Making a hole into the side of the Auxiliary Box under the CD Player
Discussion in 'Gen 2 Prius Audio and Electronics' started by exhuman, Oct 11, 2006.
  1. exhuman
    exhuman Member
    151
    Pasadena, CA
    I have my VAIS working fine and sharing my top glove box with my iPod. I'd like to have the iPod in the Aux box under the CD player for ease of getting it and putting it back. I'm thinking of putting a hole in the sid of the aux box close to the back. Then I can thread the cables for the iPod thru that hole and have a nice little home for my iPod.
    When I first considered this I thought it was just plastic and I could melt thru with a soldering gun or easily drill thru. Now it seems that there is a metal cage that surrounds it. Has anyone made such a hole in that box? Or does anyone have any suggestions on making one?
    Thanks for any ideas.
  2. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    Yes, people have done it (and i will be when i get my Dice unit). Did you just look at the sides, or is the back included in that metal cage?
    One suggestion i would have is don't make the hole the size of the iPod connector, make it the size of the end that plugs into the Vais (which, i believe, is round and smaller).
    Also, i'd go with the drilling method rather than the melting method. the fumes from melted plastic aren't good for your lungs, for one, and a drilled hole will be more accurate to the minimum size you need.
  3. Skwyre7
    Skwyre7 What's the catch?
    2,332
    Richmond, Virginia
    I did while installing my Sirius Starmate (here).
    I used a Dremmel. (It was closer than my drill.)
  4. exhuman
    exhuman Member
    151
    Pasadena, CA
    <div class='quotetop'>QUOTE(Skwyre7 @ Oct 11 2006, 03:03 PM) [snapback]331391[/snapback]</div>
    When you drilled back there did you have to go thru any metal or just plastic? Thanks for the info and pic.
  5. dgstan
    dgstan Member
    159
    OC
    I did the same thing, except on the right side of the cubby instead of left. It's plastic only - no metal where I drilled. I felt up behind it to make sure I wasn't going to drill into anything important. I used a 1/2" dia. drill IIRC. Just big enough for the round DICE connector.
  6. galaxee
    galaxee mostly benevolent
    9,810
    470
    MD
    DH installed our drive and play ipod adapter screen in that little box. pretty sure he removed the box, drilled the holes, mounted the screen and put it all back in there.
  7. yakky
    yakky New Member
    <div class='quotetop'>QUOTE(dgstan @ Oct 11 2006, 06:44 PM) [snapback]331420[/snapback]</div>
    I drilled the right side also. Please don't melt or dremel, its going to look crappy and make a mess. Use a bit that is just slightly larger than the smaller plug.
  8. exhuman
    exhuman Member
    151
    Pasadena, CA
    <div class='quotetop'>QUOTE(yakky @ Oct 11 2006, 05:20 PM) [snapback]331465[/snapback]</div>
    Sorry if I'm getting too picky, but did you drill thru the right side of the back or the back of the right side? Also, did you have to go thru any metal.
    Thanks to all for your insights.
  9. naterprius
    naterprius Senior Member
    1,843
    I would remove the box, then drill through the top, then put it back in.
    These boxes are dirt cheap (under $20) and most techs at the dealers each have a spare they'll give you for free from some sort of upgrade.
    Nate
  10. Skwyre7
    2,332
    Richmond, Virginia
    <div class='quotetop'>QUOTE(exhuman @ Oct 11 2006, 06:28 PM) [snapback]331411[/snapback]</div>
    I had removed the CD tray when I dremmeled. I don't recall seeing any metal that you would have to drill through. There will be metal on the sides, but there might be some places that aren't covered by metal.
    <div class='quotetop'>QUOTE(yakky @ Oct 11 2006, 08:20 PM) [snapback]331465[/snapback]</div>
    Dremmeling did make a mess, so the drill with proper bit size would have been a better choice.
