossed pink Italian salad dressing. The reservoir tank color differentiation is probably a coating that developed over the last eight months since I did what I did.
    Kenny, I'll do as you suggested - a drain & fill twice.
    My question is - should I bother with and/or is their any harm in using a radiator flush? Like adding a 11oz bottle of Gunk Motor Medic Radiator Flush to help de-coat the trans fluid from the inverter cooling system?
  8. ETC(SS)
    7,282
    Since the system is rated for Toyota's coolant I do not think it will hurt it, but I'm not sure if you will benefit either, especially since you've been using the salad dressing for 8 months now without any problems.
    I'd flush and monitor - but that's me being me.
  9. Grit
    Grit Senior Member
    6,573
    4,228
    Wilkes Land
    No refill after the flush? :eek:
  10. ETC(SS)
    7,282
    Pends on whether or not you're at a dealership, where "flush" and "fluid change" are interswappable.
