OEM Cross Bars / Roof Rack
Discussion in 'Prime Accessories and Modifications' started by kepani, Aug 3, 2020.
  1. kepani
    kepani Member
    63
    67
    2020 Prius Prime
    Well, if anyone has been wondering about the OEM Cross Bars / Roof Rack, I purchased a set yesterday from my local dealership. In about 20 minutes after unpacking the kit, it was fully installed. The installation was very simple and the fit is of OEM quality.
    The part number is PW30147009 and the link to the kit is here:
    2020 Toyota Prius Removable Cross Bars - With Keys - PW30147009 - Genuine Toyota Accessory
    The main use is for my surfboard. Atop the cross bars, I use Thule Surf Pads (Wide L 30") with the Thule Express Surf Straps. It works just as one would expect to secure and transport a surfboard.
    I do see that many are curious as to the wind noise after fitting a Prime (or a normal Prius) with one. I have yet to take it on the freeway to get some impressions. Once I do, I'll try to remember to check back in here. However, since working from home during the pandemic, I have had little need to drive on the freeway!
    #1 kepani, Aug 3, 2020
    UCC and LightningBolt like this.
  2. kepani
    kepani Member
    63
    67
    2020 Prius Prime
    UPDATE: Noticeable Wind Noise?
    This morning I drove in to work and wanted to see if I could hear or detect any significant wind noise or adverse effects from the cross bars.
    Note: The outside air temperature was around 68 deg. F on the way to work so this report may not apply to cooler or warmer conditions. ;)
    At around 45-50 MPH on the street (non-freeway), I thought I could hear a slight high pitched "whirring" coming from above. It wasn't extremely loud, but i'm certain it was coming from the cross bars.
    Upon entering the freeway, I focused in on that same noise as I approached 45-50 MPH, but didn't hear it. I suspect it was due to the freeway pavement (concrete vs. asphalt) and the other vehicular noise that might have drowned out that sound. As I drove up to freeway speeds (60-70 MPH), I didn't hear any noticeable wind noise. Then again, it could have been drowned out by surrounding noise.
    As for efficiency, I didn't really look at the negative effects. I'm sure there's a percentage decrease, but I drive slowly on the freeway anyway so that efficiency loss is obviously a factor of your top speeds.
  3. Salamander_King
    Salamander_King Senior Member
    11,024
    8,963
    New England
    Great to know that the wind noise is unnoticeable at high speed. I read earlier review on 2017 PRIME with very loud noise. I wonder if Toyota has improved the OEM roof rack somehow? The price is just right too. Much better than Yakima kit IIRC.
    LightningBolt and kepani like this.
  4. kepani
    kepani Member
    63
    67
    2020 Prius Prime
    Hi @Salamander_King actually, now that you mentioned earlier reports, I realized that the cross bars / roof rack I have is apparently an updated kit. I have Part # PW30147009.
    The old kid had Part # PW30147005.
    So It seems they may have updated it to address the noise issues?
    I drove home from work earlier this morning and didn't hear any noteworthy noises!
    LightningBolt likes this.
  5. kepani
    kepani Member
    63
    67
    2020 Prius Prime
    @Salamander_King speaking of the Yakima kit, which one were you looking at? I actually paid around $284 give or take before taxes for the kit (Part # PW30147009). I could have driven further away to another dealer to get a better price but I needed the racks for a surf session so I just decided to get the rack anyway!
    The fitment is excellent IMO...
  6. Salamander_King
    11,024
    8,963
    New England
    Pics of older Part # PW30147005 and new old kid had Part # PW30147009 looks identical. The part numbers seems to be interchangeable.
    Toyota Prius Removable Cross Bars - With Keys - PW30147005 - Genuine Toyota Accessory
    Not sure if they are different in anyway. Noise level maybe very subjective thing and may change in different conditions, so I am not sure. Earlier when I got my 2017 PRIME, I was worried about the smaller cargo area and explored the possible roof rack, but since then I have discovered that my use case for this car is such that I don't use rear seats at all, and having the seats folded allowed plenty of cargo space for most uses. Also, since then, I have purchased used Pathfinder Hybrid SUV for people and cargo carrying trips.
    I don't remember which specific Yakima rack system I was looking at, but any one of the systems are priced higher than OEM parts.