    <div class='quotetop'>QUOTE(naterprius @ Oct 12 2006, 12:45 AM) [snapback]331565[/snapback]</div>
    That's a good idea.
  11. GeoGeek
    GeoGeek Member
    360
    31
    Auburndale, FL
    In the attached .pdf file (from Metraonline.com) there are directions for
    putting in their aftermarket radio adapter kit. In it, there are diagrams that
    show you what the metal brackets (that hold the radio & pocket) look like.
    You can clearly see that there are parts of the pocket that are not aligned with
    the metal brackets that you're worried about hitting.
    If you're still not confident, there's also directions for taking apart the dash
    so you can get the pocket out & drill it from the safety of a workbench.
    Enjoy!
  12. dgstan
    dgstan Member
    159
    OC
    <div class='quotetop'>QUOTE(exhuman @ Oct 11 2006, 06:06 PM) [snapback]331479[/snapback]</div>
    I drilled right through the back without removing anything. I distinctly chose that location because there was nothing behind it - no metal or wires.
  13. GeoGeek
    GeoGeek Member
    360
    31
    Auburndale, FL
    <div class='quotetop'>QUOTE(GeoGeek @ Oct 12 2006, 02:10 PM) [snapback]331806[/snapback]</div>
    Revision:
    Although the diagram in the Metra manual shows the pocket extending beyond
    the metal bracket, I had occasion to pull my stereo this weekend and found
    that not to be the case. See the attached piucture to get a feel for where the metal
    is relative to the pocket.
    Good luck!
  14. exhuman
    exhuman Member
    151
    Pasadena, CA
    Thanks for everyone's input. I drilled in to the middle of the back of the pocket. Made a not-so-beautiful hole. But it works fine. Threaded my cables thru. Now my iPod has a cozy new home.
    Thanks again.
  15. PrimeRisk
    PrimeRisk New Member
    somewhere
    <div class='quotetop'>QUOTE(GeoGeek @ Oct 15 2006, 06:55 PM) [snapback]333167[/snapback]</div>
    Geo, in your estimation, is there enough depth behind the pocket to install an aftermarket stereo and still have the door close? (Assuming you remove the pocket)
  16. GeoGeek
    GeoGeek Member
    360
    31
    Auburndale, FL
    <div class='quotetop'>QUOTE(PrimeRisk @ Nov 11 2006, 05:47 PM) [snapback]347574[/snapback]</div>
    Since taking that picture I have installed a half-din EQ (the Audio COntrol Three.1) in that space.
    It's definately a full din space and I have read of others here on PC who have installed full din
    slide-out monitors etc. in that space. Depth toward the back shouldn't be an issue, but depending
    on which unit you're installing, it may be tight keeping the face behind the smoked plastic door.
    The screw holes in the metal side brackets that hold the plastic pocket in also line up nicely with
    the mounting holes on most aftermarket head units/eq's.
    Good Luck!
  17. PrimeRisk
    somewhere
    <div class='quotetop'>QUOTE(GeoGeek @ Nov 11 2006, 08:50 PM) [snapback]347635[/snapback]</div>
    Thank you for the quick reply. I'm hopeful that the unit will fit behind the door. I currently have a Rockford OmniFi MP3 faceplate mounted on the front of the existing pocket and the door still has plenty of room to close without touching the faceplate.
    My intention is to remove the OmniFi faceplace and replace it with the JVC KD-DV6200 In-dash DVD receiver connected to the MFD through the CoastalETech ultimate lockpick and I'll throw in Sirius satellite connected to the JVC while I'm at it. Unfortunately I can't seem to find one in the local area, so I'll have to order it in and hope that the control knob on the front doesn't stick out too far.
    Take a look at the features of the JVC KD-DV6200 it looks pretty full functional. If you search for the price, you can get DVD Video, MP3/WMV playback from CD or DVD, Sirius, and XM in your Prius all for about $450. You can add an ipod and HD Radio interface to the JVC if you like too.
