  1. Montgomery
    Montgomery Senior Member
    2,254
    2,241
    Orange County, CA
    107 degees today. Was going to detail the hell out of my car till the heat kicked in. Hiding inside for now. Next two days projected to be over 100 degrees and we should cool down into the 90's by mid next week. Whoop-De-Do!
  2. ianzkee
    ianzkee Junior Member
    SoCal
  3. ianzkee
    SoCal
  4. MPGRaja
    MPGRaja Senior Member
    469
    1,679
    Corona
    Added couple things to the basic PHV ;)
    JDM OEM visors
    JDM vent cup holders
    #18404 MPGRaja, Sep 6, 2020
    HelloHybrid, orenji and Burna J like this.
  5. PaulMS308
    PaulMS308 Member
    Orange county
    Red Bullet, Actually it's been roughly 3 weeks since I've installed the solenoid. I live in OC commute to La x5 a week for work... roughly 80 miles round-trip per day. In short, I get the same MPG in "Normal" mode now as when previously in "ECO" with the added drivability! Throttle is much more responsive, ECU switch's from combustion to EV quicker and actually stays in EV longer. The car now drives in a "New" drive mode that is somewhere in between"Normal" - "Power" with the MPG of "ECO".
    Currently avg 47-49 MPG in "Normal" mode with 98% of that being fwy traffic.
    _xw30_chris, RMB, HelloHybrid and 4 others like this.
  6. Xterra72
    Xterra72 Senior Member
    1,429
    1,673
    Link? I might just try the real deal ..
  7. PaulMS308
    PaulMS308 Member
    Orange county
    ebay;
    Red Bullet VVTI Toyota Prius 1.8 (2009-2019)
    Xterra72 likes this.
  8. Xterra72
    1,429
    1,673
    This is still the older version? Thought they were going to make the newer one with the modification to clear the engine cover.
  9. Montgomery
    2,254
    2,241
    Orange County, CA
    They did make a newer version. Just make sure when you order it they know your car is NOT a PriusC. I have had the same results for over 6 months now. I don't regret buying the red bullet.
    PaulMS308 likes this.
  10. ianzkee
    SoCal
    How bad did it end up touching the engine cover? Were you able to put the cover on perfectly fastened?
  11. Montgomery
    2,254
    2,241
    Orange County, CA
    Yes, it comes with an extended fastner. Very simple and clean. You can't tell the difference.
    ianzkee likes this.
  12. MPGRaja
    469
    1,679
    Corona
    Honestly it’s not even a big deal :whistle:. You can either cut a small 3/4”or leave it. BTW QUANTUM solenoid is also the same thing, just a different seller and rebranded.
    ianzkee likes this.
  13. ianzkee
    SoCal
    Thanks for the reply, might hold off until the revised version comes out.
  14. Xterra72
    1,429
    1,673
    I sent a message to the seller and this is what he had to say...
    We have custom standoff for the gen 3 which mediates this issue. This gives the engine cover a little more breathing room and also can be reversed at anytime without permanent modifications to the cover. We do not do the re-clocked version anymore due to unstable performance.
    I hope this answers your question. If you have any questions or concerns please check out our website redbullet.net
    TheeWood and ianzkee like this.
  15. pree_us
    pree_us Member
    64
    95
    Santa Clarita
    They had me pay $75.
  16. pree_us
    pree_us Member
    64
    95
    Santa Clarita
    As a side note, look underneath just past the rear axle line toward the rear. . . a couple of diffusers molded into the plastic undertray, helping the Prius' airflow management.
  17. pree_us
    pree_us Member
    64
    95
    Santa Clarita
    Do you have a pic facing directly at the rear of your Prius? I have an Ebay 4-fin diffuser sitting in the garage. I'm debating whether or not to install it.
  18. PaulMS308
    PaulMS308 Member
    Orange county
    Bad Picture but you get the idea...
  19. Mongiamc10
    Mongiamc10 Junior Member
    66
    22
    Finally got some wheels on my 2015! Bought some Rays Super Ecos 17x7 in Formula Silver from another member on the forum. I wrapped them in Yokohama Avid Ascend GT 215/45 and I previously had it lowered on Tanabe DF210 springs along with a Cusco strut bar and TRD Rear sway bar.
    HelloHybrid, RMB, Montgomery and 4 others like this.
  20. priusgreymint
    priusgreymint Member
    96
    67
    Look at those wheels!