    Roof Rack Systems– Yakima
    #6 Salamander_King, Aug 5, 2020
  7. LightningBolt
    LightningBolt New Member
    27
    Rhode Island
    2020 Prius Prime
    Speaking of cross bars - how do you store them when they are removed from the car?
    I'm looking for some sort of cloth-like bag with a drawstring closure but haven't found anything suitable yet.
    Any ideas?
  8. Prim.e.xample
    Prim.e.xample Active Member
    164
    107
    Indiana
    2020 Prius Prime
    Do you find them beneficial so far? I’ve been on the fence about adding them, but after having a 4Runner, it seems like I sometimes run out of space. Though last week I moved a good amount in it and was surprised!
  9. LightningBolt
    27
    Rhode Island
    2020 Prius Prime
    I don't plan on using them on a regular basis. I wanted them for the times I need to get something big home. Like lumber or an outdoor patio table. They *ARE* real handy helping me find my car in a parking lot!
    Prim.e.xample likes this.
  10. Tips
    Tips Member
    128
    66
    Grand Forks, B.C. Canada
    2020 Prius Prime
    Have you done any damage too the roof of the car as the metal is very thin on these new cars! Just be carefull or you will loose the aerodynamics of the car due to dents. I managed one little dent!
  11. LightningBolt
    27
    Rhode Island
    2020 Prius Prime
    The manual says max load is 152 lbs evenly distributed, i.e. no more than 76 lbs per bar. Should be good as long as you don't exceed that.
  12. m8547
    m8547 Senior Member
    950
    628
    Colorado
    2018 Prius Prime
    The edge of the roof where the rack sits is usually heavily reinforced for crash safety. I wouldn't worry about dents.
  13. Rolla01
    Rolla01 Junior Member
    Vancity
    2020 Prius Prime
    Hi I'm new here and just got a 2020 Prime and set of used OEM roof rack. And I realized that I am missing a set of plastic inserts, and I cannot find the part number for them. Do I really need them? Thanks.
    Opt1mus and LightningBolt like this.
  14. LightningBolt
    27
    Rhode Island
    2020 Prius Prime
  15. Rolla01
    Vancity
    2020 Prius Prime
    I got the roof racks from Craigslist and it does not come with the insert, and the seller don't have them installed in their car too. Will try dealer, hopefully they can find the part.
  16. LightningBolt
    27
    Rhode Island
    2020 Prius Prime
    I just took my crossbars off today and took a look at the insert.
    It has a hole in the center that accepts a pin on the crossbar mounting bracket.
    I would say its important to have that insert.
    Not only does it keep the pin from moving around in the larger hole, but because its plastic it protects the paint on both the roof rail hole and the crossbar pin from getting scraped away.
    You might be able to get away with wrapping some plastic electical tape or duct tape around the mounting pins to build them up to the diameter of the hole, but I would get the inserts if I were you.
    Opt1mus, Rolla01 and kepani like this.
  17. kepani
    kepani Member
    63
    67
    2020 Prius Prime
    Hi @Rolla01 I would definitely go to your Toyota dealer and get them. You'll need them to properly index/align your roof rack when you tighten down the clamps. You'll notice in the installation instructions to remove the blank plastic inserts that are on your car from the factory and to replace them with the inserts you're missing.
    If you don't put them in, there's no guarantee that your racks are set properly and when you tighten down, you could damage the roof.
    Good luck!
    Rolla01 and LightningBolt like this.
  18. kepani
    kepani Member
    63
    67
    2020 Prius Prime
    Absolutely! (y)
    LightningBolt and Rolla01 like this.
  19. kepani
    kepani Member
    63
    67
    2020 Prius Prime
    I only got them for my surfboard which is not very heavy. But for that purpose, they're great! I just attach a soft top sleeve (velcro) around the bars and they work fine. If you're coming from a 4Runner, then yeah, I can see why you'd run out of space quickly!
    LightningBolt and Prim.e.xample like this.
  20. LightningBolt
    27
    Rhode Island
    2020 Prius Prime
    The wind noise is definitely noticable. At first I thought it wasn't bad enough to be objectionable, but as time went on it got to be annoying and I finally took the bars off. I'll put them on if I need to haul anything but I'm keeping them off for the coming winter.
    I also worry about going through a carwash with them on. Anyone have any experience with that?
